Write-up: 3rd Gen Bilstein 6112/5160 with 3-Leaf AAL for 1.5" lift
Discussion in 'Suspension' started by smitty99, Apr 15, 2017.
  1. Oct 26, 2018 at 3:15 PM
    #341
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Well there are users here who installed the new Fox pro suspension and I believe are only getting 1” right? (From stock OR)
    Rob Daman[QUOTED] likes this.
  2. Nov 4, 2018 at 5:05 AM
    #342
    Vjtrey1
    Vjtrey1 Well-Known Member
    Richmond, Tx
    2018 Super White Tacoma TRD OR DCSB
    Simple mods
    Hi did you use 6 tones jack stand in this video?
  3. Nov 4, 2018 at 6:44 AM
    #343
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    That guy is no longer on this forum.
    I think 6 ton jack stands would be more than enough.
    I use 2-ton when rotating my tires...
    I’m going to get beefier ones though soon.
  4. Nov 4, 2018 at 6:48 AM
    #344
    ejewels
    CT
    What happened to smitty?
  5. Nov 4, 2018 at 7:23 AM
    #345
    nDub
    Lead Free Gasoline
  6. Nov 4, 2018 at 7:24 AM
    #346
    ejewels
    CT
  7. Sep 8, 2019 at 12:56 PM
    #347
    Governor
    Governor Well-Known Member
    Las Cruces, NM
    2016 DCSB TRD OR 4x4
    :hattip:thank you smitty
  8. Oct 3, 2019 at 8:06 AM
    #348
    veedo
    veedo Well-Known Member
    Anyone here install the 6112's on clips #2 and #3? Not looking for much lift, as I don't plan to do anything with the rear. Bilstein says .5 an inch, just wondering if anyone has real world results. 18 off road double cab short box.
  9. Oct 3, 2019 at 8:10 AM
    #349
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    No personal real-world results here, but I seem to remember Marie @HeadStrong Off-Road indicating that the measurements shown in the chart were pretty accurate.
  10. Oct 3, 2019 at 11:11 AM
    #350
    veedo
    Thanks for the quick reply.
  11. Oct 4, 2019 at 11:34 AM
    #351
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Usually most people report seeing more lift out of the gate but they tend to say that they settled in near the height listed on Bilsteins guide.
  12. Dec 10, 2019 at 5:34 PM
    #352
    nate_scarbrough
    nate_scarbrough Well-Known Member
    Nate
    2017 Mettalic Grey TRD Off-Road
    Just received my 5160’s in the mail and was checking the parts and what not and noticed the *left shock came with a brake spacer/bracket. I view the left being drivers side but others might view it as passenger. That’s the only difference between the 2 shocks is the one side (either driver side or passenger) has a brake line spacer. Looking for clarification please! TIA!
  13. Dec 10, 2019 at 7:48 PM
    #353
    Comb
    Comb Known Member
    The rear left (driver side) gets the brake line spacer.
  14. Dec 26, 2020 at 2:17 PM
    #354
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    I made this little video on how to install a Fox Roost Shield "Shinguard" on a the passenger-side rear Bilstein 5160 shock.
    Edit 2021-11-08: The mudfest at Rendezvous in Ozarks rendered this shield a mud collector. I will be drilling multiple holes in the bottom to mitigate the issue.
