Best method for removing scratches after going thru thick trails
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sternum Overlanding, Mar 23, 2019.
  1. Mar 24, 2019 at 7:12 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Congrats on using your truck .
    JCOOR likes this.
  2. Mar 24, 2019 at 7:12 AM
    charles.headlee
    charles.headlee Well-Known Member
    East TN
    Wait. For scratches that are into the clear but not thru, heat will heal them out a bit. No sense in rubbing off clear where you don't have to. A light heat gunning might help if you live in cold climates, but a black truck in the sun should do it on its own.
    After two weeks decide if you want to rub / buff / seal / wax. Chances are you'll have less to do.
  3. Mar 24, 2019 at 7:13 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  4. Mar 24, 2019 at 7:38 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Meguiars scratch x followed by their ultimate polish if you cannot feel the scratch with your fingernail.
    Get some buff wheels that fit in your drill off ebay.
  5. Apr 3, 2019 at 12:37 AM
    Mcsosgt110
    Mcsosgt110 Well-Known Member
    Northern California
    2016 Trd offroad
    In the works
    Have had the same issue for years and other trucks I have owned. Last 2 were black. Depends how handy you want to be. I purchased a orbital polisher/buffer
    Groits is the brand. I use three different polishing compounds , 1,2 then #3, different color foam pads, depends on the #compound then a finishing wax. All depends how deep the scratches are. You will remove approx 90 percent plus . Takes time. No swirls either. Invest 100.00-200.00 and it will last a long time. You will pay that just to have a pro do it. Good luck if you go that route. You wont regret it.
    na8rboy likes this.
