HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jul 17, 2019 at 8:05 AM
    #3701
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    BTW, I thought that I saw there was questionable value in the cam gears for non-FI?
  2. Jul 17, 2019 at 8:05 AM
    #3702
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Right on! I have definitely been enjoying my v10 standard tune, so much more pleasant to drive!
    tblizzard likes this.
  3. Jul 17, 2019 at 8:21 AM
    #3703
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Hell of a deal, i'll probably wait till i get my fuel rail and FIC injectors to knock a few things out while i have the supercharger off, really don't like pulling that thing if i dont have to ..
    05Taco4x4 and loginfailed like this.
  4. Jul 17, 2019 at 8:22 AM
    #3704
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You saw wrong my friend. The datalogs are in this thread, and @mightytacoman 's thread.
    05Taco4x4 likes this.
  5. Jul 17, 2019 at 8:24 AM
    #3705
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I stand corrected, I will re-research. :thumbsup:
  6. Jul 17, 2019 at 8:30 AM
    #3706
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    05Taco4x4 and Torspd like this.
  7. Jul 17, 2019 at 9:38 AM
    #3707
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I can feel a mod day coming together. Keep me in the loop. :cheers:
  8. Jul 17, 2019 at 1:23 PM
    #3708
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Shall we setup a mod day for real? Not a bad idea.
  9. Jul 17, 2019 at 4:59 PM
    #3709
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
    Anyone know how the HP Tuner works on a SC engine with the BullyDog tune? Does it overwrite it with the TRD tune + whatever changes you you enter since they both use the same calibration ID?
    jojotoo likes this.
  10. Jul 17, 2019 at 5:47 PM
    #3710
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Worked no problem for me but I had bullydog, then overwritten by OVTune then overwritten by hptuner. 98% sure you will be good to go
    Torspd likes this.
  11. Jul 17, 2019 at 5:53 PM
    #3711
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    If the bullydog tune uses the same calibration ID as the TRD tune for your truck, Then you'll be downloading the TRD tune from HP and tuning that. The bullydog will cease to exist. So, Yeah. Just like you're thinking.
  12. Jul 17, 2019 at 6:12 PM
    #3712
    ThomasMore66
    Dallas/Fort Worth & Durango
    Hadn’t heard Bully Dog in a while.
  13. Jul 17, 2019 at 7:05 PM
    #3713
    JaxJacket
    2013 DCLB
    I've read a few complaints on here about the BullyDog, and the install procedure was a royal pain (for reasons not entirely due to my learning curve), but I don't really have any complaints about the installed tune. It was supposed to be able to change some convenience features, and I used it to turn off the seatbelt chime, but once I did that it locks up anytime I tried to use that feature again so it's been sitting in the toolbox since then.
    I was mostly curious as to whether going this route would lead to some of the transmission shifting issues that have been mentioned with the TRD tune. Although it sounds like there is now the ability to adjust that back out.
  14. Jul 17, 2019 at 7:21 PM
    #3714
    TodayWasTHeDaY
    Russ
    Calgary
    I used the bullydog to delete my seatbelt chime too. I also still use the display (exhaust temperatures, throttle percentage and battery level, at the moment) with no problems even though I'm tuned with hptuner.
  15. Jul 17, 2019 at 7:37 PM
    #3715
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I really should unbox mine to turn off the seatbelt chime. Or damn it I forgot to ask while the truck is at toyota right now :annoyed:
  16. Jul 18, 2019 at 12:05 PM
    #3716
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    damb it, where have I been, I have been waiting for a tuner for years.
    Looks like we can build our own tunes with this software???
    This is a game changer I was almost getting ready to jump ship with all the new truck coming out...
    I can finally get this thing running right...
    I'm assuming we can tune MAF, fuel and timing maps????
    Murphinator likes this.
  17. Jul 18, 2019 at 12:12 PM
    #3717
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    You can do it all!
  18. Jul 18, 2019 at 12:20 PM
    #3718
    BillDaCat8
    Jake
    PHX
    Boy are you in for a treat.
  19. Jul 18, 2019 at 12:20 PM
    #3719
    shr133
    Muskego, WI
    2010 V6 Sport
    Awesome, I have been waiting for ever.......
    Can't believe I'm just learning about this...
    This is giving me tons of ideas, time to start getting more parts...
  20. Jul 18, 2019 at 12:45 PM
    #3720
    shr133
    Muskego, WI
    2010 V6 Sport
    So, what do I need to order? I want to tune and data log 1 truck...
    Do I need the Pro features?
    And how many credits do I need..
