Complete 30k Maintenance
Discussion in '4 Cylinder' started by DanGer, May 17, 2009.
  1. Apr 8, 2010 at 12:35 PM
    #101
    telecraig
    telecraig New Member
    Florida
    2006 TRD Tacoma
    Thanks for the great photos and details. I am getting ready to change the oil and to tackle lubrication of propeller shaft and all of this will help.
    A couple of questions: My 2006 Scheduled Maintence guide does not mention changing the Manual or transger case oils at any interval. I have looked through it twice. Only to inspect them. The only exception is if you are towing or off road. ANy recommendation if I have not been doing either as in, do i still need to change them and how often. It seems pretty easy to do.
  2. Apr 9, 2010 at 8:48 AM
    #102
    GoldBeachBiker
    GoldBeachBiker Member
    BeachBiker
    SR5 4X4
    I meant to say 24mm, not 14mm. and YES, it IS a better fit.
  3. Apr 9, 2010 at 5:58 PM
    #103
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks 4 the heads up. A lot of people don't have metric sockets that go to 24mm.
  4. May 1, 2010 at 9:34 PM
    #104
    wolfeye
    wolfeye Well-Known Member
    Subscribed
  5. Jun 7, 2010 at 11:27 AM
    #105
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    What spec gear oil is recommended? Ie. SF is the lettered grade for some motor oil.
    Good info and pics!
    BTW another option is a suck gun. Looks like a grease gun without the pump handle. It has a tube in one end and a handle at the other. All metal, $25 or so.
  6. Jun 7, 2010 at 12:07 PM
    #106
    george3
    New Jersey
    All these years of DIY and now I find out I could have been using a suck gun. Who knew ?:confused::rolleyes: I'm putting a suck gun on the very top of my list of things to save up for. Do they come in sizes ? I wish I could use a large but I'll probably wind up with a small. Oh well. Thanks for the heads up.
  7. Jun 7, 2010 at 12:19 PM
    #107
    emanb115
    emanb115 Taco Luvr
    SoCAL - Orange County
    07 Black Debadged TRDSport
    current cosmetics: Debadged Smoked Taillights TRex eyelids LuminX Yellow fogs Engine: K&N Intake System JBA cat back exhaust from URD
    this would definately come in handy; great job on the write up very informative.
  8. Jun 8, 2010 at 6:08 AM
    #108
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I called a reputable dealership... Diffs take 75w-90 GL-5, xfer case and manual trans take 75w-90 GL-4 or GL-5. The GL-5 has more shear resistant additives than the GL-4.
    One size fits all on the suck gun. You can put a longer hose on the end as well as other attachments;) to suit your needs. Keep in mind, it is a manual suck gun. You will have to do some work to make it happen, lol.
  9. Aug 25, 2010 at 5:25 AM
    #109
    Jaguar
    Jaguar The dude abides...
    James
    Right next door to Hell, NJ
    White 99 Tacoma, 4x4, 2.7, 5 speed
    Line-x, tints, Sony head unit
    Great write up, Last night I did the rear diff, trans, and transfer case. I sheared 2 bolts getting the front plates off, and was going to drain the front diff, but the drain plug won't budge....even torched it a bit, but no luck. Surprising that it's jammed...well, off I go to grab some PB blaster and soak the sucker.
  10. Sep 8, 2010 at 3:44 PM
    #110
    george3
    New Jersey
  11. Jul 3, 2011 at 8:46 AM
    #111
    Conviction11
    Conviction11 Busting Asphalt
    J
    South Carolina
    thanks to all involved in the detailed work.
  12. Aug 11, 2011 at 3:57 PM
    #112
    Ocean's
    Ocean's Well-Known Member
    For the Great write up with pix and torque Specs! It is done as professionally as Chilton's or Toyota.
    "Scratch That" Is is done better... :D
    I appreciate the time and attention to detail you took in this endeavor. Take a Bow Sir
  13. Aug 21, 2011 at 6:45 PM
    #113
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    fixin' to do this here pretty soon. thanks for the write up man! :thumbsup:
  14. Aug 22, 2011 at 7:06 AM
    #114
    conscript88
    conscript88 newfie
    St. John's Newfoundland
    2011 2.7 AC 4x4 4t3
    I nominate you for a sticky
  15. Aug 22, 2011 at 10:17 AM
    #115
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    2010 Toyota Tacoma Reg Cab 4 Cyl. whats the TQ specs for the driveline? i tried to follow the link but it came up with an error
  16. Dec 17, 2011 at 12:03 PM
    #116
    davegoroun
    davegoroun Well-Known Member
    USA
    '19 DCLB TRD Offroad
    woohoo!
    Just finished my 60k maintenance.
    Thanks guys, for saving me the couple hundred bucks in labor and giving me the sense of accomplishment.
  17. Dec 17, 2011 at 3:26 PM
    #117
    george3
    New Jersey
    The two best reasons to work on our trucks and thanks to a little help from the guys and the occasional gal on TW we can.
  18. Apr 28, 2012 at 9:30 PM
    #118
    MartyDoc
    MartyDoc Member
    California
    2007 Tacoma 4x4 6sp Access Cab
    Thank you for taking the time to explain everything with Pictures!
  19. Apr 30, 2012 at 5:37 AM
    #119
    DESTROYERRACER
    DESTROYERRACER Well-Known Member
    Sean
    Buffalo NY
    18 DCSB 4x4 SR5
    It's new......mods starting soon. Removed step bars so far. lol
    just a heads up for everyone since it was not mentioned in the past 6 page write up, any gear oil with a hypoid additive and gl-5 is NOT good for your manual trans.the hypoid additive will damage the brass synchros in our 5 speed manulas after awhile, and is commonly too slick in the friction coefficient side of things for our trans to operate properly....redline is the way to go here as it is specifically made for manual trans and is safe for the synchros etc....and no im not a redline dealer or employee just speaking from cold hard facts ive researched......ever have problems in frist or reverse or still have some "shift crunch" its because of th eoil your running
  20. May 1, 2012 at 1:36 PM
    #120
    Hot2na
    Hot2na Well-Known Member
    Can anyone do a similar writeup w/pics for the 4.o L ???
