X runner lift
Discussion in 'Suspension' started by paxr, Dec 24, 2010.
  1. Dec 24, 2010 at 8:06 PM
    paxr
    paxr [OP] New Member
    Camp hill, pa
    06 xrunner
    I have a 2006 X that I want to lift and turn into more of a desert rig. I already know that your thinking why, no don't do that, thats stupid, all of the above. I have desert trucks and prerunners in my blood and only an X in the driveway. I want to keep my current truck because i love it and make it something different. I need help figuring out how to get the lift out of it, which lifts will fit, and any other considerations. I have experience with lifting vehicles and am a mechanic by trade. I just need to figure out what will and will not work on the X. thanks
  2. Dec 24, 2010 at 8:10 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    are the xrunners same suspension setup as the regular 5 luggers or the 6 lug tacoma
  3. Dec 24, 2010 at 8:12 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I'm not sure how the xr's suspension is set up but you could start by removing the spoilers. That will give you some more clearance and if you take it off road they'll probably be ripped off.
  4. Dec 24, 2010 at 8:12 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Welcome to TW Steve.
    Since it's a 5-lug, you should be able to use the same lifts that the base model guys do. Fat Bob's Garage makes a top plate spacer lift.
  5. Dec 24, 2010 at 8:13 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Can't really help you but I remember reading on ttora about a topic like this. A lot of people over there mentioned it might be a good platform because everything is tucked up under the truck, iirc.
  6. Dec 24, 2010 at 8:16 PM
    BAMFTACO
    Juan
    Kings bruh
    To the op my advice just do a shit ton of research and keep posted on any progress if you do end up lifting your truck
  7. Dec 24, 2010 at 8:46 PM
    Ptowntaco
    Ptowntaco Camburg :)
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Tint, Socked, Deck Plate mod, Camburg 2.5 coils, Camburg UCA, 5100's in the rear, Custom Deaver leaf pack, Micky Thomson Classic Locks, BFG KM2, CB
    this sounds really interesting. OP. cant help much but like said before look at 5 lug kits.
  8. Dec 24, 2010 at 9:27 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Remove the body kit and get the total chaos lt
  9. Dec 24, 2010 at 9:29 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    :rolleyes:
  10. Dec 24, 2010 at 9:31 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    looking forward to seeing a lifted x runner in the future...
    Good luck man!
  11. Dec 24, 2010 at 9:34 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
  12. Dec 24, 2010 at 9:35 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Yup, the TC 5 lug kit is bolt on bad ass. The Xrunner is actually a great platform to build off of for a prerunner, 4.0, strong frame, lightweight, etc.
    http://www.chaosfab.com/88000.html
  13. Dec 24, 2010 at 9:48 PM
    PA Tacoma
    PA Tacoma Member
    Nyles
    East Earl, PA - Tanauan, Philippines - Baghdad, Ir
    05 Access Cab TRD Off Road
    Custom wheels, Haven't had time for anything else
    paxr, have you thought about swapping your truck for a 4X4 Tacoma? I've been thinking of selling my Tacoma for an X.
  14. Dec 24, 2010 at 9:55 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    The frame on the X isn't the same as every other '05+ AC out there?
  15. Dec 24, 2010 at 10:31 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Nope. Pretty close, but it's more rigid with the X brace and the front end is a little different. It doesn't have all the vsc/trac bullshit like the 6 luggers either.
  16. Dec 25, 2010 at 7:42 AM
    paxr
    Camp hill, pa
    06 xrunner
    The frame has the X braces. Thats about the only difference I know of. So what I'm hearing is that a kit for a 5 lug will bolt up. I'll be putting the rear axle under the leafs and then the rear is pretty straight forward, can do block, add a leaf, or maybe try and mod the shackle setup. The front end is really the area where I want to be sure of the fitment before I pull the trigger and order a kit for it.
  17. Dec 25, 2010 at 8:11 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    ^these two, if you have the money, if not there is the regular TC mid travel with UCA's and coilovers or the fatbob's/readylift spacer lifts,
    that is also if the xrunner and base model are the same but i believe they are if base models can ran the sittin sic and djm stuff
    goodluck with your search, if you do end up lifting keep us posted!
  18. Dec 25, 2010 at 8:13 AM
    paxr
    Camp hill, pa
    06 xrunner
    I'm in contact with TC right now and ORW so we'll see what they have to say. I saw the TC mid travel kit with the new UCA and coilovers. That looks like a good option for me. The long travel would be a big hit to my toy fund.
  19. Dec 25, 2010 at 8:18 AM
    113tac
    Stephen
    Northern Virginia
    yeah i think the UCA's are a good option, its definitely better than stock
    check out naked's build he's got a sick truck that has teh mid-travel and LT in the rear, hes taken through some jumps and i believe its fine haha
    here's a link to it http://www.tacomaworld.com/forum/2nd-gen-builds/89530-nakeds-5-lug-off-road.html
