headlight problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1996tacoma5speed, Oct 29, 2019.
  1. Oct 29, 2019 at 6:12 PM
    1996tacoma5speed
    1996tacoma5speed [OP] Member
    Ali
    96’ Tacoma regular cab 5 speed
    I recently bought my first vehicle, and i bought some new headlight housings and new lights, and i installed the new lights and when i had one new one installed and one stock one still, i tested them and everything was good, high and low beams worked and new light was much brighter. i got the other one installed and tested and now only the low beams work. the little blue icon on the dash for brights won’t even turn on. anybody know what the problem is?
  2. Oct 29, 2019 at 6:28 PM
    1997tacomav6
    Denver
    With led or HID lights the high beam indicator will not work unless you install a capacitor type box in one of the headlight wires inline.
    Did you install LED OR HID lights?
  3. Oct 29, 2019 at 6:39 PM
    1996tacoma5speed
    Ali
    I installed LED lights, are you saying they should be making a visible switch in the lights and just not the indicator? because nothing happens at all when i turn them on.
  4. Oct 29, 2019 at 6:50 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    There are a multitude of reasons to not put LED lights in your halogen housings.
    I've never heard of the high beams not working with LEDs without a resistor (that's your turn signals that need the resistor), but I guess that's a thing:
    https://www.tacomaworld.com/threads...t-working-after-led-headlight-upgrade.354065/
    The main reason not to use LEDs (resistor or not) is that the light gets reflected differently and you end up blinding on-coming drivers. Sure, the light appears brighter, but the light is just smeared more. I drive a mildly lifted 4x4, and I get blinded by tons of people in their little Hondas because if their stupid LED/HID lights in the stock halogen housings.
    IMO you have 3 options, all of which include getting rid of the LEDs:
    1) Go back to Halogen bulbs, and search for the "proper headlight upgrade"
    2) Or go for a full HID retrofit (spendy)
    3) get some LED light bars/pods if you want the extra light for off-road use
    crashnburn80 likes this.
  5. Oct 29, 2019 at 6:52 PM
    1997tacomav6
    Denver
    I agree, you need a capacitor type box if you run LED or HID if you want the high beam indicator to work.
  6. Oct 29, 2019 at 6:53 PM
    1996tacoma5speed
    Ali
    I bought new housings to though. i’m not using the stock ones they were sealed ones
  7. Oct 29, 2019 at 6:57 PM
    1997tacomav6
    Denver
  8. Oct 29, 2019 at 7:01 PM
    1996tacoma5speed
    Ali
    1997tacomav6[QUOTED] likes this.
  9. Oct 29, 2019 at 7:43 PM
    jbrandt
    Justin
    Oh wait, you've got a '96.
    Even still, unless you got housings *specific* for LEDs, then you still run into the same problems. I'm not even sure there really are any quality LED housings (that aren't integrated LEDs/sealed housings...
    The version of the "proper headlight upgrade" for the pre-'98's is the E-code housings from Hella (still halogen iirc). There may be others, too, I'm not all that up on the E-code housings...
    But yeah, if you can throw up some links for what you have, that'd be helpful.
  10. Oct 29, 2019 at 8:34 PM
    1996tacoma5speed
    Ali
    Vision X Lighting VX-57 Hi-Lo Sealed Beam Replacement Light https://www.amazon.com/dp/B000ES6N72/ref=cm_sw_r_cp_api_i_1qqUDbZR2TXRC
    H4 LED Motorcycle Headlight Bulbs Hi/Lo Beam 9003 Bulb 2500 Lumens White 6000k CSP Chips LED Car Headlight H4 Headlamp 1:1 Design https://www.amazon.com/dp/B07QBYFVX6/ref=cm_sw_r_cp_api_i_msqUDbXHVYWJ1
  11. Oct 29, 2019 at 8:42 PM
    jbrandt
    Justin
    You got bulbs with *motorcycle* in the description??? :facepalm:
    Although I'm not sure what you'd expect for $18 LED bulbs. I spent more than that on my cheap halogen bulbs. Those housings are halogen housings, too...
    IMO, return all those products you purchased from a place that sells books and games, and buy your parts from an automotive retailer.
  12. Oct 29, 2019 at 9:13 PM
    1996tacoma5speed
    Ali
    yea i feel stupid now, was so exited and wasn’t really paying attention, should i be looking for led specific housings?
  13. Oct 29, 2019 at 10:11 PM
    jbrandt
    Justin
    Like I said, I’m not sure they really exist for our trucks. LED bulb manufactures claim they are compatible with halogen housings, but they just aren’t. They project light differently, and the shape of the reflectors in the housing are very specific to how the light is projected. There are the integrated LED housings (sealed, integrated leds). Make sure you get DOT approved ones.
    Maybe like these:
    https://www.carid.com/1997-toyota-t...7x6-rectangular-led-headlights-547472736.html
    Or these more affordable ones:
    https://www.carid.com/1997-toyota-t...7x6-rectangular-led-headlights-547452669.html
    Check for compatibility tho, some are for DRLs, some aren’t. Just cruise that site, maybe hit up @crashnburn80, he’s kinda he goto light guru, at least for me, lol. He might even chime in and say I’m full of shit, lol
    Since you have some decent housings already, and only $20 in your LED bulbs, I would seriously consider just getting some good halogen bulbs. You can get ones with those blue filters to simulate that “hotter” color, but that does technically decrease the light output.
  14. Oct 30, 2019 at 7:40 AM
    1997tacomav6
    Denver
    These reviews will help you below.
    There’s plenty of junk and high end lights available
    https://m.youtube.com/watch?v=6ifsEY7KbBg
    https://m.youtube.com/watch?v=vCNj9hvPSfY
    jbrandt likes this.
  15. Oct 30, 2019 at 8:58 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    If you really want a LED headlight (instead of H6054 sealed beam) prepare to spend top bucks and buy DOT approved. But there is a catch: DOT approved means the real light output on the road will be no better than quality H4 bulb. DOT puts a limit of the total output of the lamp to not blind the oncoming traffic. This is kind of stupid that DOT allows co much glare (relative to "below the line" light) that the amount of the light below cut off line is limited. These stupid H6054 sealed beam are DOT approved this way.
    So really if you want more light on the road without blinding other people you will never get it from any LED (DOT approved or not). The good news is that your truck accepts 200mm lamps designed for H4 bulbs. The good quality housing (not cheapo from China) paired with quality brand name H4 bulb (not the bulb that comes "free" with the housing - they are junk) will give you the best bang for bucks. E-cut lights while officially "not legal in USA" are much better choice than any DOT approved lamp (sorry, DOT still lives in stone age). But if you want to turn a truck into "Christmas tree", go ahead and put cheap LED bulbs but don't drive it at night - park it on your driveway and enjoy the light show.
    cruiserguy and 1997tacomav6 like this.
  16. Oct 30, 2019 at 9:59 AM
    jbrandt
    Justin
    Even though the cutoff beam isn't effected with the "proper headlight upgrade", glare is still increased because you're throwing more light at the road, which reflects more of that light. It should also be considered that the cutoff doesn't 100% prevent your lights from hitting another driver's eyes anyway. So even if you don't alter the light beam pattern and assuming your lights are perfectly aimed, you WILL blind drivers more than with a stock setup (like coming over a hill).
    I agree it is quite backwards for DOT to limit the light output the way they have and focus more on the lumens rather than beam pattern. I feel that LEDs in halogen housings should be illegal. They have to draw the line somewhere if they want an enforceable law. You can't just say "that's too bright" or whatever. It has to be measurable.
    All this being said, even with my ~20 year old technology headlights (as long as the lenses are clear and functioning properly), I've never thought that I needed "more" light for driving on the road at night. My run of the mill stock replacement halogen lights project light plenty far enough down the road that is easily within my stopping distance. No one "needs" more light. We just "want" it.
    The only time you'd "need" more light is off-road, and anything that would be useful off-road is illegal to use on the road anyway.
    :rofl::rofl::rofl:
    cruiserguy and RysiuM[QUOTED] like this.
  17. Oct 30, 2019 at 1:23 PM
    1996tacoma5speed
    Ali
    https://ledlightstreet.com/products/h6054-led-conversion-kit so something like these?
  18. Oct 30, 2019 at 2:14 PM
    RysiuM
    Rysiu
    Just search "Why you should not put LED bulb in reflector housing" and you will understand that:
    That is 100% true. Especially when the road is wet and acts as a mirror. And even with no reflection from the road I'm always bracing myself when some Audi or BMW with HID in projectors are coming at me. As soon as they hit a small road bump these nice lights with perfect projection and cut-off turn my cabin into a day.
    The other thing is any dirt on the reflector glass will ruin the cut-off by turning a headlight into a surface emitting the light all over the place. My 2012 4Runner has very good headlights (Toyota ruined it in 2014 models replacing big reflectors with wimpy projectors) and with halogen bulbs they put very good amount of light on the road with decent cut-off. Once I was driving in a rain (long distance) and after hour I got flashed. I stopped and check my headlights. The layer of dried road dust turned both lamps into bright glowing balls. They were blinding everybody almost like there was no difference between low and high beam. I wiped my headlights clean and I started to see much more and not blinding anyone. I had to stop every hour and repeat the process.
  19. Oct 30, 2019 at 2:23 PM
    jbrandt
    Justin
    Did you look at the links I provided earlier? Those are tried and true LED specific housings with integrated bulbs. I don't have personal experience with them, but those are at least DOT approved units.
    The lights in your link look just like regular halogen housings, just with LED bulbs. Not sure how that constitutes a conversion "kit".
    Just about any time you see a headlight housing with a replaceable bulb like that, it's in all likelihood just a halogen housing.
    Look at the difference between how the housings in my links appear, vs. the housings in your link or any other conventional halogen housing. True LED housings look like alien eyes or something.
    LEDs project light completely differently than halogen (LEDs are HIGHLY directional vs. the omnidirectional halogens). Even though some (all?) LED bulb manufacturers claim their bulbs are "compatible", they really aren't. Some are better than others, but the physics is inescapable.
    But again, this comes back around to what kind of an advantage you think you'll be gaining form an LED bulb, or even the true LED housings. If they are DOT street legal, the only difference will be the color of the light. They won't be brighter, and won't project light any further as is legally limited.
    RysiuM likes this.
  20. Oct 30, 2019 at 2:34 PM
    jbrandt
    Justin
    I guess what I'm trying to say here is that I'm not trying to discourage you from getting LEDs, but to just have realistic expectations of their performance, and most importantly, if you're going to do it, do it right.
    From an efficiency point of view, LEDs are generally superior. They also produce various "heats" of light, where 5000k-6000k is pretty good pure white light and is good to see at night. Any more than that and you just end up with purple light which has no real performance or visibility advantage. It just looks cool, I guess...
    cruiserguy likes this.
