Front IFS 7.5" E-Locker and rear 8.4" E-locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Jun 23, 2016.
  1. May 3, 2017 at 11:25 PM
    #161
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Just installed my front locker thanks to ecgs, shipped my old gears back yesterday. They offer a relatively inexpensive install
    QMEDJoe and smmarine[OP] like this.
  2. May 4, 2017 at 9:03 AM
    #162
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Cool to see these lockers are taking off :D
    QMEDJoe likes this.
  3. May 4, 2017 at 9:04 AM
    #163
    smmarine
    Melbourne FL
    I think I paid $1000 which included the clamshell core, rebuilt clamshell with new gears, and the labor to machine and install. It's really not that bad of a price when you think gears are $200 and the master install kit is another $250.
    Prayn4surf[QUOTED] likes this.
  4. May 4, 2017 at 9:23 AM
    #164
    Prayn4surf
    Socal
    Yeah for new gears and the front harrop install it ran me about $1400 all prebuilt third n clamshell...cant beat it! A local shop wanted $2500 to do it plus $500 for the locker install...that woulda put me at $4200 ish with the purchase of the locker...$2600 and diy or $3000 with a 400$ instal of the third and clamshell...hmmm haha
    MotoEd likes this.
  5. May 4, 2017 at 9:35 AM
    #165
    charliegt35r
    charliegt35r MALL CRAWLERs
    CenCal
    2003 tacoma dc
    OME 2.5 LIFT 285/75/16
    Does that inclued the harrop locker? @1400 the harrop cost almost that much already? I got a quote from ecgs and its extra 100 to get harrop install, so assembly 3rd 600+1314(locker)+100(extra install for machine)
  6. May 4, 2017 at 9:45 AM
    #166
    99kyota2506
    99kyota2506 Well-Known Member
    EO
    1999 Taco/Flatbed
    Get to it later...
    Whats this core charge? And how does one guy pay 1000 for the locker and installl while others are at 1500-2000? Whats the cheapest way to do this?
  7. May 4, 2017 at 11:33 AM
    #167
    Prayn4surf
    Socal
    So the gears were 1300 ish +100 install of locker plus the 1200 ish locker..not counting the core charges as they are refunded as soon as you return them...all together I paid about 2600 ish for gears and locker...then you can instal yourself or find someone to do it for you...best i could find was 400$ in san diego...i should have bought an impact wrench...n saved an extra $200
    charliegt35r[QUOTED] likes this.
  8. May 4, 2017 at 11:39 AM
    #168
    charliegt35r
    CenCal
    2003 tacoma dc
    Ok, thanks for clearing up the prices. I was gonna say where can I get the locker and gears for 1300 too. I am plan on getting the harrop front locker and gears sometime this year also.
  9. May 4, 2017 at 11:48 AM
    #169
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    So who has their elocker in a second gen diff? The one you call 8.4 which is open from the factory?
  10. May 4, 2017 at 11:53 AM
    #170
    TireFire
    Olympic Peninsula
    Link to this rear locker? Know if it works for gen 2 tacos?
  11. May 4, 2017 at 12:05 PM
    #171
    99kyota2506
    EO
    1999 Taco/Flatbed
    Get to it later...
    The first gen 4 banger standard cabs also have the 8.4" Which I think is ass backwards to put the 8" on the TRD models. I was about to do the whole 8" TRD axel swap before I saw these lockers. Im not interested in ARB or lunchbox type lockers. I want electric and an on/off switch to save wear and tear when not necessary.
    Thanks for clearing up the prices.
    MotoEd and Chipskip like this.
  12. May 4, 2017 at 1:05 PM
    #172
    TireFire
    Olympic Peninsula
    The 8.4" name is nothing but somebody's measuring mistake that somehow stuck and took off, possibly to imply the extra strength of the trussed 2pinion carrier. Both the TRD off-road and all other 6 lug diffs have the same size 8" crown gear and use the same axle shafts...
    That said, I'm stoked there finally is an aftermarket elocker for these diffs. The new 2016+ off-road model also uses an improved electro magnetic locker, no actuator.
    Did you install it yourself? I assume it's similar to ARB install where you swap your crown gear on a new carrier and drill the housing to run he wires thru?
  13. May 4, 2017 at 3:08 PM
    #173
    smmarine
    Melbourne FL
    That's right, I think my front install was $1300 and I got $300 core charge back when I sent my front diff back.
    QMEDJoe likes this.
  14. May 4, 2017 at 3:10 PM
    #174
    smmarine
    Melbourne FL
    This elocker will fit the 2nd gens too. The 8.4" open diff rear was identical inside between the 1st and 2nd gens. And all links should be in the beginning of the thread
  15. May 4, 2017 at 3:36 PM
    #175
    TireFire
    Olympic Peninsula
    Negative! Only the front one I see linked and I have absolutely zero interest in a front locker
  16. May 4, 2017 at 3:46 PM
    #176
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
  17. May 5, 2017 at 2:55 PM
    #177
    smmarine
    Melbourne FL
    Go to the Yotalockers link and search under tacoma
  18. May 5, 2017 at 4:23 PM
    #178
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
  19. May 5, 2017 at 4:24 PM
    #179
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
  20. May 18, 2017 at 10:30 PM
    #180
    mark52cents
    mark52cents Well-Known Member
    Nice find!
    MotoEd likes this.
