4LO-Trac & ABS Kill Switch - Why/Why Not?
Discussion in 'Technical Chat' started by Benson X, Jan 10, 2013.
  1. Apr 27, 2014 at 5:22 PM
    #201
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    so i read several pages and just wanted to confirm that this abs mod will worl even without 4x4. I have an 09 Sport 2wd with auto LSD. Just looking for a simple abs kill since i dont have a locker or anything else. Ill check later for that small green wire but wanted to make sure that 4x4 and the ywm is not required for this abs kill
  2. Sep 2, 2014 at 5:58 PM
    #202
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
  3. Oct 9, 2014 at 9:42 PM
    #203
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    The yellow wire mod wouldn't work on a 2005 sr5 4x4 with open diffs, right?
  4. Oct 10, 2014 at 8:26 AM
    #204
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Right, it is to trick the truck's computer into thinking it is in H4 when it really is in L4. That's because in H4, all 2009+ Tacomas (and a few earlier special order models) have TRAC (Traction Control, an electronic/ ABS limited slip system).
    In L4, only the Off Road TRD has traction systems (A-TRAC and Locker). This mod gives all non Off Road Tacomas some traction control in low range.
    Traction control stops (reduces) free spinning of a tire so that some energy goes to the tire with good traction.
  5. Oct 11, 2014 at 11:47 AM
    #205
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    So I've seen a couple guides like this for different models, but I can't find one for a 2008 Sport 6spd equipped only with ABS. I have none of the other stuff. Think this guide could work, even though I don't have Trac?
  6. Nov 25, 2014 at 9:35 AM
    #206
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Is the ABS override different for 2012+ trucks? When I went to cut the light green wire, it wasn't there. :confused:
  7. Nov 25, 2014 at 11:35 AM
    #207
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Could be different, but there are few guys that posted in this thread that it worked on 12+ Sports.
    This guy had a different harness, but the same Green wire:
    http://www.tacomaworld.com/forum/te...bs-kill-switch-why-why-not-9.html#post8165525
    This guy has a 2012 Sport and said it worked for him. Maybe PM him to see what he did or if he has pics:
    http://www.tacomaworld.com/forum/te...bs-kill-switch-why-why-not-4.html#post7393826
  8. Dec 15, 2014 at 10:42 AM
    #208
    dcvt16
    dcvt16 Well-Known Member
    Ehren
    SCV, CA
    SOLD =( MGM Supercharged long travel 5lug
    Total Chaos 5 lug long travel kit, Fox coilovers. Mcneil fiberglass. Defined engineering sua, 14 in kings, Defined shock hoops rear. Weathertech digital liners and vent visors. Paint match grille and added fogs. 4.56 gears, detriot truetrac LSD (gear type), LCE header, URD 2TR supercharger.
    Thanks for the write up.
    Wanted to note that the green wire mod works on my 2012 4cyl 5 lug 2wd. Green wire was there and turns on/off all the computer controlled aids.
  9. Dec 15, 2014 at 3:07 PM
    #209
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks for posting your results!
    Since there are so many versions/configurations of these trucks, it's good to know which ones this Mod will work for (and which ones it won't). :cheers:
  10. Dec 15, 2014 at 5:53 PM
    #210
    dcvt16
    Ehren
    SCV, CA
    Absolutely. Theres was no info that i could find on the five lug.
  11. Dec 18, 2014 at 9:12 PM
    #211
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    So I read the entire thread but did not see anyone with a similar rig. I have an 06 Sr5 with 4wd...none of the other fancy traction options you guys seem to have (I don't even have power windows or door locks) manual transmission.
    I would like to be able to turn off my abs though....any other threads that cover this package?
  12. Dec 19, 2014 at 6:58 AM
    #212
    BradyT88
    BradyT88 Well-Known Member
    This one should work for you and all 2005-2008's.
    http://www.tacomaworld.com/forum/2n...easy-caveman-can-do-abs-disable-mod-pics.html
  13. Dec 19, 2014 at 7:12 AM
    #213
    replica9000
    2019 T4R ORP
  14. Jan 9, 2015 at 4:24 PM
    #214
    nxrunner
    nxrunner Well-Known Member
    Nick
    Lafayette La.
    2015 Tacoma Double Cab 6 Speed
    Subbed. Thanks Milo!!
  15. Jan 14, 2015 at 5:58 PM
    #215
    nxrunner
    Nick
    Lafayette La.
    Ok I need some input. Need to know if this will work on my truck.
    I have a 2015 V6 6spd 4x4. No TRD Offroad, no locker, Not sure if its VSC equipped, not sure if its TRAC equipped?
    Please advise.
  16. Jan 14, 2015 at 6:10 PM
    #216
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Are you trying to do the ABS kill or Yellow Wire Mod?
  17. Jan 14, 2015 at 6:25 PM
    #217
    nxrunner
    Nick
    Lafayette La.
    Im trying to get the most traction out of my truck. Is it necessary to Kill the ABS?
  18. Feb 7, 2015 at 6:11 PM
    #218
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
  19. Mar 28, 2015 at 1:56 PM
    #219
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    Thanks for the detailed write up. I finally did the yellow wire mod on mine today
  20. Mar 28, 2015 at 2:02 PM
    #220
    replica9000
    2019 T4R ORP
    Does doing the yellow wire mod also make engaging and disengaging 4-lo less of a pita?
