12-15 climate control in a 05-11 truck wiring guide
Discussion in 'Lighting' started by 3378jakesr5, Jan 20, 2016.
  1. Apr 19, 2020 at 7:35 AM
    #181
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    i just have one spare set, sorry guys!
  2. Apr 19, 2020 at 11:55 AM
    #182
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Now worries! Just to clear, your holding on to that spare or giving it to other member?
  3. Apr 19, 2020 at 11:59 AM
    #183
    cromag27
    phx-ish
    going to @Goosie0080 because he was the first one to ask.
    theolee[QUOTED] likes this.
  4. Apr 19, 2020 at 12:14 PM
    #184
    theolee
    Theo
    SAN DIEGO
    I'll keep searching, Thanks Jacob :thumbsup:
  5. Apr 22, 2020 at 4:16 AM
    #185
    theolee
    Theo
    SAN DIEGO
    Hey @svonavja
    Sorry to bug again but could you direct me to which website you used to order the male and female connectors from? I found a few websites but they come off a bit shady.
    Thanks :thumbsup:
  6. Apr 29, 2020 at 11:20 AM
    #186
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    i have a 2007 tacoma.
    i am about to take this on and id like to verify where the AC wire would go in my new A33 connector. right now the pdf says the GREY AC wire goes to pin 16. Since i have an 07, the AC wire would go to pin 13 instead? thanks for any help TW can provide ;)
    supkillah808 likes this.
  7. May 14, 2020 at 1:15 PM
    #187
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Have you been able to get this to work? I've tried multiple times with mine and nothing. I always had problems with either blowing fuses, ac stayin on but once turned off it would never turn back on, etc. I've been trying to do this swap into my '08
  8. May 18, 2020 at 10:55 PM
    #188
    theolee
    Theo
    SAN DIEGO
    Anyone have an issue with the LEDs that illuminate the rings not lighting up? Everything else is working perfect after the swap. The AC and air circulation lights are working fine. Any insight would be appreciated.
  9. Nov 8, 2020 at 12:12 AM
    #189
    taco_jacko
    taco_jacko Active Member
    Jackson
    BC
    2022 TRD Sport DCLB
    Bilstein 6112 & 1/2” Spacer Bilstein 5160, 2 1/2” AAL & 1/2” block KMC Impact (17x9, -12mm) Toyo Open Country 285/75/17 JBA HC UCA
    Anyone still have a 16P025 NH female connector?
  10. Sep 4, 2021 at 4:52 PM
    #190
    airkewled
    airkewled Well-Known Member
    Kevin
    Moab
    2006 Tacoma DCSB
    PSA
    If you do this, you may need to switch two traces on the hot/cold control, else when you want cold air, you have to put the dial on hot and vice versa.
    Extra details
  11. Jan 10, 2023 at 8:09 AM
    #191
    Awsome57
    Awsome57 Well-Known Member
    Kevin
    did you find the fix to this I am having the same problem
  12. Jan 10, 2023 at 12:27 PM
    #192
    theolee
    Theo
    SAN DIEGO
    Yup! Make sure the harness/terminals are making contact. If I remember correctly, the - or + illumination wire wasn't seated properly.
  13. Mar 26, 2024 at 12:17 PM
    #193
    ZFred1007
    ZFred1007 Active Member
    Looking at tackling this mod. I noticed there are two P/N’s for the HVAC Controls on the 12-15.
    55900-04070 - Glossy Black W/ Bluetooth
    55900-04090 - Matte Black W/O Bluetooth
    I want to make sure that either one of these will wire up without issue if I purchase. Does anyone have insight on this?
    Thanks in advance.
  14. May 2, 2024 at 3:16 PM
    #194
    ZFred1007
    I have enough parts to make 5 more harnesses. Message me if interested.
    ill ay, theolee and Mgscott25 like this.
  15. May 3, 2024 at 1:38 AM
    #195
    theolee
    Theo
    SAN DIEGO
  16. Jun 2, 2024 at 2:54 PM
    #196
    TacoTuesday1
    SD CA
    what's the point of this?
    12-15 black panel seemed to connect directly into my '08.
    But, after that vents don't seem to blow as well as before
  17. Jun 2, 2024 at 9:48 PM
    #197
    theolee
    Theo
    SAN DIEGO
    You put a '12-'14 climate control in your '08 without a harness or soldering and it worked? I really want to see how you did that :)
  18. Jun 3, 2024 at 3:51 AM
    #198
    TacoTuesday1
    SD CA
    yeah I don’t get it either. I expected the plug to be different but for some reason it plugged right up and turned on. It’s like piano black. Said 11-15. Got it off eBay for like $40-50.
  19. Apr 28, 2025 at 6:12 PM
    #199
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    I know this thread is old but thanks to yall I was finally able to do this mod! I’ve been keeping an eye out on a control unit for like 2 years now and someone had on on marketplace at the same time someone else was selling a harness. I had to do it lol just put everything back together and tested her out, it’s good to go! And yes I wanted to stick with grey so I trimmed the faceplate tabs and the 4 screws seem to hold it all down just fine.
    theolee likes this.
  20. Apr 30, 2025 at 12:54 PM
    #200
    theolee
    Theo
    SAN DIEGO
    Looks good and congrats! I've never seen those knobs before, who makes them?
    Watermallon[QUOTED] likes this.
