Michigan Tacomas
Discussion in 'Mid West' started by harshest, Feb 8, 2009.
  1. Nov 17, 2011 at 9:32 AM
    #241
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    Its good to build for your likes/ needs. I actually like plate bumper better but decided against because of the weight. My rear is actually the plate design I was going to build just ended up making it out of square tube to save weight.
    That will look sweet. I can help out with the fabrication building if you would like. I also have some of the parts / tabs needed already.
    Just make sure you are getting enough airflow to the radiator. Maybe a few slots were the radiator is behind the bumper ( always a good idea).
  2. Nov 17, 2011 at 9:44 AM
    #242
    tacoma-king
    tacoma-king Well-Known Member
    sault ste. marie Michigan
    1997 Tacoma
    hitch
    I see Tacomas all over the place up here in Sault Ste. Marie and Brimely .both first and second gens its a fairly popular truck up here in the UP
  3. Nov 17, 2011 at 9:47 AM
    #243
    Taco.VR4
    Taco.VR4 Fast Cars, Off-Road Trucks, and Hott Women ;)
    Jay
    Grand Rapids, MI
    '02 Tacoma, '97 3000GT
    5100s, Icon 3 AAL, Custom-built front/rear bumpers, Hybrid seats, 3000GT modified intake box, toolbox, D-rings
    Maybe i'll cut teeth-shaped vents for airflow... no that'd be way too cheesy :p
    Question: is having just the corner markers enough to be legal turn signal wise? or do I need to somehow preserve the lights in the oem bumper?
    The plates, since they are more for shielding not armoring, I think I will use sheet metal enough to cover but not thick enough to really stop much. The frame will be the guard, not the plates.
    *edit* also, any recommendations on best mounting points for d-ring holes?
  4. Nov 17, 2011 at 3:11 PM
    #244
    atvlifestyle
    Michigan
    01 trd tacoma
    Just relocating the turn signal in the corner light is legal. I did that but I also run the LEDS under the headlight to ensure people see them.
    D rings sould be as close to the frame mounts as possible. Also best to have them attached to morethan a surface weld.
    Do you have a tubing bender? If not it may be easier to just build a plate bumper. Just use heavier gauge steel between the frame rails than the outside and it will keep your weight down.
    For vents just make a couple strategically placed holes. Dont need to be that big, or you can slot it for a winch fairlead later.
    The options are endless. You are building it so make it exactly what you want. You will like it much more and the learning experience is priceless.
  5. Nov 17, 2011 at 4:28 PM
    #245
    Taco.VR4
    Jay
    Grand Rapids, MI
    I do have access to a tube bender :)
    any more details on how to mount d-ring beyond surface welds?
  6. Nov 17, 2011 at 4:50 PM
    #246
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Cutting a hole big enough for your mount to fit into the plate then welding the back of your mount to the bumper and the front. Known in my book as a plug weld!
  7. Nov 17, 2011 at 6:36 PM
    #247
    atvlifestyle
    Michigan
    01 trd tacoma
    Dont use bed tie downs for D-ring, or at least that what it looks like in the pic. My bumpers have a piece of 120 wall 1.25 DOM tubing mounted into a piece of plate. I also have some old Allpro greasable shackles I have cut up and used the ends for the same purpose (have more laying around). A lot of companies make weld on tabs also.
    Ill post a few examples when I find them.
  8. Nov 17, 2011 at 6:50 PM
    #248
    Taco.VR4
    Jay
    Grand Rapids, MI
    No no, not doing tie-downs just looks that way cuz i didn't feel like messing with it lol
    I know where I can get tank armor plating, maybe ill use that for them :D
  9. Nov 17, 2011 at 6:53 PM
    #249
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I wish I had your truck so much. I'm hoping to be able to find one in the future and start over!
  10. Nov 17, 2011 at 6:57 PM
    #250
    atvlifestyle
    Michigan
    01 trd tacoma
    That should definetly work. To bad you arent closer I have all kinds leftovers from my different projects laying around until I clean the garage.
  11. Nov 17, 2011 at 7:02 PM
    #251
    Taco.VR4
    Jay
    Grand Rapids, MI
    what would you do differently? any recommendations?
    if i asked this sry for the redundancy: where exactly are you?
  12. Nov 17, 2011 at 8:17 PM
    #252
    PcBuilder14
    Brent
    Nor Cal
    Preferably save up for a very nice mid-travel setup, then get some new fenders and bedsides. Basically end up what one of these guys did, except with plate bumpers and more aggressive mud tires.
    http://www.tacomaworld.com/forum/1st-gen-builds/138220-jasons-long-travel-toy-taco.html
    http://www.tacomaworld.com/forum/1st-gen-builds/182552-coles-tacoma.html
    http://www.tacomaworld.com/forum/1st-gen-builds/168727-taco-me-elmo-2002-black-black-build-thread.html
    The main reason for me wanting a 01-04 tacoma is because they're my favorite year models, plus after I had my wreck, mine just isn't the same anymore. Almost like it's falling apart.
  13. Nov 18, 2011 at 2:59 AM
    #253
    atvlifestyle
    Michigan
    01 trd tacoma
    Jay
    I am almost 2 hours south of you in stevensville. People actualy know st joe same dif.
  14. Nov 18, 2011 at 1:20 PM
    #254
    Taco.VR4
    Jay
    Grand Rapids, MI
    Chris what size steel is ur front bumper? I am thinking of going with 1 1/4 inside diameter round steel. thoughts?
  15. Nov 18, 2011 at 5:12 PM
    #255
    atvlifestyle
    Michigan
    01 trd tacoma
    Do you only have pipe dies for the bender? My bumper is 120 wall 1.75 DOM tubing. Tubing is measured OD not ID.
  16. Nov 18, 2011 at 6:33 PM
    #256
    Taco.VR4
    Jay
    Grand Rapids, MI
    Hmm, no I'll be getting the piping from Porter Steel in Muskegon. Apparently they measure it in ID, so OD would be more in the 1.75 range. They will do the bending, 95 degree bend over 3.5inches (so not sure what dies they are using). Then all I will be doing is the fishmouthing/welding/mounting/painting etc.
    OH BTW: this is the rear bumper I am working on first since my stock one is bent, so might as well start with it. Once I get it done I'll be moving to the front.
  17. Nov 19, 2011 at 4:44 PM
    #257
    atvlifestyle
    Michigan
    01 trd tacoma
    Do you have a drawing of what your plans are?
    Some people will give you a hard time for using pipe not tubing. just make sure u have at least a 120 wall thickness. Difference between pipe and tubing is how its measured, pipe is ID measurement and tubing is OD.
  18. Nov 19, 2011 at 10:28 PM
    #258
    Taco.VR4
    Jay
    Grand Rapids, MI
    I have several different drawings and now one with dimensions. When I get a minute ill try to get one thrown up here.
    Basically what I think I will do is design the tube bumper, and seperately design d-ring retrieval points which will be separately attached to the frame there it meets the bumper. That way I can build the bumper to only have to take impact from one direction :p
    question: as far as i can see I wont need to remove my tow hitch/assembly for the new bumper. Is this right or am I missing something? (IE the stock bumper is in no way connected to the tow hitch?)
  19. Nov 20, 2011 at 4:41 AM
    #259
    atvlifestyle
    Michigan
    01 trd tacoma
    The bumper isn't attached to the hitch. You can just take the bumper off and retain the hitch.
  20. Nov 20, 2011 at 5:41 AM
    #260
    Ranch Runner
    Ranch Runner Member
    Dan
    Waterford, MI
    08 SR5 4X4 Debadged
    TacoTunes audio upgrade
    I agree, not many Tacos around.
