2005
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wlmuncy, Apr 20, 2010.
  1. Apr 20, 2010 at 6:44 AM
    wlmuncy
    wlmuncy [OP] Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I found a 2005 with 20k miles on it. I know it's the first year of the 2nd generation trucks. Can I get some feedback on issues the 2005 had that were worked out in later model years? Would this be a good truck with the lows miles, or would a 2007-2008 with 40k be better? Thanks everyone.
  2. Apr 20, 2010 at 6:51 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Rear Leaf sag
    Timing chain cover oil leak
    Clock spring (Sr5 airbag)
    check to see if these tsb's have been repaired.
  3. Apr 20, 2010 at 6:52 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Wow. That's low miles!. Definitely run Carfax on that, and a good lookover..Bought mine w/57K miles, no issues..
  4. Apr 20, 2010 at 6:56 AM
    05SuperChrg
    05SuperChrg Well-Known Member
    SF Bay Area
    TRD Supercharger, TRD Air Filter,Rancho 9000's, Old Man,Fumoto Oil Drain Valve,Kenwood Sub, Sony HU,Wet Okole, debadged,satoshi,Slee Sliders
    I recently purchased an 05 with 17k miles and am very happy with it- with the exception of the rear leaf springs, which I am replacing with OME in a month.
  5. Apr 20, 2010 at 7:02 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I got mine at 52k miles. I added an AAL and haven't had any issues.
  6. Apr 20, 2010 at 7:25 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Maybe you should get a newer one. That way you can deal with the failing radios and such. j/k
    There weren't too many "common" problems that you could say an '05 had that others didn't. It's more of a truck-by-truck situation. Some will point out the failing motor mount welds on some early 05's, but I have an early 05 and mine still look perfect. Most common problems with the 05's were not fixed in later years (rear leaf springs, weak tailgate...or did they finally getting around to reinforcing the tailgate?). Anyway, later years have problems that the 05's didn't have. So just look it over like you would any vehicle.
  7. Apr 20, 2010 at 4:17 PM
    wlmuncy
    William
    Knoxville, TN
    The motor mount issues, did those follow on into the 2006 model years or were they only 2005 related complaints?
  8. Apr 20, 2010 at 4:21 PM
    05Moose
    Jim
  9. Apr 20, 2010 at 4:23 PM
    wlmuncy
    William
    Knoxville, TN
    How about the oil chain cover leak, is that an expensive fix?
  10. Apr 20, 2010 at 4:38 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Dealer would probably charge around $1,000 for that cover leak, but that shouldn't be a problem till you get some miles racked up on the truck
    I think someone said around 75,000 miles it was leaking
    I love my 05 Pre-Runner Below are my list of problems:
    NO PROBLEMS!:D
  11. Apr 20, 2010 at 5:11 PM
    toyby4
    toyby4 Well-Known Member
    05 INDIGO INK PEARL TRD Sport
    Black HID Headlights, HID FOGs, Leer Tonneau, Tint, Pioneer NAV, Backup CAM
    Bought my 05 w 92000 miles.... still looks and runs like new!
    :headbang:
  12. Apr 20, 2010 at 5:29 PM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Check for dampness in the carpet and underpad in the driver and passenger side footwell. The first three months of production had issues with the cowl seam leaking. I, of course found this out after I purchased my '05. Other than that, my biggest gripe would be the tailgate.
  13. Apr 20, 2010 at 6:16 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Dealer quoted me $1450. . . So, I proceeded out the front door.
  14. Apr 20, 2010 at 6:54 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I was a new 2005 owner, traded to it with my '01 (a perfect truck), and traded the '05 for my '10 last December.
    Issues in the 2005 were:
    1) the soft rear suspension (bottomed out with rear passengers or cargo in the bed going over bumps at speed), they wouldn't fix and I finally had air bags installed...
    2) intermittent brake noise for a few thousand miles they couldn't solve, that disappeared with new pads installed...
    3) ABS brake system noise and lack of stopping truck well in wet or off road situations, they said was 'normal'...
    4) air bag warning light came on, required a $300 wire harness replacement, out of warantee.
    However, with over 102,000 miles put on, in less than 5 years... the truck otherwise performed so well, I got a new one... and I like it a whole lot better, so far! The new traction controls are dynomite!
  15. Apr 21, 2010 at 7:00 AM
    05Moose
    Jim
    And what David K said about the newer vehicles is a big plus. All the traction control would be good to have...
    As far as oil chain cover, I've got 90K and no leak. I do have, however, the front diff output bearing problem. It could be that most of the trucks (even newer ones) have the problem but you won't know until you raise the front end an inch. Could be they'll all have this problem with time/mileage though. I know it's not limited to the any specific year because people with less than 30K miles are having this problem.
  16. Apr 21, 2010 at 9:59 PM
    XC4ME
    XC4ME Well-Known Member
    Litchfield Park, Arizona
    05 Tacoma DC TRD Sport
    I bought my '05 just over a year ago with 64,000 miles on it. It's got 78,000 on it now. Not one single problem, love it! :)
  17. Apr 22, 2010 at 5:12 AM
    wlmuncy
    William
    Knoxville, TN
    Thanks guys for all the feedback. Carmax are tools and want 1 grand more than book value and $ 500 to ship it from Las Vegas to Knoxville. So I have moved on. The truck looks good though. Right now I am negotiating on a 2007 with 34k and a 2006 with 22k, both are manuals. I'll let everyone know what I get and update my profile when the deal is done.
    Here is the 2007 I am negotiating for: http://www.youtube.com/watch?v=6C6ZFbJAAPU
  18. Apr 22, 2010 at 5:13 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Good luck with the purchase!
  19. Apr 22, 2010 at 2:07 PM
    wlmuncy
    William
    Knoxville, TN
    Pending test drive I am getting the 2007. I will be going to drive and pick-up on Saturday.
  20. Apr 22, 2010 at 4:17 PM
    David K
    No A-TRAC in 2007... Think about it! ;)
