Auxiliary switch Wiring and switches.
Discussion in 'Lighting' started by Lay_brandon, Dec 25, 2019.
  1. Dec 25, 2019 at 5:24 PM
    Lay_brandon
    Lay_brandon [OP] New Member
    2017 TRD Off-Road CCLB
    I'm looking to put a triple rocker switch panel in on the right side of the dash where the existing control panel for the rear slider window is. I'd like to have a kill switch for my led bed lights, front lower grill light bar, and LED rock lights. I was wondering for those of you that have something similar, will I need a separate fuse panel for these accessories? and how would I go about wiring them all?
  2. Dec 25, 2019 at 5:27 PM
    Shellshock
    Iowa
    I put in a switch pro. Super clean install and makes it very easy to add accessories. I’ve got it keyed off ignition so everything turns off when I turn off the truck.
  3. Dec 25, 2019 at 6:48 PM
    Lay_brandon
    that looks like a sweet setup, anything in the sub 500 dollar category though .
  4. Dec 27, 2019 at 12:22 AM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Some links of interest:
    https://www.tacomaworld.com/threads/show-off-your-aux-fuse-panels.308677/
    https://www.tacomaworld.com/threads/8-gang-switch-panel-auxbeam-amazon.641431/
    I just ran this 9-conductor 18-ga stranded copper wire through the firewall from inside the dash to an aux fuse box. I'm just adding a couple OEM switches to the dash to keep things looking factory but figured it would be useful to have a surplus of channels ready to address as necessary:
    https://www.amazon.com/gp/product/B01LXI9LBI/
