Yellow light things? Where the blinkers are?
Discussion in 'Lighting' started by RJALLDAY702, Sep 13, 2011.
  1. Sep 13, 2011 at 12:20 PM
    RJALLDAY702
    RJALLDAY702 [OP] U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Not quite sure how to word this.. Bare with me.. :p
    I noticed a lot of tacoma's can have the yellow strip of light (the blinker light)
    They can have it stay on, and I thought all tacoma's had this feature, but when i turn my light switch to the middle, only the sides of my headlights turn on..
    whats up with this? is it some kind of bonus feature? day time running lights?
    They say there is no such thing as a stupid question...
  2. Sep 13, 2011 at 12:22 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Daytime Running Lights.
  3. Sep 13, 2011 at 12:22 PM
    neoflex
    neoflex Well-Known Member
    I think what you are referring to is the DRL that some Tacomas were equipped with while other weren't.
  4. Sep 13, 2011 at 12:27 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Thought so! Thanks! :D
  5. Sep 13, 2011 at 12:29 PM
    cc350
    cc350 Retired Member
    An easy wire in. Takes about 10 mins, and 2ft of wire. :)
  6. Sep 13, 2011 at 12:58 PM
    Tacoma Mike
    Southern Maine
    Takes about 5 seconds and a pair of wire cutters to take them out.. Roflmao
    JK..... ;)
  7. Sep 13, 2011 at 1:04 PM
    leveltwo
    leveltwo Well-Known Member
    no issues yet with my '11
  8. Sep 13, 2011 at 1:14 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Go onnnn......
  9. Sep 13, 2011 at 1:18 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
  10. Sep 13, 2011 at 5:27 PM
    cc350
    I jumped them from the side marker lights. So they come on with parking lights. Just jump from marker hot and pop the plug from the turn signal connector push wire in plugs spot with 1/4 wire striped replug test.Lights come on with parking lights and headlights and turn signals work as they did before mod. You'll see it's a high/low bulb.
  11. Sep 14, 2011 at 8:24 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Think you could make a quick schematic for this? I think I follow, and it makes sense.... but would be nice to visually verify what you are saying.
  12. Sep 19, 2011 at 3:39 PM
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
    interested too, that would help a little
  13. Sep 24, 2011 at 1:04 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    i wired mine up this way....so when i turn on my parking lights the blinkers turn on n when i turn on my blinkers to turn the corner lights blink as well :thumbsup:
    http://youtu.be/ousjed3bS74
  14. Sep 24, 2011 at 3:23 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Thats sick!!!
  15. Sep 24, 2011 at 6:20 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    :humble:thank you, thank you lol jk...i like it...i drive like that with my fogs when the sun starts to set then when its dark i just turn on my headlights
  16. Sep 25, 2011 at 5:53 AM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    X3... I think I understand what to do, but would appreciate a quick hand drawn schematic....
  17. Sep 25, 2011 at 6:46 AM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Here's the LINK to the write-up
    It's #45 on the "Cheap/Free Mods" list found here.
    And Schematic, if it links/shows
    http://s82.photobucket.com/albums/j...view&current=SignalsNSideMarkersJungleman.jpg
    EDIT: And if you link all the way to Jungleman's write-up @ ToyotaNation,
    heres the link to Danial Stern's site, he refers to. Good reading about lighting stuff
    http://www.danielsternlighting.com/home.html
    CC
  18. Oct 3, 2011 at 5:22 PM
    cverneau
    Craig
    Cheshire, CT.
    Ok..so I had some time to play around with the wires today....
    I have a 2011 with no DTRL at all. I did the mod that jumps the wire from the side markers. It makes the front blinker lights stay "on" but not ultra bright - so it's using the "low" element in the bulb. They only get brighter with the second "high" element when the turn signal is applied and they then blink (or alternate) from "low" to "high".
    Here's my question:
    When putting the DTRL's in using the relays as Toyota would do, you're obviously not using the third plug on the bulb and because of that, you're not using the "low" element of the bulb. Is this why some people have melting and bubbling lenses - because the relay turns the DTRL's on using the "high" element??
    By jumping the wire, you're utilizing the "low" element (which otherwise will never be used), and even though the bulb gets hot, it will never get as hot a the "high" element being on all the time.
    I also did the side/corner blinker mod as well (exactly as shown in the video above). I like the idea that people more to the sides can see where you'll be turning...
    Before I forget - anyone with a 2011 that wants to do the side/corner blinker mod should note: The wire colors to cut and splice are different than the write-up mentioned here...
  19. Nov 22, 2011 at 12:26 PM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    OK....but if I wanted to utilize BOTH filaments, which wire would I splice into?
  20. Nov 26, 2011 at 4:21 PM
    cverneau
    Craig
    Cheshire, CT.
    You'll never use them both at the same time - The high element is only used with the blinker:
    The DTRL will use the low element of the bulb.
    The blinker will utilize the high element of the bulb.
    When you splice from the side marker wire, you'll plug the new splice into the empty plug on the bulb (there are three - one is empty, one is for the common and one is for the blinker).
    As for the colors of the wires that you'll cut and splice from, It's been a while since I did this and can't remember the colors, but I followed the info I read from this thread and checked th links that others had posted.
