Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. May 15, 2018 at 8:08 AM
    #701
    Aw9d
    Aw9d That one guy
    They are all about the same. The cheap ones are hit and miss. I have the $11 one from Amazon and it's been working great since 2011.
  2. May 15, 2018 at 8:22 AM
    #702
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    So you just plug it in to your truck, load of the torque app, and you are good to go? If the answers are in this thread maybe someone could point me int he right direction? It would be nice to get HP/temps/MPG info.
  3. May 15, 2018 at 8:23 AM
    #703
    Aw9d
    Aw9d That one guy
    For the most part yes. You do need to setup the Torque app with the truck info but it's pretty simple.
    HP won't be accurate. Temps are there but you'll have to add the trans temp manually. MPG info is there but it's hit and miss on how accurate it is.
    xguntherc likes this.
  4. May 15, 2018 at 8:40 AM
    #704
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Ahh ok. I just ordered it and will play around with it on Thursday. Thanks!!
    Aw9d[QUOTED] likes this.
  5. Feb 8, 2019 at 8:05 AM
    #705
    Oscar I
    Oscar I No longer a toyota driver
    Resurrecting a dead thread here.
    I'm trying to get the engine knock to work and I've searched and searched and cant find one that works with the 3.5 anyone have a lead on this pid?
  6. Feb 19, 2019 at 11:31 AM
    #706
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    Towing the track car from San Diego to Sacramento, bought a bluetooth OBD2 scanner and the Torque Pro app. Do I need the custom PID codes to read my '14 AT Tacoma tran's temp or is it all ready to go within the app?
  7. Feb 19, 2019 at 5:45 PM
    #707
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    Not sure of the 14, but I need the custom PID for my '08 trans temps. Add it in and see if it works. That's the best advice I have.
  8. Feb 20, 2019 at 2:10 PM
    #708
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    Thanks!
  9. Feb 21, 2019 at 12:18 AM
    #709
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    Some of you guys posted 2 custom PIDs. I added both and now temp 1 and temp 2 are reading, but both are different temps. What does that mean?
  10. Feb 21, 2019 at 12:48 AM
    #710
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    The pan is usually the first pid. The torque converter is the second. I believe it's just timing issue of receiving senor data but I'm not and expert on this.
  11. Feb 21, 2019 at 4:42 PM
    #711
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    Yes, from what I believe. The torque converter should read higher than the pan if i recall correctly. Not due to timing, but it just runs warmer.
    bigfoote13[QUOTED] likes this.
  12. Feb 22, 2019 at 5:49 PM
    #712
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Anyone data logging with torque? Curious how many readings you get per second. I have some old logs that I was getting about 8/s now I'm getting 1.
  13. Aug 26, 2020 at 1:11 PM
    #713
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Are there more instructions for adding the trans temp?
    I tried and got an error that the variable didn't exist. So I exit out
  14. Aug 26, 2020 at 1:44 PM
    #714
    Poindexter
    Poindexter Well-Known Member
    north of Denali
    15 V6 auto 4x4 mag gray
    I stopped using this app, gosh, two years ago? There was a mandatory upgrade to the torque app when I got a new phone, I couldn't have the old version on my new phone. The new version of the app required me to turn on the location service on my phone to even install the app. I wasn't willing to let go of that control, so I didn't download the new version.
    2015WhiteOR likes this.
  15. Aug 26, 2020 at 2:24 PM
    #715
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    I have the Torque ODB Pro app.
    on the customizable screens there's an option to add transmission temp gauges... But the gauges don't do anything. Hm
  16. Aug 26, 2020 at 2:56 PM
    #716
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    That's because of Android requirements. Android made it that some simple things like knowing your WiFi name needs some level of location services enabled. Even though the app itself doesn't actually need that function, they must comply with Google or get kicked from the Play Store.
    You could search on apkmirror (legit backups) to find an older version of Torque. It should still function fine on newer versions of Android without location services.
    2015WhiteOR and xguntherc like this.
  17. Aug 26, 2020 at 2:58 PM
    #717
    replica9000
    2019 T4R ORP
    You need to create a custom PID. The included PIDs don't work on the Tacoma (and other Toyotas)
  18. Aug 26, 2020 at 3:11 PM
    #718
    replica9000
    2019 T4R ORP
  19. Aug 27, 2020 at 2:33 PM
    #719
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    They are easy enough to configure. From the opening screen, tap the cog wheel. Then settings. The towards the bottom you can manage custom PIDS.
    There are different PIDs between 09 and 10+ so be mindful of that.
    https://www.fjcruiserforums.com/threads/trans-temp-in-torque-pro-obdii-anyone-try-this.323866/
  20. Sep 17, 2020 at 8:21 AM
    #720
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Does anybody with Android 11 have Torque functioning? It has not worked since the 11 Beta launched and the Dev seems out to lunch?
