Installing extra d-rings in bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cjh, Mar 22, 2010.
  1. Mar 22, 2010 at 4:49 PM
    cjh
    cjh [OP] Well-Known Member
    10 doublecab
    Has any one installed another set of d-rings in the front of the bed using the front bed mount bolts with any luck? The side rail tie down points seem kind of flimsy to me. It looks like it should be a matter of unscrewing the front bolts and putting another d-ring onto the bolt and screwing it back in. Any good or bad points to doing this?
  2. Mar 22, 2010 at 4:52 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Search. This has been done.
    A few points:
    - The side rails are *not* flimsy.
    - Fitment of d-rings on the bed bolt will be tricky. Drilling out mounting holes in the d-rings with a uni-bit may be necessary. It is also common to have to grind some metal ribs off the bed bolt so that the washer may be removed.
    - You will likely need an impact driver/wrench or LONG (2 feet plus) cheater bar to break loose the bed bolts. I don't know the exact torque spec, but it's somewhere just past "torqued to all hell".
    - Recommend a nice thick coat of rustoleum after drilling/grinding to prevent rust.
  3. Mar 22, 2010 at 4:55 PM
    2010SWB
    2010SWB Active Member
    you need to use a t-55 torx bit with a rachet to remove the front bolts. then use either a bench grinder or a dremel to grind the top threads from the bolt removed to get the washer off. put d-ring on then the washer for more support and re-install. just did them in my truck this weekend make sure you use red locktite btw.
  4. Mar 22, 2010 at 4:57 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
  5. Mar 22, 2010 at 5:42 PM
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    i didnt need to do squat... just removed the bolt and installed the bed rings... granted they dont move at all... but yup.. just removed and replaced.
  6. Mar 22, 2010 at 6:23 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
  7. Mar 22, 2010 at 6:25 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    what are you going to be tieing down, for dirtbikes or just everyday use?
  8. Mar 22, 2010 at 7:50 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    what about putting D-rings on the front wall, or back wall. Or whatever you want to call it. The end that's against the cabin.
    I have one of those "spider" nets for my bed. I sometimes haul with a tarp and the tarp will flap around that area if it's not held down.
  9. Mar 23, 2010 at 2:38 AM
    cjh
    10 doublecab
    Thanks for the replies. I searched for d-rings with no luck. I am hauling 2 bikes and occasionally my 4 wheeler. I know the rail clips are rated for only 200# and my VTX weighs about 600#. I haven't had that bike in there yet, but I don't want that thing coming loose and taking anything out. The main reason for the bed bolt mounting spot is that it has a nice metal bracket underneath the truck so it should be as strong as the rear factory d-ring location. I would be leary of just mounting an extra one just anywhere because you are mounting it to just the plastic bed.
  10. Mar 23, 2010 at 3:56 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  11. Mar 23, 2010 at 4:00 AM
    rsincavage85
    rsincavage85 Well-Known Member
    Rick
    Plains Twp. Pa.
    Super White SR5
    Saw this and I am currently putting extra d-rings in my bed for tie downs. 2 are going just under the original track for the OEM tie down above the wheel wells. And then i am going to mount the other 2 behind the wheel well on the bottom of the bed. Just finished painting them and making a back mounting bracket. I got the tie downs from Lowes, Daddy's toy store as my kids call it. They came in a pack of four for like $5.00. Installing them this weekend on Saturday. I'll post pics when I do them and figure out how to post them.
  12. Mar 23, 2010 at 4:05 AM
    cjh
    10 doublecab
    Okay just out of curiosity I ran outside and tried to break loose the front bolts and they both came loose with basically no effort at all. I guess they aren't torqued very tight from the factory. I am going to order up some rings today and I should be all set. Thanks again!
  13. Mar 23, 2010 at 4:18 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    yes I totally forgot that there were no front d rings on my truck when I went to pick up my new (to me) motorcycle. Needless to say I drove home and got my trailer which has mounting points into the metal, not just the wood & picked up a wheel chock. Now the trailer is setup for my bike!
    Racheting a bike, sled or atv to the rail isn't something I would do either & would be leery of mounting points just in the bottom or sides of the plastic bed. I am going to have to arrange to get d rings added to the front bed bolts too. Thanks for all the links & posts.
  14. Mar 23, 2010 at 4:24 AM
    jandrews
    The rail cleats are rated for up to 220# pull force. An ATV sitting in the pickup bed and shifting with a turn is applying maybe 100# pull force to an actual cleat in the worst case scenario, most of the time much much less.
    I wouldn't hesitate to strap anything up to max payload down with the rail cleats. Toyota kind of designed them that way...
    That said, I have extra d-rings in just because 10 tie-down locations is better than 6...especially for smaller items.
  15. Mar 23, 2010 at 4:54 AM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    They're in a spot that's exposed to the weather so they get rusty pretty quick. On mine they took a bit of muscle to break loose and remained stiff while unscrewing them. I even squirted some PB Blaster (penetrating oil) on them because I did not want to break one of those.
    As far as the washer went, I just ground down one edge to fit the D-ring rather than remove it.
  16. Mar 23, 2010 at 5:28 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Cheep and easy mod, do it!
  17. Mar 23, 2010 at 6:15 AM
    doodle_cakes
    doodle_cakes Well-Known Member
    Canada
    08 Taco SR5 5lugger
    :D I want to add d rings just so I have an excuss to buy an impact drill / grinder / more toys
  18. Mar 23, 2010 at 7:14 AM
    ktmrider
    Junk
    Search no more
    http://www.tacomaworld.com/forum/product-reviews/69666-hook-ups-dirtbike-solution.html
  19. Mar 23, 2010 at 8:53 AM
    cjh
    10 doublecab
  20. Mar 23, 2010 at 10:16 AM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    Never seen it done here
