W59 transmission, to fix or replace?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kayakingguy, Feb 26, 2015.
  1. Feb 26, 2015 at 8:53 PM
    kayakingguy
    kayakingguy [OP] Ask about my custom truck detailing!
    OutsidaTampa
    Just bought a '96 4 cylinder 2.7 liter... Test drove fine but on the way home after buying I noticed it is not wanting to go into fourth... It goes into 1-3 and 5 fine, but it catches going into 4'th... Not sure how I missed this test driving it! :mad:
    From what I understand the W59 is the transmission in the 2.7 liter 4X4 manual?
    Is it worth having it rebuilt or just better to buy a secondhand one? Unless the issue with 4'th is something that will remain stable?
    are there any other transmissions that will bolt into the 2.7 liters? Anyone had to replace a tranny; what did you use if so?
  2. Feb 27, 2015 at 6:02 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    There's a good chance that your problem is just the shifter bushing and seat, which are really easy fixes. Try that before you go dropping a transmission.
    https://www.marlincrawler.com/transmission/shifter-parts/heavy-duty-seats
    If that doesn't work, then yes - you will have to rebuild or replace. Replacing with a used one is considerably cheaper. If you decide to go that route, I have a working W59 with ~150k miles that I'll give you a really nice deal on if you can get it from me here in NC.
    What I did was buy a used one, put it in, and drive on that for about a year. I took my time rebuilding the original, then swapped that one back in. It's not too hard of a rebuild, but it's pricy even if you do it yourself. You can often find an entire used transmission for less than the cost of a good rebuild kit, and that doesn't include any labor.
  3. Feb 27, 2015 at 6:33 AM
    gearcruncher
    gearcruncher Well-Known Member
    Canadain bumper technician
    Great white North 51.0333° N, 93.8333° W
    2010.TRD.SportDCLB4x4Limited leather package
    TRD Sport Rally -5 speed automatic Limited ,Factory heated leather seats ,chrome package,Super white with front windows tinted to 35 % Dick Cepek DC-2 wheels Summer tires - Good year silent armor P265/65R17 Winter tires - Good year P265/65R17 Ultra Ice studded Illuminated 4x4 switch TRD 3rd brake light cover ($20) TRD seat belt shoulder protectors (5). ($50) TRD ...B pillar emblems ($20) TRD rear slider sticker with devil horns ( $6) TRD summer floor matts ($60) TRD steering wheel emblem ($20) TRD floor pedals .($95) TRD shorty antenna ($14) TRD front Windshield emblems ($17) TRD head pillows .($60) TRD head rest protectors TRD door scuff protection $20 TRD floor matt emblems ($40) TRD tow plug emblem . ($40) TRD cigarette lighter with LED.($35) TRD tissue dispenser ($12) TRD front bezel emblems ($9) TRD door emblems ($6) TRD lanyards($9) TRD lisence plates with TRD bolts($50) TRD fender emblems TRD center caps Part Number:PT904-35070-CC ($80) TRD cd
  4. Feb 27, 2015 at 7:21 AM
    MrRiverMan
    WNC
    Yes, full disclosure is that the one I have for sale has whiny counter shaft bearings. I gather that most of these W59s do - my freshly rebuilt one has also already gotten noticeably louder in the 10,000 miles I've driven it. My old truck was like that too. I guess I'm going to have to get used to the noise if I want to keep driving 2.7s.
    The 4th gear problem on the spare tranny wound up being that the shifter seat was completely gone - must have disintegrated over time.
    So it's a working transmission for a really low price.
    I suspect a seat and bushing will fix the OPs problem as well.
  5. Feb 27, 2015 at 3:57 PM
    kayakingguy
    OutsidaTampa
    I just saw your post here. Sounds like you have some real experience! I noticed today when I shift slowly it is doing well, so it may be a combination of worn clutch and synchros although the bushing sounds like a relatively painless thing to assess...
    Did you in your research look into any other transmissions that would bolt in or fit with minimal effort into your 2.7 besides the W59? You are right regarding cost, btw, it looks like a used one is cheaper than a good rebuild.
  6. Feb 27, 2015 at 4:42 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Yes, but a good rebuild has a warranty and you know where you stand when it's installed.
  7. Feb 27, 2015 at 6:00 PM
    MrRiverMan
    WNC
    I didn't find anything else that bolts right up. I recall that some of the other W series might have worked, but I decided they were probably not strong enough for the use my truck gets.
    I've read that the R series transmissions from the '96-'04 V6 Tacos (and some other Toyotas) will work if you use the bell housing from a 2005-2009 4x2 with 4cylinder. You could probably google that and find some info. I'm not sure a good used R series would be any easier to find than a good used W series.
    If I'd had the money, I would have bought the Marlin rebuilt one. I just didn't have the $1600+ to spend. I've been really happy with the rebuild I ended up with, though.
  8. Feb 27, 2015 at 6:10 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I'd guess syncros from 4th being a 'passing gear'. May just try to change the fluid out and see if it'll help.
  9. Feb 27, 2015 at 6:18 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Had the same issue and it was the shifter bushing. I replaced the bushing and it shifted like a new truck.
  10. Feb 27, 2015 at 6:46 PM
    gearcruncher
    I agree with 68Dave .
    I dunno why the bushing in the shifter gives so much grief but here is a bunch of info that may help . I just copied and pasted from another post for ya !
    Here is the part number to replace the shifter bushing
    Toyota Part no. 33548-60040 . You can also get this bushing from Marlin Crawler
    https://www.marlincrawler.com/transm...y-duty-sockets
    TRD quick shifter review http://www.tacomaworld.com/forum/2nd...questions.html
    TRD short shifter questions http://www.tacomaworld.com/forum/2nd...-opinions.html
    Hurst shifter review /questions http://www.tacomaworld.com/forum/2nd...w-shifter.html
    URD short shifter and review http://www.tacomaworld.com/forum/und...ifter-kit.html
    Sloppy Shifter ? http://www.tacomaworld.com/forum/2nd...d-shifter.html
    and More sloppy shifter info http://www.tacomaworld.com/forum/2nd...d-shifter.html The military should dispose of these things like they did in the past . Sell them to Arnold Swarzenegger
    Broken URD shifter http://www.tacomaworld.com/forum/tec...install-2.html
    EDIT ! one more link for you to look at http://www.tacomaworld.com/forum/te...ation-your-5-speed-transmission-write-up.html
  11. Feb 27, 2015 at 8:28 PM
    Brake Weight
    Hmm. I'll be getting a set of those Marlin bushings soon.
