Advice on Regular Maintenance and Mods
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coachk13, Dec 12, 2018.
  1. Dec 12, 2018 at 6:55 PM
    coachk13
    coachk13 [OP] Member
    Tim
    New Orleans, LA
    2007 Access Cab 4x4 V6
    I have a 2007 TRD Off-Road 4x4 Access Cab with 160k miles on it that I’d like to start modifying a little bit. I’ve had it for about 2.5 years (got it w/ 113k miles) and so far have added the following: a used A.R.E. shell (which needs a little love), Yakima crossbars on the shell, a cheap plywood/2x10 sleeping platform, and BF Goodrich KO2s. About the only maintenance myself I’ve done is regular oil changes, so I’d first like to know what do all of you recommend in terms of regular maintenance that’s easy enough for a noob to get the hang of? Second, I’d like to add a suspension lift and would like recommendations on how go to about doing so… You guys are badasses. Thanks!
  2. Dec 12, 2018 at 7:00 PM
    tcjacado
    tcjacado Well-Known Member
    Change front and rear diff fluid
    Clean maf and throttle body
    Alexely999, Bishop84 and coachk13[OP] like this.
  3. Dec 12, 2018 at 10:42 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Do ATF drain/refill, or flush.
    Brake fluid flush
    Power steering flush
    Check idler pulley bearings
    Check serpentine belt and radiator hoses
    Consider front brake upgrade to 14WA calipers, and matching rotors/brakes
    Consider installing oil catch can
    The Search box can be your friend ...
    https://www.tacomaworld.com/threads/tacoma-brakes-swaps-and-tech.468271/
    https://www.tacomaworld.com/threads/oil-catch-can-install-guide.231227/
    https://www.tacomaworld.com/threads/cheap-free-mods.4838/#post-45403
    coachk13[OP] likes this.
  4. Dec 13, 2018 at 5:25 AM
    coachk13
    Tim
    New Orleans, LA
    I've bookmarked a number of threads already and while the search feature is definitely handy, there's almost too much information to sift through at times. Thanks for the info!
  5. Dec 13, 2018 at 5:28 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    I thought ATF fluid was lifetime? I've got a manual but I seem to remember hearing that.
  6. Dec 13, 2018 at 8:22 AM
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    Grease your drive shafts, front & rear universal joints!!! All 5 of them..
  7. Dec 14, 2018 at 12:26 AM
    Chuy
    Lakeside, CA
    Silver Taco
    ATF is not lifetime. The fluid turns dark as it accumulates contaminates. Even Toyota recommends flushing ATF at 60K if vehicle meets severe service definition. That said - there comes a point when changing the ATF in a very dirty and neglected transmission can cause more harm than good because removing the suspended particles/contaminants will cause the transmission to slip.
    Here is a good video from Chris Fix. After the first minute, skip to minute 5.
    https://www.youtube.com/watch?v=o690DovjDAc
  8. Dec 14, 2018 at 5:46 AM
    BizzyB726
    BizzyB726 Well-Known Member
    Brandon
    New Jersey
    2012 Black TRD TX Baja
    I like this guy. Good video. Very thorough explanation. Now its time to get lost in his other videos. Thanks
  9. Dec 14, 2018 at 6:12 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Suspension depends on your budget an use, If you have thrle funds coilovers are the way to go, but a old man emu setup is great an toytec makes some solid stuff also.
    Wont input for general upkeep all great advice there.
  10. Dec 14, 2018 at 6:29 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Going to ask Santa for my truck to magically have a dipstick like that video. Would be nice!
  11. Dec 14, 2018 at 6:42 AM
    JdevTac
    JdevTac Bawnjourno
    Josh
    GA/WA
    2nd gen
    At one point in time Toyota said lifetime then they changed it to like 100k then dropped it to 60k. So even your service manual might go with the old recommendation. But idk if it applies same to manual vs auto.
  12. Dec 14, 2018 at 7:01 AM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    Speaking of that, I've wondered for a while (even though I've never taken any action on it) if it would be possible to "plumb" up your own top-side fill tube and find/make a dipstick the appropriate length. I understand (I think I understand lol) that the fluid goes to the top of the original fill hole, so I was kind of thinking a long sweep 90° fitting (or maybe a couple 45's even to ease the turn for the dipstick) with the proper thread to replace the fill plug, then some other fittings and supports to go on up top-side. Thoughts? Possible? Possible but difficult? Near Impossible? Just seems like it'd be handier but (full disclosure) I haven't messed with the tranny at all yet, so the way it is now might be easy as pie, for all I know.
  13. Dec 14, 2018 at 7:06 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    You are well over due for a transmission flush.
    I would consult the service manual and do everything you haven’t done since ownership.
    At this point youve reached the service point for everything. You kind of reached that when you bought it let alone now.
  14. Dec 23, 2018 at 11:53 PM
    DanielCarter
    DanielCarter New Member
    Daniel
    Yeah very true!!
