Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. May 21, 2016 at 9:49 PM
    #801
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I had about 10 oz or so of Valvoline full synthetic left from the last time I changed mine several years ago. I used it today when I changed it. Looked no different than the new stuff I had when I pumped it into the diff.
  2. May 23, 2016 at 8:20 PM
    #802
    Kwik
    Kwik Well-Known Member
    Kyle
    Seattle
    2011 Tacoma 4x4 2.7L
    How did you find the torque specs for the front diff and trans case? I'm also changing the rear diff and transmission oil and would like to find those torque specs as well. Thanks.
  3. May 24, 2016 at 2:38 AM
    #803
    mike15
    mike15 Well-Known Member
    PA
    2021 Tacoma Limited
  4. May 24, 2016 at 7:03 AM
    #804
    Kwik
    Kyle
    Seattle
    I looked through here and did not find any torque specs for the drain and fill plug of the Trans and rear diff.I checked several times. Maybe I overlooked it?
  5. May 24, 2016 at 7:48 AM
    #805
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
  6. May 26, 2016 at 2:49 PM
    #806
    Redsnapper
    Redsnapper Member
    Travis
    2013 Tacoma TRD Sport
  7. May 26, 2016 at 7:46 PM
    #807
    Kwik
    Kyle
    Seattle
    I'm pretty sure that is the intended weight gear oil for the tacoma but I would check in the owners manual. After searching through the forums I noticed many guys were using redline mt90 and were very happy with it. You may want to consider that over royal purple.
  8. May 26, 2016 at 11:20 PM
    #808
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    According to pg 458 of my Owner's Manual, "Your Toyota vehicle is filled with 'Toyota Genuine Differential Gear Oil' at the factory." The specification listed for Differentials is "LT 75W-85 GL-5 or equivalent," while the one listed on pg 460 for Transmissions is "Gear oil API GL-4 or GL-5 SAE 75W-90."
    FWIW, I run Amsoil Severe Gear 75W-90 in the Transmission, Transfer Case, and both Differentials.
  9. May 30, 2016 at 2:43 AM
    #809
    Tweetercat5
    Tweetercat5 Member
    Brandon
    Oakman
    07 4x4 trd sport package sr5
    Washable cabin air filter, removal of secondary air filter, led lights for dome and map lights,
    Do you guys think it would be a bad idea to change rear and front diff at 176000 never done anything either than oil and normal stuff. Truck doesn't make any noise or anything while driving just figured I ran through a lot of creeks in the past few months might want to change it out saying how it probably never has been changed.
  10. May 30, 2016 at 9:02 PM
    #810
    Norton
    On the contrary. Changing it would be a GOOD idea, especially if you've run through deep water, assuming it's done correctly and with the right replacement gear lube.
    simplehuman and shakerhood like this.
  11. May 31, 2016 at 12:55 AM
    #811
    Tweetercat5
    Tweetercat5 Member
    Brandon
    Oakman
    Well didn't figure it would be bad but wasn't sure because I know sometimes changing stuff if it hasn't been is a bad idea and never had to change diff oil at all never had a vehicle long enough to have to do it lol
  12. May 31, 2016 at 5:59 AM
    #812
    Moonman58
    Moonman58 Well-Known Member
    Parma, OH
    2015 Tacoma 4WD SR5
    Just changed my front and rear diff and transfer case fluids. 2015 4x4 Tacoma 27,500 miles. I used a 15/16 6 pt socket instead of the 24 mm. Fit the bolts tighter. Wish I would have used a pump. I bought a hose that attached to the top of the Mobil 1 bottles and just squeezed the oil in. Spilled it a couple times, but will be better prepared for the next time. Thanks to all for your comments. It is really an easy job, if you can get the bolts loose!
  13. Jun 4, 2016 at 4:15 PM
    #813
    kev6216
    kev6216 Well-Known Member
    Kevin
    Pittsburgh
    2013 Baja
    Any idea how many lbs to torque the transfer case plugs?
  14. Jun 4, 2016 at 5:15 PM
    #814
    IPNPULZ
    going to be fun!
  15. Jun 8, 2016 at 5:50 PM
    #815
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Did mine the other day with 30,500 miles. Front and rear diff's were dirty/grey. Transfer case was clean as can be. Honestly, I would recommend holding off on doing the T-case until maybe 60k miles unless you're doing A LOT of offroading.
  16. Jun 15, 2016 at 4:30 AM
    #816
    TreadUp
    TreadUp Well-Known Member
    Justin
    Belville, NC
    2007 DBCL TRD Sport
    Bilstein 5100's Toytec Springs / AAL SOS Sliders FN Five Star Wheels Falken Wild Peak AT3W 32"x 10.5"
    I thought I remember reading that certain year 2nd gens needed an additive if you have an LSD even if the fluid says for LSD.
  17. Jun 21, 2016 at 3:49 PM
    #817
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    Thanks for the write-up. Just did both diffs, transfer case and engine oil. PB Blaster is your friend. I used an impact wrench and it took care of every plug handily, with the exception of the front diff drain plug, which was stubborn. I alternated the impact wrench and the breaker bar, with liberal amounts of PB Blaster, and then it finally uncorked. Other that that one taking longer, they all came off with little effort. If you don't own an impact wrench, its time for you to go buy a cordless set with the heavy duty llithium ion batteries. My set came with a drill, an impact wrench, two batteries, a rapid charger and a shop radio for about $150.00. I use both tools all the time all over the house, in my hangar, built my fence with them. Its a great thing to have.
    1. A 6-point 24mm socket on an impact wrench is the way to go, with a breaker bar as your standby.
    2. I tried both a pump and an oil suction gun. The suction gun made a lot of mess, lost a lot of fluid, and was a general PITA. It is going in the trash after pumping less than one quart. Although the hand pump takes more strokes, it was faster, it was consistently pushing the fluid and made almost no mess. It also got more out of the container than the suction gun did.
    3. I have a TRD Sport, so I think I have a different skid plate than the TRD Off Road, and I did not have to remove my skid plate, nor did I have to remove my spare tore for the rear diff.
    Overall it was very easy. The longest part was running errands, and rounding up supplies. Actual work time was only an hour or so. I did forget that I bought both crush washers and non-crush washers, so I have no idea which ones I used where. You may need to separate the old brass washer from the front diff drain hole with a screwdriver, as mine fused slightly to the diff. If the washer doesn't come off with the plug, you will probably find it stuck there at the hole.
    Sometimes I worked on a creeper and sometimes used jackstands with no creeper. I have my own safety rule. If I am on a creeper and there are parts of the truck I cannot fit under, I use either the jackstands or the creeper, but not both. If I have to work where there is not enough room for me and the creeper (where I would get crushed if the truck slid off the stands) I use the jackstands with no creeper. I just lay on my back. That way if it does fall I am still alive. Its just an insurance bet. It must be the pilot in me that thinks ahead about these things.
  18. Jun 22, 2016 at 7:31 PM
    #818
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    just sayin.... but, I would have cleaned that off a lot better before opening it. running water and a brush should knock all that mud off.
  19. Jun 24, 2016 at 12:00 PM
    #819
    DirtyTeRD
    DirtyTeRD Well-Known Member
    Steven
    Ohio
    Black 07 TRD
    BlackMAXX Tonneau, Toytec 3in 5100s with eibach coils, Toytec BOSS leafs, LR UCAs, Relentless fab diamondplate tailgate cover, lowes slimline toolbox, pelfreybilt bed bar
    I don't have time to dig through 43 pages. I am planning to tackle this job this weekend and service the pumkin as well. Would Lucas 75W90 be a good choice for everything. I have an offroad W/ locker. I am at 107K and bought it with 81K last year. I do not know if any of them have ever been changed.
  20. Jun 24, 2016 at 12:33 PM
    #820
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    the manual transmission specs a different grade (GL-4, I used Redline MT90) than the differentials (75W90 GL-5, I used LiquidMoly). I believe the transfer case takes the same as the manual tranny. of course, an automatic transmission uses ATF not gear oil.
