Longer wheel studs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdg, Sep 26, 2015.
  1. Sep 26, 2015 at 10:09 PM
    jdg
    jdg [OP] Well-Known Member
    David
    Texas Panhandle
    2015 Tacoma SR5, V6, automatic, 4x4, extended cab
    All the time!!!
    I'm fixing to put 1 1/4 spacers on my wheels. Just to see what it was going to look like I put one on and as I have seen on nearly every pictures I've seen on TacomaWorld they've showed the nuts to hold the spacers on are only about half full of the studs. Sorry but that makes me very nervous! I've checked at a couple of places and cant find any longer studs, or place to even order them from. Has anyone put longer studs in and where did you get them from?
  2. Sep 27, 2015 at 11:08 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yep, I had same issues and put longer studs. I got mine from this vendor's Ebay site: http://www.wheeladapter.com/wheel_studs.php . They were $50 for 24 studs and are about 53mm long. I see they raised the price a bit. I have since found out about Ichiba's studs: https://www.ichibausa.com/searchresults.asp?cat=956 priced $3 each and they have a 45mm and a 50mm. Also saw these 50mm on Amazon and are quite a deal at $19: http://www.amazon.com/EXTENDED-WHEEL-BOLTS-TOYOTA-M12X1-5X50/dp/B009OZ7T5Q . The OEM length is about 30mm. ARP's studs are $32 for a set of 5; they make very good bolts/studs but they are not priced/packaged with our needs in mind.
    As Rock Lobster mentioned, there may be interference issues because the extended studs stick out of the adapter/spacer about 3/8 of an inch - for the 53mm I got from wheeladapter's. The OEM alum wheels happen to have depressions that allow for this protrusion; some aftermarket wheels may not. I'm curious to see if Ichiba's 45mm stud doesn't stick out. If I had to buy new ones again, I'd go with Ichiba's 45mm. They used to make a one-inch wheel adapter that I had on my Taco and were bullitproof, but it was too thin when I went with MT tires.
    A good time to replace the studs is when you replace the wheel bearings. Otherwise, you'll need to drill a hole into the dust shield as I did. I used an air hammer with a sheared chisel to remove the studs; came out like butter.
    .mr.e. and jdg[OP] like this.
  3. Sep 27, 2015 at 2:12 PM
    jdg
    David
    Texas Panhandle
    All the time!!!
    Thanks!!! Just what I needed to know. I'm in no big hurry so I'll get some ordered and on the way. Thanks again!!!
  4. Sep 27, 2015 at 3:42 PM
    thecoz
    thecoz Well-Known Member
    Tim
    Columbus Ga
    07 DC 4x4 6 speed
    K&N drop in, flowmaster 40 dumped before rear axle, 20% tint up front. 3 inch fat bobs coilover. Rear aal and zone shocks. LR UCA. 1.5 inch rear block. CBI moab 2.0 front bumper with wrap around guard. Smittybuilt 9500lb winch. URD short throw shifter.
    I was just thinking about this today because I'm going to get 1.25 inch spacers here soon. There is a guy on here who sells the entire hub with new bearings and arp studs. Wonder how well that would work with spacers?
  5. Sep 27, 2015 at 9:36 PM
    Chuy
    Lakeside, CA
    Silver Taco
    thecoz likes this.
  6. Sep 28, 2015 at 8:41 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    jdg[OP] likes this.
  7. Sep 28, 2015 at 8:46 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    You shouldn't need longer studs to run spacers. They will come with their own lug nuts to install on the stock hub using the OEM studs, and then their own extended studs to mount the wheel onto them.
  8. Sep 28, 2015 at 10:08 PM
    jdg
    David
    Texas Panhandle
    All the time!!!
  9. Sep 28, 2015 at 10:53 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I speakth from experience: the OEM studs are not long enough to accommodate a 1.25" spacer/adapter; the spacer/adapter will take up a fair amount of threads on the OEM stud.
