Yet another 5100 question (sorry)
Discussion in '1st Gen. Tacomas (1995-2004)' started by ohdrj1all, Aug 15, 2011.
  1. Aug 15, 2011 at 4:45 PM
    ohdrj1all
    ohdrj1all [OP] Well-Known Member
    AZ
    2003 XtraCab 4x4 SR5 2.7L 5spd
    Hi and thanks in advance... I am trying to level the front of my 03 XtraCab 4x4 2.7L and leave the rear stock height. I have read in several threads on TW (via search) that putting 5100s at all 4 corners will do this (with the fronts on the middle setting)... but when I called DSM the guy there recommended that I go with 5100s on the front (set to middle) and 5125s in the rear. I have also read some guys running the 5125s out back on TW too... so which is it???? I am confused and want to make the correct purchase!!!
    I am not trying to lift it, nor do I plan to in the future, but I would like it leveled. Could someone please tell me definitively (and/or post some pics so I can see for myself) which is the proper set up for me.
    5100s all around
    OR
    5100-Front / 5125-Rear
    Thanks!
  2. Aug 15, 2011 at 4:47 PM
    MedicalTacoma
    MedicalTacoma Well-Known Member
    Florida
    08 Tundra SR5 5.7L V8 4x4
    HID lights, LED dome,map,door panels, Flowmaster exhaust, leveling kit, thats all i had money for right now.
    Actually either would work but some people like the feel of the 5125 rear. Both are good options. I would use either one from what i have read.
  3. Aug 15, 2011 at 4:50 PM
    StatutoryAPE
    StatutoryAPE Well-Known Member
    Joey
    Phoenix,AZ
    2000 Prerunner xtracab
    TRD Headers,CAI, dynomax super turbo, blacked out headlights, Smoked LED tails, Billy 5100 w/OME 881's and 5125's in rear, rear tube bumper, tint 35% front 3 windows & 5% in rear 3. fiberwerx 4.5's
    5100 front and 5125 rear. i got mine from dsm and thats what i ordered. the rear shocks don't lift the rearend at all. only the fronts are adjustable.
    the 5100 rear shocks are too long for stock height in the rear, they are better for lifted rearends, so thats why dsm found out what size 5125s work better for stock height and made a package for them.
  4. Aug 15, 2011 at 6:54 PM
    brandnewcolony
    brandnewcolony Well-Known Member
    Fort Worth, Texas
    2017 Tacoma TRD Pro SW
    ^^^This is correct from what I know
  5. Aug 15, 2011 at 9:49 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  6. Aug 16, 2011 at 7:05 AM
    ohdrj1all
    AZ
    Ok... so 5100F/5125R it is!
    Like I said, that's what DSM told me, but there was a lot of conflicting info in old threads on here. And some very adamant people espousing their viewpoint that 5100s all around was the correct way to go for just leveling and leaving the rear stock height.
    Thanks for those links though... after reading thru all that I can see how it eventually did get resolved by the DSM folks and how those arguing for all 5100s came around. Was a pretty heated debate there for a while, eh? ;)
    Thanks again... will be placing my order today.
  7. Aug 16, 2011 at 10:05 PM
    ohdrj1all
    AZ
    Okay, got another question. I had assumed that since I was buying front shocks (ie, the 5100s) that the factory set up was shocks up front, but I called a local shop to get a quote on installing them and they said the front of my 03 has struts!? Is this correct? And if so, why do people put shocks on as replacements instead of just getting new struts?
    Sorry to show my ignorance here, but I guess I am just confused. Are the 5100s just a direct bolt on, or do I have to do some kind of mod make them fit instead of struts?
    And do I have to buy a set of coils to go up front to run the 5100s since (presumably) when the stock struts come off the coils are attached to them. ???
    Sorry... but I need someone to explain to my ignorant @$$ just what the freaking deal is!!!!!!!!!!! :eek::D
    Thanks!!!!!!!!!!!!!
  8. Aug 16, 2011 at 10:19 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    Technically, struts refer to the front dampers and shocks refer to the rear dampers. Most times people refer to "shocks" as front/rear dampers in a general term.
    To level out your truck, purchase the front 5100 bilstein struts and as directed have your mechanic set it to the middle setting which will level the truck as you wanted. the stock setup is a coil-over setup, meaning the struts is set inside the coil spring in laymen terms. your mechanic will disassemble the coil-over and reassemble it using the new struts. you do not need to purchase new coil springs or do any other mods. it's bascially a strut replacement job. as recommended, the 5125 in the DSM kit will work in the rear.
    hope this helps.
  9. Aug 16, 2011 at 10:25 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    This
    tomato / to mah toe. In the front, theyre struts but people call them shocks all the time. you ordered the right kit, and it's actually really easy to install... So enjoy it when you get it!
  10. Aug 16, 2011 at 11:48 PM
    ohdrj1all
    AZ
    Thanks guys. Order has been placed. 5100F/5125R... got the TW discount too... $295.99 + free shipping! Dang good deal!!!
