Install instructions for new leaf springs?
Discussion in 'Suspension' started by CurboCycles, Oct 18, 2011.
  1. Oct 18, 2011 at 9:33 PM
    CurboCycles
    CurboCycles [OP] Well-Known Member
    Curtis
    Phoenix, AZ
    BLACOMA
    AFE CAI, Flowmaster muffler, Donahoe Racing 2.5" Coilovers, all-pro 3" leaf springs, 5100s, 17" Method wheels, 285 Terra Grapplers, Avid step bars, scooped hood, painted bumper, debadged, black grill and Toy symbol.
    Just bought some allpro 3" leaf springs. Is there a "how to" on installing new leaf springs? I saw the thread on the aal but none for a full leaf pack and new shocks.
  2. Oct 18, 2011 at 9:35 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Don't make multiple threads on the same subject, bump your old thread back to the top
    Don't you just jack it up, take off the shocks/springs, then replace with the springs/shocks (in that order)
  3. Oct 18, 2011 at 9:42 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Basically follow the aal instructions but just remove the springs as well. They didn't come with instructions? Maybe PM allpro and see what they got!
  4. Oct 19, 2011 at 7:05 AM
    CurboCycles
    Curtis
    Phoenix, AZ
    BLACOMA
    It seems that simple in my mind, but i wanted to hear from those that have done it before cuz rarely are things as simple as we hope/anticipate!
    Cpngo likes this.
  5. Oct 19, 2011 at 7:43 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    http://www.tacomaworld.com/forum/su...talls-full-ome-kit-rear-brake-lines-pics.html
    Air tools and an extra set of hands make the job much, much easier in my opinion! I used this thread as a guide for mine. :thumbsup:
    A couple tips, unbolt the brake line from the axle so it doesn't get overextended, bolt the front of the leaf pack in place first then the back since the back is a flexible connection, multiple jacks makes it easier (I used one on each side of the axle and good jack stands on the frame).
    SouthernWild likes this.
  6. Oct 19, 2011 at 10:35 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    There are some pix and instructions in the OME link in my sig.
  7. Oct 19, 2011 at 10:53 AM
    Pugga
    Massachusetts
    Your sig is blank... :confused:
    I linked your install thread above also. I found it helpful when I did my install and figured I'd pass it along :thumbsup:
  8. Oct 19, 2011 at 11:17 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Hmm that's interesting. How about now?
  9. Oct 19, 2011 at 11:18 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    And now??
  10. Oct 19, 2011 at 11:19 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Looks like it doesn't post a sig when I'm using tapatalk on the iPhone, which is most of the time. I'll have to be aware of that.
  11. Oct 19, 2011 at 11:20 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    :) Thanks for the props.
  12. Oct 19, 2011 at 11:30 AM
    Pugga
    Massachusetts
    That one had your sig with all the links
    This one doesn't have a sig
  13. Oct 21, 2011 at 9:12 AM
    CurboCycles
    Curtis
    Phoenix, AZ
    BLACOMA
    Thanks guys. The truck goes on the lift tomorrow. I'm going with stock brake lines so we'll see how that plays out.
  14. Oct 23, 2011 at 8:18 AM
    CurboCycles
    Curtis
    Phoenix, AZ
    BLACOMA
    Got the springs and shocks on...took about 4 hours. Instead of swapping out brake lines, I created a spacer (or large 1" washer) that lifts the brake line holder an inch higher off the axle. This gives me enough brake line stretch at full extension. Also, I welded the old bumpstops onto my new flip U-bolt plates.
    I was nervous about making a $650 investment into the rear suspension of my truck. I did NOT want just a 3" lift out of it for the money. I'm happy to say that the rear suspension is 10x better than it was stock. I have a few large dips near my home that usually my truck bottoms out at 20-25 mph. I can hit it at 40 mph and its no big deal!!! HUGE improvement! If only i could get the left side of the rear to match the right side....right now the right side is 1.25" HIGHER! Hopefully it settles in.
  15. Oct 23, 2011 at 8:23 AM
    CurboCycles
    Curtis
    Phoenix, AZ
    BLACOMA
    And for anybody in the future looking to do the same, here is the install process I used:
    Removal
    Tires, emergency brake, brake lines off axle, shocks, ubolts, springs. Install one spring at a time.
    Reverse process for install.
  16. Oct 23, 2011 at 8:24 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Did you get the standard duty springs? What shocks are you running?
  17. Oct 23, 2011 at 8:26 AM
    CurboCycles
    Curtis
    Phoenix, AZ
    BLACOMA
    Yes, standard All-Pro 3" springs. I don't haul or tow much other than a quad and I wanted 3" of lift, not 4" so I chose standard over expo pack. I'm running the 5100s in the rear, 2.5" Icons up front.
  18. Oct 23, 2011 at 10:43 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    OP do you mind posting what your #'s are from the hub to the center of the rear fender? Im looking to swap out my procomp aal for a leaf pack and trying to maintain the same amount of lift.
  19. Oct 23, 2011 at 4:35 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    You could also check out the Dakars. That's what I got.
    http://www.tacomaworld.com/forum/suspension/173193-2nd-gen-ome-dakar-hub-fender-measurements.html
    Average returns from posters in this thread ( updated to post #52 )
    DCLB-24 3/8" (3)
    DCSB-24 3/8" (6)
    AC- 25" (4)
    RC- 25.5" (1)
    http://www.tacomaworld.com/forum/suspension/180042-all-pro-dakar.html
  20. Oct 23, 2011 at 5:10 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Dude, we're going to have to wheel sometime! That's the set up I want to go with but I'm running 9.24" 5125's in the rear. Wasn't sure how much rake with the Icon's up front? Can you post pics? I've got next weekend off if you want to hit Sycamore or Butcher Jones to shake everything down?
