noob question about 4wd and 2wd lifting
Discussion in '5 Lug' started by mcleod90, Nov 28, 2010.
  1. Nov 28, 2010 at 6:01 PM
    mcleod90
    mcleod90 [OP] 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    why do 3" lift kits look different on 2wd than they do on a 4x4?
    is it because the 4x4 is already higher when its stock?
  2. Nov 28, 2010 at 6:10 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    6 lug 4wd Tacomas are higher than 5 lug 2 wheel drive Tacomas. All prerunner and 4wd Tacomas are 6 lug.
  3. Nov 28, 2010 at 6:40 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    ^exactly
    edit: thats also why there are so little choices for us :(
  4. Nov 28, 2010 at 7:25 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    so basically it will never look as high as a 4x4?
  5. Nov 28, 2010 at 7:27 PM
    cgs2k2
    cgs2k2 old man
  6. Nov 28, 2010 at 7:33 PM
    Jason'sLawnCare
  7. Nov 28, 2010 at 10:22 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    thanks for the help guys
    i really like the look of neslerrah's truck. do the shocks make any difference in ride height or is it mainly the readylift kit? and the tires
  8. Nov 29, 2010 at 7:05 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    My 5lugger is as high as stock Prerunner. I have fat Bob's lift kit & 31's on my truck. Harrelsen's truck is probably little taller than mine since he has 33's on his.
    Check out my build thread ;) Link is in my signature...
  9. Nov 29, 2010 at 10:46 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    what kinda milage do you get with it lifted? i want mine the hight of a stock 4x4 but i like getting 25mpg..:eek:
  10. Nov 29, 2010 at 11:09 AM
    05RedTaco
    Tony
    Scottsdale
    I have lead foot and 31's so I guesstimate about 20mpg or so. I bet the mileage suffers by few mpg, but it all depends on your driving habits...
  11. Nov 29, 2010 at 4:44 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    yours does look pretty good. have you thought of painting your stock rims? i would like to see what that would look like on your truck.
    and my lift kit would cost more since i would need to take it some place to get it installed
  12. Nov 29, 2010 at 5:04 PM
    113tac
    Stephen
    Northern Virginia
    i was quoted i think 250 or so for front and back here in virgnia so im not gonna get that done, i found a guy here that said he would help so if you do end up getting it lifted im sure someone on here would be willing to help if you ask!
  13. Nov 29, 2010 at 5:05 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
  14. Nov 29, 2010 at 10:59 PM
    mcleod90
    sean
    modesto ca
    05 double cab
  15. Nov 30, 2010 at 7:37 AM
    05RedTaco
    Tony
    Scottsdale
    Nope. The best you can do with 5lugger is to lift it & put 31's on it, which would make the 5lugger the same height as stock 6lug 4x4 or Prerunner. You can go little higher by putting on 33's, however you will need custom bumper or cut the hell out of your stock bumper to make the 33's fit.
    However lifted 5lugger with 31's & Powertrax No-slip locker will be pretty capable off road ;) I took my 5lugger off roading right after i got the lift with the stock 215/70/15 Dunlops and it did pretty good, exceeded my expectations...
  16. Nov 30, 2010 at 7:42 AM
    05RedTaco
    Tony
    Scottsdale
    The lift CAN be installed in your driveway with basic hand tools, don't be scared to turn a wrench, make sure you have 18" cheater pipe at least to loosen some of the bolts and you are golden. Make sure to get alignment afterwards.
    I am not painting the stockers. The stocker wont be on the truck long, eventually they will be replaced by 15x8 Cragar soft 8's in flat black.
  17. Nov 30, 2010 at 8:31 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    what gears you running? stock? or 4.10?
  18. Nov 30, 2010 at 8:55 AM
    05RedTaco
    Tony
    Scottsdale
    Stock gears. Going higher gears will only hurt your mpg.
  19. Nov 30, 2010 at 4:56 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    ok ill see what i can do.
    another noob question. the stock rims are 15x8?
    and what would be better to get first, lifting it or tires?
  20. Nov 30, 2010 at 5:23 PM
    05RedTaco
    Tony
    Scottsdale
    Stock rims are 15x6. Get lift first. With stock ride height you can't fit 31's...
