4LO-Trac & ABS Kill Switch - Why/Why Not?
Discussion in 'Technical Chat' started by Benson X, Jan 10, 2013.
  1. Dec 4, 2013 at 7:03 PM
    #101
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
  2. Dec 4, 2013 at 7:07 PM
    #102
    BradyT88
    BradyT88 Well-Known Member
    Yep! That's the mod I did.
    Since shifting into 4Hi disables VSC I figured I could do that mod and shift into 4Hi for driving around town (but thanks to the mod I am really in 2wd, so I don't damage the 4wd system on pavement) and that would let me keep Trac (as an LSD) while disabling the throttle cutoff. Well it worked even better than I thought. I don't have to flip the selector to 4wd. I can just leave it in 2wd and flip the 2Lo mod switch and VSC turns off.
    It's certainly not as good as a real LSD, but it's better than being open.
  3. Dec 4, 2013 at 7:10 PM
    #103
    Broseph Stalin
    Broseph Stalin Well-Known Member
    Justin
    Santa Barbara
    '10 white dbl cab LB trd sport
    15% tint , Bak Flip G2 tonneau cover, poplock WeatherTech mats, FX-R retrofit, BHLM, eyelids, smoke Lamin-X, daystar leveling kit, studded snow tires and a shitload of sand bags
    Hmm o.k., Now i am really not sure what to do because between you and Benson X i'm getting conflicting opinions...
  4. Dec 4, 2013 at 7:24 PM
    #104
    BradyT88
    Do this mod and give it a try. It is probably what you are looking for really. Also it's a lot easier to do than the 2Lo mod and we don't even know if you can do the 2Lo mod or not since you aren't a 4x4.
  5. Dec 4, 2013 at 7:32 PM
    #105
    Broseph Stalin
    Justin
    Santa Barbara
    for sure, guess ill just snip the wire, go for a drive and see how it reacts. thanks for the help guys!
  6. Dec 5, 2013 at 6:10 PM
    #106
    Broseph Stalin
    Justin
    Santa Barbara
    so i just got done with the mod, flippped the switch and had NO ABS or VSC lights pop up on my dash. I even pulled off the switch to break the circuit and NO lights popped up so i know the switch is good. I have the exact same wiring harness too.any ideas gentleman??
    :help:
  7. Dec 5, 2013 at 6:18 PM
    #107
    BradyT88
    Have you like triple checked that you got the right wire harness and wire? You just did the ABS kill right? and not the Yellow wire?
  8. Dec 5, 2013 at 6:21 PM
    #108
    Broseph Stalin
    Justin
    Santa Barbara
    Definitely have the right wire harness and definitely the correct wire. Do you know of anywhere to get a wiring diagram for Prerunners?
  9. Dec 5, 2013 at 6:24 PM
    #109
    BradyT88
    I can't imagine the wiring is any different for you. I wouldn't be surprised if you have all of the 4wd wiring harnesses in your rig, just missing the computer, switch and of course the Tcase, and front diff. If you have the right wire it should work since all you have to do is cut it. For my mod I have to ground it so it would be a little different.
  10. Dec 5, 2013 at 6:38 PM
    #110
    Broseph Stalin
    Justin
    Santa Barbara
    i definitely do NOT have crom's wiring harness, just checked
    the only 2 thing's i can think of is that they use a different wire for ABS on 2 wheel drives
    OR
    my crimestopper alarm remote start system (installed in the same region) is messing it up from happening but i feel like thats a long shot
  11. Dec 5, 2013 at 7:00 PM
    #111
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Weird, I would suggest checking the switch, but since it was removed completely that eliminates it as a cause. Did any other lights on the dash come one?
    I went through a couple fuses before figuring out that I did not need to ground it.
    This guy's 2WD: http://www.tacomaworld.com/forum/2n...comas-w-o-vsc-locking-diff-write-up-pics.html
    Here's another thread: http://www.tacomaworld.com/forum/2nd-gen-tacomas/4838-cheap-free-mods-3.html#post45912 which worked for THIS guy (Prerunner)
    My guess is you need to use a different ECU wire, or you need to ground it. The other solution is to pull your ABS fuse when you don't want it on, and continue to use the Burn Rubber button when you don't want VSC on. Sorry I couldn't more help man...good luck!
    :cheers:
  12. Dec 5, 2013 at 8:22 PM
    #112
    Broseph Stalin
    Justin
    Santa Barbara
    no other lights came on, the fuses are good
    checked those other write ups and they're harnesses dont match mine, think ill have to resort to toyota nation :turtleride: :spy:
  13. Dec 5, 2013 at 8:30 PM
    #113
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    damn dude. I guess we will just blame Toyota for making 38 different versions of the same truck...
    Good luck bro, I will troll around to try to find a solution too.
    Just to confirm, you have a '10 TRD Sport DC/LB Prerunner, and you want to be able to disable ABS and VSC (to disable the throttle limiter) but still keep the eLSD function (TRAC)?
    EDIT: have you checked this thread too? http://www.tacomaworld.com/forum/2n...easy-caveman-can-do-abs-disable-mod-pics.html (he doesn't have VSC, but it might work)
  14. Dec 5, 2013 at 8:51 PM
    #114
    Broseph Stalin
    Justin
    Santa Barbara
    yea thats what i have,thanks for the help!
    i dont want any of those nonsense features, my competence and studded tires are all i need to get me around, don need no stinkin systems to drive for me lol. Free spin for life!
  15. Dec 5, 2013 at 9:08 PM
    #115
    Broseph Stalin
    Justin
    Santa Barbara
    btw what the hell is a locker? after 2 days of searching i figured i'd find the answer but cant find the definition, only uses...everywhere!
  16. Dec 5, 2013 at 9:32 PM
    #116
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    In the most basic terms, it locks the differential so both wheels have equal power and spin simultaneously no matter what. If you really want to dig into it, there's a TON of good info. out there.
    Here are a few good articles:
    http://www.offroaders.com/tech/limited-slip-lockers-differentials.htm
    http://www.offroaders.com/tech/locking-differential.htm
    http://www.4x4wire.com/toyota/tech/electric_locker/
  17. Dec 5, 2013 at 9:55 PM
    #117
    Broseph Stalin
    Justin
    Santa Barbara
    so if i understand the second article correctly, by having the LSD button i have a selectable locker?
  18. Dec 5, 2013 at 10:04 PM
    #118
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Not quite. The LSD turns your open differential into a simulated LSD (Limited Slip Differential) to send more power to the wheel that is losing traction. The first article is a better explanation of the various types of differentials in general.
  19. Dec 5, 2013 at 10:48 PM
    #119
    Broseph Stalin
    Justin
    Santa Barbara
    gotcha, so i should be looking for a write up thats meant for no locker
  20. Dec 5, 2013 at 10:55 PM
    #120
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Yup. And that's why I'm confused as to why this mod doesn't work on your truck, since its essentially the same as mine, just 2wd.
