Anytime Front and Rear Camera Mod
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Logistics91, Apr 3, 2018.
  1. Jul 15, 2018 at 5:37 PM
    #601
    Slim_shadowz
    Slim_shadowz Well-Known Member
    17 Sport DCLB MGM 4x2
    Okay I guess I'm that one guy who can screw up the simplest task. I tried installing today and camera didn't work. I am using a DPDT switch. Started off in drive, switched I to on which is front camera nothing. Switched to II on for rear view nothing. Turned the switched off then shifted the car to reverse. It took a while for the car to get into gear. Once in gear I hear a pop and now the head unit does not turn on. Reverse lights do not come on also. I checked the fuse box in the engine bay and all fuses are intact. For the interior ground I used the ground point near the passenger glove box when the head unit was popped out.
    So now the head unit does not turn on what so ever nor does the reverse light. Any ideas on how to.solve?
  2. Jul 15, 2018 at 6:05 PM
    #602
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    Ouch! :eek:
    I can try to help if I saw pictures of what your wiring looks like. Try uploading pictures of the back of the head unit connections, relay connections and DPDT switch connections.
  3. Jul 15, 2018 at 6:10 PM
    #603
    Slim_shadowz
    I'll have to upload it another day. I attempted to install it at my brothers place on a time crunch. So I learned my lesson trying to rush things. I will get pictures uploaded tomorrow or the following day.
  4. Jul 15, 2018 at 11:45 PM
    #604
    Catatonic636
    Catatonic636 New Member
    James
    2018 TRD OR
    Waiting up on this as well!
  5. Jul 16, 2018 at 1:08 AM
    #605
    Slim_shadowz
    After getting support from JJ, I found that the ecu-acc fuse was blown. Replaced it, and everything is working back to normal. Next part is dissecting the cables and see what I did wrong.
    payrow likes this.
  6. Jul 16, 2018 at 1:46 AM
    #606
    kwlewis55
    kwlewis55 Active Member
    Kevin
    2017 Tacoma Off-road
    Grill Light bar
    im about ready to buy one also when you get product in. please and thank you.
  7. Jul 19, 2018 at 1:38 PM
    #607
    Baronmutatis
    Baronmutatis Active Member
    sanford
    2018 Tacoma Double Cab
    I want a dual set up with a/v. also, is there any way to add a dvr to keep the cameras recording to a loop even when not being displayed on the screen? love how everyone in russia has cams recording all the time :)
  8. Jul 19, 2018 at 1:57 PM
    #608
    360joules
    360joules FWC Stalker
    Troy
    Portland Oregon
    SOLD
    Gone. Thanks
  9. Jul 19, 2018 at 3:08 PM
    #609
    Colorado Crawler
    Colorado Crawler Well-Known Member
    2017 Black Tacoma TRD Off-Road
  10. Jul 19, 2018 at 3:37 PM
    #610
    360joules
    Troy
    Portland Oregon
    SOLD
    I bought this set from the OP without his switches and bought the three way from air on board.
    Still available!
  11. Jul 19, 2018 at 3:57 PM
    #611
    YachterSteve
    YachterSteve Well-Known Member
    Multiple Time Zones
    2017 white Tacoma Limited
    TRD exhaust, CA intake, TRD skid plate. ARB lockers front and back, toytec shocks front and rear, factory Bed liner, weather tech floor mats front and rear, interior led lights and tag lights,SSO front bumper with led light and remote winch, old man emu back leaf springs, Lasfit led low beams and fogs
    I already have the rear cam......do I need the anytime font and rear or just the front?
  12. Jul 19, 2018 at 4:47 PM
    #612
    360joules
    Troy
    Portland Oregon
    SOLD
    I have no idea. I haven’t looked at the kit too closely.
  13. Jul 19, 2018 at 4:56 PM
    #613
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    Your not the only one. Mine worked fine after initial install then the morning on way to work, all center control switches went out, window switches and headlights went out. Uninstalled kit, Checked all fuses and it was the ECU fuse too. Replaced it and everything seems back to normal too. I’m an idiot when it comes to electrical mods so I’m not going try again. Kit was nice though.
  14. Jul 19, 2018 at 9:04 PM
    #614
    Slim_shadowz
    Glad I'm not alone. I found out what I did wrong with the help of JJ. I had my front cam wire in the wrong location of the diode. Going to attempt reinstall this weekend or so. Hoping that it goes smooth.
    When I blew the ecu-acc fuse, I also got a check engine light for p0750. Every time I shifted into reverse and gave it a little throttle it felt like I was getting rear ended. Once I replaced the fuse. Everything returned back to normal by the following day. Crazy how one fuse could do so much damage
    orangeracer[QUOTED] likes this.
  15. Jul 20, 2018 at 10:55 AM
    #615
    COSD
    COSD Well-Known Member
    Denver Metro
    2017 MGM DCSB OR
    @Logistics91 will you please reply to my PM. I still haven't received my cameras and it's been since July 6th.
  16. Jul 20, 2018 at 1:05 PM
    #616
    orangeracer
    I installed everything as directed but I guess the back of the switch I used needed to be shielded he said and I grounded the kit to a bolt in the dash which I found after I shouldn't have done. I'm not electrical expert and didn't know that so lesson learned. And your so right about how one small fuse effects so many parts of the truck. I'm now carrying spare fuses and a circuit tester in my truck!
  17. Jul 20, 2018 at 7:03 PM
    #617
    DrWeld
    DrWeld Well-Known Member
    Southern CA
    '18 Cement Off Road
    2” Bilstein shock lift in front
    Can someone that has installed this guys mod help us out with a real good how-to on the install. I have it but after reading several of the posts I’m real hesitant to install this without a real good instructions instructions or even a video. My biggest concern is what wires to tap into. Thanks whoever.
  18. Jul 21, 2018 at 12:32 PM
    #618
    YachterSteve
    Multiple Time Zones
    PM’d please respond thanks
  19. Jul 21, 2018 at 12:56 PM
    #619
    Colorado_Taco17
    Colorado_Taco17 Well-Known Member
    Jake
    Denver, CO
    2017 Tacoma TRD Off-Road
    CBI bumper/skids, BAMF sliders, Bilstein 5100s & 5160s
    Dang, I was looking into this kit a couple weeks ago and went to try to buy today and got slapped with the "No longer available" message. Time to go wash my truck with my tears
    GoodOlBoy likes this.
  20. Jul 21, 2018 at 1:14 PM
    #620
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    Wonder if this not being available has anything to do with the PM that I received from someone on here saying that the OP stole his product? PM is below:
    JJ Johnson (trdmod.com) stole my design, my intellectual property and sell it without my permission. My Attorney is ready to take him to the court. He has been warned and under monitor of my attorney.
    If you feel you can DIY then here is my schematic that I posted for our members to DIY...
    If you want to buy it then here is the link from me.
    Regards,
    Hoangde
    CMD-KY and DrWeld like this.
