KeithB's SWB '09 Tacoma DCSB V6 4.0 TRD Sport 4x4
Discussion in '2nd Gen. Builds (2005-2015)' started by KeithB, Apr 1, 2009.
  1. Mar 23, 2020 at 11:24 AM
    #121
    KeithB
    KeithB [OP] Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
  2. Mar 25, 2020 at 3:02 PM
    #122
    KeithB
    Keith
    Cheshire, CT
  3. Apr 11, 2020 at 7:59 PM
    #123
    KeithB
    Keith
    Cheshire, CT
    Got the bulbs earlier this week and installed today. They work and the A/C button light is now re-illuminated as well. Weird how the bulb on the right lights the button on the left and vice versa. Also new wiper blade rubber inserts and closing in on 200k. At 199,930 today.
    Wiper blade rubber insert (Left, driver side) - 85214-0E020
    Wiper blade rubber insert (Right, passenger side) - 85214-01011
  4. Apr 14, 2020 at 10:39 AM
    #124
    KeithB
    Keith
    Cheshire, CT
    Getting ready to do some maintenance:
    Toyota ATF for 200k mile drain and fill. Did once before at 100k.
    Engine air filter for after spring pollen season.
    Cabin air filter also for after spring pollen season.
    Will be rotating tires (every 5k miles) and changing engine oil also. I've been using AMSOIL 5W30 since the truck was new with Toyota OEM 90915-YZZD3 Oil Filter.
  5. Apr 17, 2020 at 6:31 AM
    #125
    KeithB
    Keith
    Cheshire, CT
    Yesterday:
    TRlPPlN likes this.
  6. Apr 24, 2020 at 12:48 PM
    #126
    KeithB
    Keith
    Cheshire, CT
    TRlPPlN likes this.
  7. May 13, 2020 at 11:12 AM
    #127
    KeithB
    Keith
    Cheshire, CT
    Finally received the voltage booster I ordered back on 3.27. Installed yesterday and instantly booster my ECM voltage from 13.9 to 14.5 on cold start.
  8. May 13, 2020 at 12:29 PM
    #128
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    Just curious , what else does the booster do or specifically for really cold weather?
  9. May 15, 2020 at 7:39 PM
    #129
    KeithB
    Keith
    Cheshire, CT
  10. Jul 1, 2020 at 4:59 PM
    #130
    KeithB
    Keith
    Cheshire, CT
    Did tranny fluid drain and fill today at 202558 miles. 2.8 quarts out, 3.0 quarts in. UG tranny temp at 120F, overfill plug drained for a few seconds then done.
  11. Jul 3, 2020 at 10:30 PM
    #131
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    The only maintenance I'm afraid to try.
  12. Jul 6, 2020 at 8:10 AM
    #132
    KeithB
    Keith
    Cheshire, CT
    Really pretty easy. Especially if you have a SG or UG so you can read tranny temp. If you don't have a gauge or head unit with datalink maestro, you can jump the obd pins to get into remp check mode. See the thread. https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/.
    Otherwise you could simply measure how much drains and put back in the same amount.
  13. Jul 22, 2020 at 5:38 AM
    #133
    KeithB
    Keith
    Cheshire, CT
    Plugged a flat tire on the 8th. First time I've ever plugged a tire and its worked so far.
    Been working from home most days lately due to Covid-19 but both my wife and I needed to physically go to work on the 9th. So about 5pm on the 8th I get home from a couple of errands and hear this hissing sound when I get out of the truck. Perfect timing, I need the truck the next day for the first time in a while my wife needs here car too. Turns out my right rear tire was punctured but no nail or anything in the tire. So I call a few shops and nobody can fit me in for a few days let alone before closing now. I start watching some video's online and seems pretty easy. Call Advanced Auto and they have a tire plugging kit ($10) and close at 7pm. Got there at 6:30 to grab the kit. Tire was plugged in about 2 minutes. Took longer to air it back up. I'm just amazed that it actually holds.
    TRlPPlN likes this.
  14. Jul 22, 2020 at 5:54 AM
    #134
    KeithB
    Keith
    Cheshire, CT
    Also, voltage booster seems to be doing it's job. Haven't had any starting troubles since installing. Battery must be a little healthier now.
    Still haven't figured out my intermittent hyperflash issue. A few clues though: Only does it when parking lights are on. Not all the time but never when parking lights are off. Parking lights are spliced into the dimmer filament of the blinkers to act as DTRL. Blinkers use the brighter filament. I say filament but they are LED bulbs so not a filament but whatever, don't know the terminology for LED's. Anyway, I'm sure it has something to do with that setup. Worked for a few years but now I'm having issues.
  15. Jul 31, 2020 at 6:23 AM
    #135
    KeithB
    Keith
    Cheshire, CT
    So I swapped out my aftermarket rear tail lights for the OEM ones and the hyperflash is gone. Guess it's the resistor in the tails that is the issue. Trying to find replacements but Xtune/Spyder doesn't sell or have replacement parts. They buy complete items from Taiwan to sell here. Suppose I could try another style resistor as long as its the same resistance.
  16. Sep 21, 2020 at 1:59 PM
    #136
    KeithB
    Keith
    Cheshire, CT
    Truck did not start this morning. Tapped on the starter and it reluctantly started. Drove it to the shop and had it all checked out. Couldn't find anything wrong and started at the shop without issue. So I had the starter replaced. Kept the original starter so I could have a look inside. Shop would not do repair of parts due to warranty issue so had to have the whole thing replaced. Anyway, did not look like worn contacts, more like dirty contacts. Cleaned them up and this is the result. Wonder what a 12 year old OE starter with 205k on the clock is worth on TW market?
    The rebuild kit:
    https://www.amazon.com/dp/B07DZXRZPY/ref=cm_sw_r_cp_apa_i_v8tAFbH2TP5AP
  17. Oct 6, 2020 at 2:27 PM
    #137
    KeithB
    Keith
    Cheshire, CT
    Replaced my Tacomabeast headlights with new last week 9.29. Had a flicker starting to develop on the drivers side led bar. Hoping I can sell them to someone willing to repair and maybe wants a HID or retrofit of somesort.
  18. Oct 6, 2020 at 2:32 PM
    #138
    KeithB
    Keith
    Cheshire, CT
  19. Oct 6, 2020 at 2:36 PM
    #139
    KeithB
    Keith
    Cheshire, CT
    SOLD - These up for sale as is with the flicker: just a couple months over 2 years old, UV protectant applied every few months, sealed with silicone bead prior to install as extra precaution against condensation, $75 + shipping, :
    (Don't mind the white strip on the two pics of the individual frontside, it's just a reflection from the ceiling lights in my garage.
  20. Oct 29, 2020 at 12:40 PM
    #140
    KeithB
    Keith
    Cheshire, CT
