JeepAndrew's Jetski Trailer-to-Offroad RTT Hauler Build
Discussion in 'Other Builds' started by JeepAndrew, Apr 7, 2014.
  1. Apr 7, 2014 at 6:15 PM
    JeepAndrew
    JeepAndrew [OP] Nah bitch Jeep guy
    Andrew
    Tucson, AZ
    Offroad beast YJ/2015 Taco
    Lots-o-mods
    Teaser pics:cool:
    Since camping out of a two door Jeep Wrangler sucks (lack of cargo space) and I'm in the market for a roof top tent, I made the long overdue decision that I needed an offroad/camping trailer. I wanted something Expo-style or similar to Boxrocket's trailer but didn't want to spend thousands of $$$ on a prebuilt trailer. I had a 3/4 ton single jetski/PWC trailer that I didn't use anymore, soo I put my building/fab skills to work!
    This is how it looked when I rolled into the garage the night before I got started. The frame measured 46"x33" with a 10 foot total tongue bar length:
    The next day, I started by stripping the license plate and trailer lights, pulling the wheels, flipping the trailer over and stripping the old axle assembly.
    The original axle assembly wasn't wide enough to mount the 15x10 rims and 33" tires I wanted to run, so it was set aside to have the carrier/hub assemblies removed from the old axle bar. On the good side, I checked the lug pattern with my old stock spare jeep rim, and the hubs just happened to be 5x4.5 bolt pattern, same as my jeeps!
    I enlisted the help of CrawlinWJ and his welding skills to help me extend the trailer frame from the stock 33" to 62". This was done with 2"x3"x1/8" box steel. I used 1/8" to match the thickness of the stock C-channel frame. All weld joints were cleaned of paint beforehand of course.
    We determined the balance point on the trailer and set the axle centerline 4 inches behind that to give it a good tongue weight, then we set the spring perches in place, double-checked our measurements, and welded them on.
    I then measured the hub-to-hub width on the rear axle on my jeep (approx 58"). We cut a piece of 1.25x.250 round tube, 53" long. We then cut the old hub assemblies and spring mounts off of the old C-channel axle bar, cleaned off the round spindle bars with a flap wheel and slid them into the tube, then did 4 rosette welds on each end to secure them. End result was a hub-to-hub of 58". The spring mounts were then welded onto the new axle tube, and bolted to the springs. Next came the sides:
    I went with 6-1.5x1.5x1/8", 18" long for the siderail uprights, with a 2x3x1/8 at front-center above the tongue bar to support the spare rim and tire. Here it is with the axle mounted and side uprights done.
    At this point I wanted to test it out, so I borrowed two of the 33" MTRs off my wrangler and hooked it up to my Cherokee for a run around the neighborhood. It tracked straight and is very light!
    I used the stock 1-7/8 ball hitch for the test but will be getting either a Lock-n-roll or Max Coupler for permanent use. I'll also be reducing the tongue length later on (depending on which hitch I go with).
    The build continues!!:D
    http://www.tacomaworld.com/forum/ot...ler-offroad-rtt-hauler-build.html#post8508587
    http://www.tacomaworld.com/forum/ot...r-offroad-rtt-hauler-build-2.html#post8526839
    http://www.tacomaworld.com/forum/ot...r-offroad-rtt-hauler-build-3.html#post8532844
    http://www.tacomaworld.com/forum/ot...r-offroad-rtt-hauler-build-3.html#post8537152
    http://www.tacomaworld.com/forum/ot...r-offroad-rtt-hauler-build-3.html#post8544761
    http://www.tacomaworld.com/forum/ot...r-offroad-rtt-hauler-build-3.html#post8549156
    http://www.tacomaworld.com/forum/ot...r-offroad-rtt-hauler-build-5.html#post8890710
    Manfred likes this.
  2. Apr 7, 2014 at 6:26 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    sub'd
  3. Apr 7, 2014 at 6:43 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
  4. Apr 7, 2014 at 6:52 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
  5. Apr 7, 2014 at 6:56 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  6. Apr 7, 2014 at 7:21 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Oh in for this!:popcorn: and cant wait to see this with us on the trail!
  7. Apr 7, 2014 at 7:35 PM
    AzCrawlin
    AzCrawlin Fuck that rock.
    Derrick
    Tucson AZ
    2010 pyrite-micha DCSB 4x4 sport
    gonna be a bad ass trailer. :)
  8. Apr 7, 2014 at 7:40 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    subd... even if a heep is town it, I'm sure it'll be an awesome trailer!
  9. Apr 7, 2014 at 7:41 PM
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    I'm curious... subbed.
  10. Apr 7, 2014 at 7:44 PM
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
  11. Apr 7, 2014 at 7:45 PM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
  12. Apr 7, 2014 at 9:26 PM
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    Sub a dub dubbed :popcorn:
  13. Apr 8, 2014 at 9:21 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    three men in a tub'd
  14. Apr 10, 2014 at 12:20 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :wave:
    Lookin good Buddy! :thumbsup:
  15. Apr 10, 2014 at 1:04 PM
    snowtank
    Andrew
    Arizona
    Its been 3 days since new photos! Get back to work. And text inbound about the "super awesome cooking platform"
  16. Apr 10, 2014 at 1:47 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Is this thing done yet?
  17. Apr 10, 2014 at 1:48 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  18. Apr 10, 2014 at 5:31 PM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
    Hey now fellas, ya can't rush perfection :cool: I'll be purchasing the additional needed materials tomorrow afternoon :)
  19. Apr 10, 2014 at 5:48 PM
    Toyanvil
    Toyanvil Well-Known Member
  20. Apr 13, 2014 at 3:20 PM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
    Picked up the steel Friday to resume the trailer build. Today we got on it again, starting with the top rails on the sides. I went with 1'x3''x1/8 thick box for the top rails. The ends were cut to 45 degrees for the corners and welded on.
    I'm using the stock trailer wheels right now just for moveablility
    Next came the spare tire carrier. For departure angle reasons, I wanted the carrier over the tongue bar. I used a 6" diameter, 3/16" round plate with three lug studs welded into it to mount the tire to. The round spare holder plate is welded to the center upright with a 6.5" piece of 2"x3"x1/8" with two precut 3/16" triangle gussetts for strength.
    I used the 33x12.50 spare off my Cherokee for a test fit. The tire just barely sits on the hitch bar, which should keep bouncing forces to a minimum.
    Here's the trailer hitch system I went with; the Max Coupler :drool: Claimed to be the best offroad hitch system on the market. I ordered it yesterday afternoon so it should be here soon!
    I also picked up some 14 gauge sheet for the floor and sides and will be getting on that later today!
