Help with retrofit wiring
Discussion in 'Lighting' started by sir1123, Nov 30, 2011.
  1. Nov 30, 2011 at 10:40 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    been doing some reserch and really want to do this..d2s minis is what i will be buying. i cant seem to figure out how the bulbs will hook up to my existing h4 plug and how to wire the high beams....help please want to start soon. thanks.
  2. Dec 1, 2011 at 8:29 AM
    morphius
    morphius Well-Known Member
    Santa Clara, CA
    2010 4x4 Access Cab TRD Sport
    This will help answer your retrofit questions. The Retrofit Source team provide multiple documents for wiring diagram, instructions for Tacoma headlamps.
    In terms of wiring harness layout, read the SlimCubby installation thread by Cabletec below. The same way to tuck the wiring harness above the radiator and zip tie process works very well.
    These links may help you as it did for me. Each link has some nuggets of information.
    How to remove the headlamp assembly
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/128360-headlight-removal-pics.html
    How to remove the lens to perform the retrofit
    http://www.tacomaworld.com/forum/lighting/65226-how-black-head-light-mod.html
    Useful for wiring harness layout & AMP connectors
    http://www.tacomaworld.com/forum/lighting/58882-official-slimcubby-hid-kit-install-diy.html
    Morimoto ballast mounting
    http://www.tacomaworld.com/forum/lighting/151993-2010-tacoma-morimoto-mini-d2s-retrofit.html
    Rubber boot fitting with D2S connector
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/109997-hid-projector-retrofit.html
    Good luck
  3. May 20, 2014 at 12:11 PM
    tomxtom
    tomxtom Well-Known Member
    Tom
    Olympia, WA
    2014 TRD Off-road
    sub'd
  4. May 21, 2014 at 8:00 AM
    NolaTaco42
    NolaTaco42 Well-Known Member
    New Orleans
    08 PreRunner
    4" lift 17x9" XD Hoss wheels on Nitto 285/70/17 Trail Grapplers
    the wire harness and relays take care of all that, it is plug and play. if youre buying the full kit that comes with HID
