Fog Lamps Help
Discussion in '4 Cylinder' started by alexander323bc, Mar 26, 2011.
  1. Mar 26, 2011 at 5:02 AM
    alexander323bc
    alexander323bc [OP] Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Ok when I first started reading all the lighting threads I thought installing HID fog lights would be easy put I am confused on a few things. My truck is 4 cylinder so it didnt come with any fog lights. All the HID lights I can find just seem to be upgrades meaning you have to some type of bulb already installed. Is this correct there is no HID LIGHT with lens, bulb, wiring and switch already made that I can just install? Or do I have to order some stock halogen kit that is everything like PIAA and just upgrade it? ( piaa is just an example of something non HID that seems to be all there) If someone could please fill in this gap for me I it would be much appreciated. I have looked at all the threads but most of the info was for people just uprading there fogs.
  2. Mar 26, 2011 at 6:09 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    http://www.tacomaworld.com/forum/lighting/84308-lighting-faq-please-read-before-posting.html
    Read that thread, there's some good info in there. You can get fully contained fog light kits, but most of the HID kits you'll find will be plug and play meaning you need to have an existing housing to upgrade. Keep your eyes out on here or ebay, you can find complete fog light systems with the wiring, switch and lights. If you get the stock system, it'd be cheaper than a PIAA system, then upgrade it with an HID kit.
    You can put something like PIAA 510's in the stock fog light locations. They're still a halogen kit but they're pretty bright!
    Good luck, hope this at least starts to put you in the right direction!
  3. Mar 26, 2011 at 10:26 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Thank you so much for the clarifying everything, I was just confused why I was having trouble finding an HID Kit with housing, lens ,bulb and everything. I think I might just GO PIAA, probaly has the the best fit it should just slide right in ( i hope)
  4. Mar 26, 2011 at 10:31 AM
    Pugga
    Massachusetts
    F-150 Mod
    PIAA does make a kit specifically for the Tacoma. It uses the 540 I believe but it doesn't have a great finish. The lights are slightly larger than the opening so they stick out slightly but it's a sure fit with their mounting kit. I'm not sure how much is required to make the 510's mount up but, after asking a few who have done it, have heard it was fairly uninvolved.
  5. Mar 26, 2011 at 11:06 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Thanks for the help now I just need to research the difference between and two and see which one would fit better. I just dont want the bumber all scratched up from trying to install lights. Thank you for all your help!
  6. Mar 26, 2011 at 11:20 PM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    08 4cly
    Dule Magnaflow Exhaust dumped behind axle, K&N Air intake, Aftermarket radio with a kicker L5 sub & a shit amp, 18" rims with tires, RHLM, DT header, color matched bumper, oem foglights, 8k hids in headlights and in fogs
    i have a 4banger that didnt come with fogs so i had to find some, luckly my buddy was getting an off road bumper and didnt need his fogs so he gave them to me. he had already up graded to hids.
    the only thing i have to say is that wiring is kinda a bitch, i didnt go through the fuse box because it would have been alot of work so i just ghetto rigged it and wireed it straight to the battery its been working well for the past 6 months for so. so i have the stock fogs and stock switch but i technically have the fog light anytime mod so i have to remember to turn them off all the time haha.
    also the last thing is if you plan on upgrading to hids in the fogs be prepared to get flashed more if you already have hids in your driving lights. i have 6k in the driving and 8k in the fogs and i get flashed a few times a week just something to warn you about.
    also sorry for the long response but i hope you get it all figured out!
  7. Mar 27, 2011 at 1:43 AM
    Bmxcast00
    Bmxcast00 Well-Known Member
    Raymond
    Exeter Ca
    09 PreRunner Reg. cab.
    Black headlight mod, powdercoated stocks, leveling kit, debadged
    Right now sierrahsky is trying to get a toyota OEM group buy together and he might be getting fogs and switches. There is a list of items that he could get and will be making a group buy for the top 5 items.
    I too am in the same boat with no fogs on my base 4 banger. Maybe if he offers a good price on them we can go the HID route for less than you'd expect.
    So vote for fogs so we don't have to cringe anymore when a Tacoma drives past us with fog lights.
    http://www.tacomaworld.com/forum/2n...oem-toyota-group-buy-what-would-you-want.html
  8. Mar 27, 2011 at 4:41 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Thank for the information my truck is 2011 all stock. My headlights are still sock, My first purchase was the intermittent wiper stalk now I am working on the fog lights. I appreciate all the help you guys offer on this site!
  9. Mar 27, 2011 at 4:42 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    BMXCAST thanks for the info on the group buy I voted lets hope 20 more people vote pretty quick.
  10. Mar 27, 2011 at 10:51 AM
    Bmxcast00
    Raymond
    Exeter Ca
    Yup, but did you see that he might still be able to get some OEM parts so even if the fogs and switch don't make the top 5. We still have a chance by PM'ing him the part numbers and he'll get back Monday or Tuesday.
  11. Mar 28, 2011 at 5:01 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Do you know the part Number's for the Fogs? I might go this route then change to HID's?
  12. Apr 5, 2011 at 7:42 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Anyone have any TIPS for installing the PIAA 510 ATP kit?
  13. Apr 10, 2011 at 5:46 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    no one really? there being installed in the factory holes
  14. Apr 11, 2011 at 1:09 PM
    Pugga
    Massachusetts
    F-150 Mod
    I PM'd a member on here asking the same thing and here is the response that I got:
    A trip to Lowes/Home depot will get the job done. you need a longer bolt and a series of nuts and washers to hold it all together. once you get the stock fog light out of the bumper and see how it is mounted the procedure is pretty much a nobrainer... No trimming necessary, I had the 510 Ion crystal fogs in there and to be honest it did not work well. the way they sit in the bumper and the design of the bumper do not allow for the fog light beam to project well. The driving or ATP beam pattern would better suit this retrofit.
    ohh, One other area of concern is heat build up. The Piaa's get warm, not hot enough to cause damage but do not go through the carwash with them on and located in this retrofit. I shattered the lens on mine.
  15. Apr 12, 2011 at 4:42 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Pugga thanks for the help, my truck did not come with fogs and I have never done anything like this before just did not want any huge surprises.
  16. Apr 12, 2011 at 9:10 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
  17. Apr 12, 2011 at 12:00 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Thanks for the info WHO DAT but I already already ordered the PIAA 510 and I noticed some people on the site had them installed. I was just looking for some tips on how to install them on my truck.
  18. Apr 12, 2011 at 7:55 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    My Fogs came in the mail today going to try and install them tomorrow!
  19. Apr 14, 2011 at 5:08 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    I am working on mounting my lights and there is pretty large gap between the lights and factory holes. Its large enough you can see the whole inside of the housing. Anyone have any idea's to help make this a little cleaner? If I put the guard on it takes care of the gap but I cant get the light to fit into the hole all the way. So I might just leave the guard on, it looks a lot better than seeing the hole inside of the hole. Any help would be appreciated.
  20. Apr 14, 2011 at 5:12 AM
    Pugga
    Massachusetts
    F-150 Mod
