Fog light mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco21122, Jul 24, 2019.
  1. Jul 24, 2019 at 1:34 PM
    taco21122
    taco21122 [OP] Taco2.7
    North Carolina
    2002 tacoma DC Prerunner 2.7l
    5% tint 32” LED bar New DEPO headlights Pioneer radio Kicker speakers Bilstein 5100’s 20x10 fuel turbos 295/55/20 toyo rts
    I am wanting to change my turn signals to fog lights on my 2002 tacoma. I know there’s a lot of write ups on this but can someone walk me through step by step with pictures on how to do this?
  2. Jul 24, 2019 at 2:02 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    just swap the positive wires. harness is behind the park lights themselves. cant remember colours but youl be able to see them anyways
    i used some projector led bulbs in aftermarket clear housings
    kdxrider199 likes this.
  3. Jul 24, 2019 at 2:03 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I have a good news and bad news for you
    Good news: First you need to do blinkers (turn signal) relocation mod. Done successfully by many.
    Bad news: Stock turn signal lamp (reflector) will not work as a fog light. The light pattern is different and really terrible to be used in foggy conditions. It will make things worse.
    However stock turn signals can work as a DRL (the pattern is acceptable for DRL functionality). Just keep in mind: Day Time Running Lights (emphasis is on DAY), they will be blinding (and illegal) to run at night.
    Finally the last resort for you will be dumping stock blinkers and find any Fog Light lamp (aftermarket or adopted from different vehicle) that will fit into holes (I have not see a perfect fit yet).
    Or, forget the whole modification, but just get a decent aftermarket fog lights and install them on the bumper leaving all existing lighting as is. If you do decent job, the truck will not look like crap and will be 100% functional and legal.
    1997tacomav6 likes this.
  4. May 18, 2020 at 8:53 AM
    kdxrider199
    kdxrider199 Active Member
    02 Stocko 4wd SR5 TRD
    None Yet
    Devinz - Will swapping the positive wires leave them on at all times? Or will that have them come on with the headlights or parking lights setting? Would they still blink when you use the indicators?
    I am asking because I am interested in setting up my stock signals with LED white/amber switchback bulbs so they could operate as additional white DRLs/weak fog lights but also blink amber as a signal. I know the bulbs exist, but curious what I would need to change from a wiring perspective.
    Thanks!
  5. May 18, 2020 at 12:53 PM
    devinzz1
    devin
    2023 aclb trd or mt
    they come on as the park lights (first turn of the stalk). they dont blink since those positive wires are going to what were the park lights. you could run those wires to the switchbacks though
    kdxrider199[QUOTED] likes this.
  6. May 18, 2020 at 4:11 PM
    kdxrider199
    None Yet
    Thanks, that makes sense. I am guessing somewhere on here there is one of those fancy fold out colorful wiring diagrams.
  7. May 18, 2020 at 4:44 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    be careful when doing switchbacks. Tacoma 01-04 uses a 3157/4157 CK style bulb that has different contacts than normal 3157. that's why there is usually only one + wire so no chance of messing it up. running switchbacks requires you to "wire" up that 3rd spot in the harness or buy new harnesses with all 3 wires present (I have these from fleabay)
    You can either buy the CK version of the switchback, or get a replacement housing that has the 1157 style and use it instead (it's what I have)
  8. May 18, 2020 at 4:55 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    let's see if this works
    1997tacomav6, Saiko and kdxrider199 like this.
  9. May 18, 2020 at 5:06 PM
    kdxrider199
    None Yet
  10. May 18, 2020 at 5:26 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I have not tried those. I got the Toyota plug ones similar to this but the ones I bought two years ago are not longer listed
    https://www.ebay.com/itm/Gray-3-way...For-Toyota-Turn-Signal-Headlight/362992677031
    I then just cut and soldered them in.
    I have DEPO brand housings because I needed new ones anyway cause they all leaked from the connector and ruined the reflective chrome inside
  11. May 18, 2020 at 6:15 PM
    kdxrider199
    None Yet
    Ahhh gotcha, I actually have a set of the DEPO replacements too (smoked) and they came with the 1157 twist in bulb holder pieces (harness?) and the connection on there is the 3 prong style like you sent so that makes sense. :thumbsup:
    Assuming you added your own resistors? I have never had any luck with that so I was looking at the "error-proof" (aka excuse to overcharge)/CANbus switch-backs.
  12. May 19, 2020 at 10:34 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    no resistors, just bought the flasher module from SBL (www.superbrightleds.com) and no issues
  13. May 20, 2020 at 7:25 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    also, the "sockets" already have 3 conductor spots, it's the plug that is missing the 3rd wire. not sure about 95-00 though
  14. May 20, 2020 at 8:33 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  15. May 20, 2020 at 8:53 AM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
  16. May 20, 2020 at 9:20 AM
    04tacoma trd
    04tacoma trd Well-Known Member
    Link to the "turn signal mod" thread?
  17. May 20, 2020 at 9:52 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
  18. May 20, 2020 at 10:17 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    This thread strikes me that the OP doesn't want "extra lighting" on his truck. But if done well, an extra set of lights isn't tacky nor overstated.
    I say get a bullbar, a modest one like mine with ONE single bar and not a bushwhacker, and mount a pair on it. Way less work, no altering of stock wiring, no cutting, no overloading of electrical.
    I did mine way back in '06 with zero ensuing problems. And my Hella 450s are subdued and in my opinion, quite fitting for the front end.
  19. May 20, 2020 at 12:43 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
  20. May 20, 2020 at 1:57 PM
    RysiuM
    Rysiu
    This would be the best approach to additional lighting. If anyone wants to use switchback in blinker housing and act them as a DRL the power wire for the "white" LED must not come from corner marker circuit. It is actually opposite - that white LED must be turned off when corner marker comes on - i.e. DRL lights must be turned off at night time, otherwise they will be incredibly blinding to other drivers. With additional lamps (like Hella 450 Fog in the example quoted) you will get the correct functionality (correct light pattern) for fog and of course you will wire it to be powered by separate switch/circuit.
    I don't care much for fog, but for my truck DRL is a must. In Europe blinker housing would not pass for DRL. It is not certified. So instead of messing with blinkers I just installed dedicated OSRAM LED DRL (certified and legal) under the headlights.
