Bilstein 5100 HARSH ride, Advice?
Discussion in 'Suspension' started by CSanders, Jun 18, 2012.
  1. Jun 18, 2012 at 8:49 PM
    CSanders
    CSanders [OP] Member
    Craig
    Pomona CA
    07 PreRunner
    Bilstein 5100, Hella 500's,
    I just installed my new Bilstein 5100 shocks at the second to tallest setting, got the truck aligned and the truck rides like a damn pogo stick! I know there are more likely than not a million threads about this but I want a for sure answer for my problem and questions, and I am too frustrated at the moment. Thank you for bearing with me and my lack of patience and time due to way too many summer school units...
    I am assuming I need to get new springs and I am wanting to do this within the week only a few problems...
    Toytec is on backorder for the Eibach springs
    Will the OME 884 springs give me the same lift I am at now while moving the clip in the 5100 to the "stock" height? (approx. 1 inch higher than rear)
    Pro's and Con's of the OME vs Eibach?
    Are there any other spring manufacturers that make a similar product to the OME 884 or Eibach/Toytec front lift springs?
    Again thank you for bearing with me I am doing a lot of back and forth driving on the 91 and 10 freeways and it just about shook me to death.
  2. Jun 18, 2012 at 8:57 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
  3. Jun 18, 2012 at 8:59 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    884's
  4. Jun 18, 2012 at 9:32 PM
    CSanders
    Craig
    Pomona CA
    07 PreRunner
    Thank you guys! Now that I have had some time to cool off does anyone know any other places to buy the Eibach springs, or OME springs preferably a company that works with TW?
  5. Jun 18, 2012 at 10:01 PM
    senor taco
    Monterey Bay, Ca
    Toytec lifts
  6. Jun 18, 2012 at 10:35 PM
    winL
    winL Well-Known Member
    Bay Area, CA
    PreRunner
    Leer 100R Cap, OEM Hood Protector, Bilstein 5100's @0, Wheeler's 3leaf AAL no TSB, Replaced oem OL, OME 885, Pioneer AVIC-D2
    You do lose some travel by setting it on the second to highest setting. I went with 885's and set at 0. A "little" hard in the beginning, but after 2000miles and nicely broken in and everything settled out, rides really well. Level it out in the rear too, I had an issue with the rear and only had the fronts on with a bro lean for a few days. Disgusting ride to say the least and lost 3mpg due to horrible drag with that bro lean. After leveling out the rear, everything rides great, no mpg issues. Wait after 2k and you're golden
  7. Jun 18, 2012 at 10:38 PM
    winL
    Bay Area, CA
    PreRunner
    Just to answer your q, I didn't measure the ride height afterwards, but since i didn't have TSB in the rear, I added a wheeler's 3leaf AAL along with one more AAL... replaced the factory overload. 6leafs total, from what my eye can see, levels out Perfectly. Rides great. No UCA issues, you will see that the ride height will lower a bit after 1k miles. I'll estimate that I got 2.75" give or take out of it.
  8. Jun 19, 2012 at 12:19 AM
    CSanders
    Craig
    Pomona CA
    07 PreRunner
    You guys are life savers! The next Question would be 884 or 885 seeing that I drive road 99% of the time now unless I am taking my dirtbike down the dirt road and my truck is stock other than the 2 hella 500s which add basically no weight would I want the light or medium springs?
    Ya the 91 still isn't much better I noticed that on my way to school when I hit Van Buren at faster speeds the ride was a bit better but still crap compared to what it should be.
  9. Jun 19, 2012 at 4:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    884's and 885's are made from the same coil (same spring rate) so it depends on how much lift you want.
  10. Jun 19, 2012 at 9:30 AM
    winL
    Bay Area, CA
    PreRunner
    the lift in the front would truly depend on if you're going to mess with the rear leaf. If you're just keeping the stock leafs, just go with 884. but, since i had no choice but to replace my leafs due to a crack in my second leaf (luckily it didn't crack through), the extra height from the new rear setup required me to go 885's.
  11. Jun 19, 2012 at 10:35 AM
    CSanders
    Craig
    Pomona CA
    07 PreRunner
    Perfect, Thank you! I have pictures but I cant figure out how to get them on here while I sit in jury duty :bored:
  12. Jun 19, 2012 at 12:40 PM
    winL
    Bay Area, CA
    PreRunner
    Nice, I'll try to get my pics one soon too since I just got mine done a month ago. Heard weather in LA this year hasn't been all that nice... trying to make a weekend trip out of it next week. Good luck on your setup. You'll enjoy the ride for sure.
  13. Jun 19, 2012 at 12:59 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    New shocks should get rid of pogo effect. Would like to see pics of the spring seat. How much lift do you think you got out of it?
  14. Jun 19, 2012 at 1:05 PM
    Pugga
    Massachusetts
    He just put new 5100's on the truck :confused:
    Assuming the coil seats are installed correctly, I'm guessing you meant new coils?
  15. Jun 19, 2012 at 1:19 PM
    CSanders
    Craig
    Pomona CA
    07 PreRunner
    Well i currently sit 1 inch higher in the front that in the rear. Im guessing around 2 inches not sure. Made the mistake of not measuring before installing the "lift"
  16. Jun 20, 2012 at 4:58 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    We need pictures of the shocks bottom spring perch to verify the way it was installed.
    The spring seat/perch can be flipped over and installed incorrectly. When this happens it adds way to much pre load, thus harsh ride.
    Also what model truck is yours, trd off road, sport, SR5?
  17. Jun 20, 2012 at 5:07 PM
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    Looks like that was the issue, the spring perch was installed up side down.
    http://www.tacomaworld.com/forum/su...your-5100-shocks-stock-coils.html#post5266961
  18. Jun 21, 2012 at 9:03 AM
    CSanders
    Craig
    Pomona CA
    07 PreRunner
    Thanks Jones, thought I had posted up here that I found the problem and fixed it. Ride is amazing now!
  19. Sep 24, 2012 at 6:00 PM
    JTRD12
    JTRD12 Well-Known Member
    AL
    08 TACOMA TRD DC
    BBS Wheels, bull bar, toolbox, vent visors, and that's bout it for now.
    Is your truck a TRD offroad? I am thinking about doing the same setup and am trying to figure out if it improves ride quality or makes it too stiff on the offroad edition. Offroad coils are stiffer than the TRD sport edition and it seems hard to find many results of the 5100s on the TRD offroad. Wonder if on top of coil spacers would be better for a slight lift in the front since they dont pre-load the spring like the 5100s do? Anyone have some good input on that?
  20. Sep 26, 2012 at 1:51 PM
    JTRD12
    AL
    08 TACOMA TRD DC
    I would do 5100s and 885s for a plate bumper in the future but im just doing the cheapest way possible right now that will work the best. I'm not going up over 2in on the front
