Flooded Truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JRodCC, Apr 23, 2018.
  1. Apr 23, 2018 at 2:17 AM
    JRodCC
    JRodCC [OP] Member
    Vero Beach, FL
    2018 TRD OR
    Good morning everyone, yesterday I celebrated Earth Day a little too hard and subsequently got my truck stuck in some deep just water above the tires. It took afternoon before it was pulled out but I was able to drive it home with all sorts of engine and sensor lights.
    I want to do as much as I can within reason to prevent major damage so here's a list of things that I want to get done before driving it regularly again:
    Change Engine oil
    Transmission and transfer case fluid flush
    Repack Wheel bearings
    Change differential grease
    Spray all of underside (WD40 or something)
    Remove carpet
    Remove door panels and clean. https://www.tacomaworld.com/threads/door-panel-removal.410871/
    Check/Reset computer code errors and fix whatever is causing trouble.
    Does anyone have any other advice on what to look out for?
    DustStorm4x4 likes this.
  2. Apr 23, 2018 at 3:08 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Not sure you can repack the wheel bearings on these but everything else sounds right
  3. Apr 23, 2018 at 3:25 AM
    Smoothmove
    Smoothmove Well-Known Member
    Stan
    Dallas TX
    2020 TRD OR CEMENT
    MesoCustoms
    Fresh water or salt water? Engine should be ok. After you change all of the fluids, re-grease all fittings, remove carpeting for several days, dry and air it out, mechanically it should be ok.
    My 2010 Rubicon was flooded in Hurricane Sandy and that is what I did. Ran fine after. Saltwater in mine got in-between body panels/welds and caused rust issues after about 6 months. Fresh water would be less of a concern IMHO
    I would use a leaf blower on the interior and compressed air to hit all electrical connections that got wet.
    Does your insurance cover flooding, not storm related?
  4. Apr 23, 2018 at 3:29 AM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    As far as wheel bearings, I'd source them from @nj636
    https://www.tacomaworld.com/threads...-complete-save-custom-built-available.288055/
    I've had nothing but good luck with those wheel bearing replacements, although I'm not sure if there are any differences between 2nd and 3rd gen wheel bearings
    Good luck with the rest of the stuff!!
    nj636 likes this.
  5. Apr 23, 2018 at 12:26 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    My question is what were you thinking? Water and electronics don’t mix that truck will never be right...good luck!
  6. Apr 23, 2018 at 12:29 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Eh. He's probably fine if it wasn't salt water. Let it dry out. Spray out all the electrical connections you can with some contact cleaner or electrical cleaner. You will be fine
    SportsmanJake and MountainRidge2 like this.
  7. Apr 23, 2018 at 12:44 PM
    TopDawg1776
    TopDawg1776 Well-Known Member
    Sam
    Nashville
    2022 Tundra TRD Pro
    https://www.amazon.com/s/?ref=pd_sl...da78a0b6c7924a9ee06f0d9&ie=UTF8&hyd_lpo_url=C
    Use these on the inside. My sisters Camry got flooded during school and she couldn't get it out. (New Orleans doesn't drain well) We put one on each front seat, 2 on the rear seat, one in the front foot wells, and on the floor in the back. Put your truck in a dry place with these in your truck. Don't open it for ~24 hours and let it sit. Then check on it, doing this stopped us from having to rip out the carpet and seats.
    Thats what we did for the inside, Id do everything else you listed for the motor/ drivetrain.
    EDIT: these specifically https://www.amazon.com/DampRid-HI-C...=UTF8&qid=1524512772&sr=8-11&keywords=damprid
    513Mugsy and OnHartung'sRoad like this.
  8. Apr 23, 2018 at 12:52 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Tacoma ≠ Boat
    Skeou, cshrum, Garrett75x and 9 others like this.
  9. Apr 23, 2018 at 1:15 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    I think he’s gonna be chasing gremlins in that truck for the foreseeable future... be better to call the insurance company tell them he fucked up...they will pay for stupidity as long as it wasn’t intentional. Theses trucks are not designed for water above the axle.
    513Mugsy, planters15 and Garyji like this.
  10. Apr 23, 2018 at 1:24 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Sorry for your issue, terrible thing to happen.
    I hope uou disconnected the battery until its dried out. Methanol (rubbing alcohol) creates a flamable vapor so you have to be careful with it, but when used on fabric and other water soaked stuff it helps cause the water to dry out faster. Dont use on clear plastic as it turns milky. This is a good way to dry out electronics, too (with the battery disconnected!!!)
    I would also invest in a very large bucket of silca gel and put it in the cab with the windows closed after you fan-dry it for a few days, or go rent a dehydration unit from a tool shop. You are going to have a mold problem starting very soon if you cant get all that water out.
    tcjacado likes this.
  11. Apr 23, 2018 at 1:26 PM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Alligators. :thumbsup:
    Sorry for the hassles. . .hope it works out.
    doublethebass likes this.
  12. Apr 23, 2018 at 1:47 PM
    Judicar
    Judicar Well-Known Member
    2016 Tacoma TRD OR DCSB
    How much water got inside the cab?
  13. Apr 23, 2018 at 1:52 PM
    tcjacado
    tcjacado Well-Known Member
    A lot.:laughing:
    tacoguy88 likes this.
  14. Apr 23, 2018 at 1:52 PM
    Ponchito
    Ponchito Well-Known Member
    Larry
    NorCal
    MGM DCSB OR 4x4
    Stay away from all Rivers, Lakes and streams
    MoneyMan55 likes this.
  15. Apr 23, 2018 at 1:54 PM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    Where I live anything at the floor board in standing water for any period of time the insurance will automatically write off.
  16. Apr 23, 2018 at 1:56 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    It wasn't a timed speed competition, so insurance should cover it...sometimes your wallet has to suffer for being stupid.
  17. Apr 23, 2018 at 1:57 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Be careful with whatever you spray underneath, don't want to spray stuff in bushings and on boots that will dry them out and rot or make them squeaky.
    I'd suggest checking your air filter and throttle body if you got time
  18. Apr 23, 2018 at 2:05 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Surprised nobody has recommended water displacement WD-40 yet. :cookiemonster:
    airborndad and Lawfarin like this.
  19. Apr 23, 2018 at 2:12 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    nightcrawler[QUOTED] likes this.
  20. Apr 23, 2018 at 2:39 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    A bit of blinker fluid will make it right as rain.
