Oil Filter for 2.7 Liter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dustflap, Nov 19, 2015.
  1. Nov 19, 2015 at 8:31 PM
    Dustflap
    Dustflap [OP] Well-Known Member
    The dealer did an oil change on my 2015 2.7L. Tacoma and the oil filter they installed is a 90915-YZZG2. This filter appears to be a replacement for a 90915-YZZG1 which is for a 2008-2010 Highlander with a 3.3L. 6 cyl. Isn't the correct filter for the Tacoma a 90915-YZZD1 or YZZD3?
  2. Nov 20, 2015 at 2:46 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
  3. Nov 20, 2015 at 2:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    One year ago the dealer did a pre sale change on my truck and installed a 90915-YZZD3 as you suggest.
    I use Purolator Pure One or Wix filters (for many years, many marquees, including my SoloII car). When buying some supplies, I noticed the cross reference book showed the Purlator number to be the exact same as my '04 Highlander 3.3. Which is quite handy for me!
    1) if it fits and doesn't leak, I don't think the number matters. P/Ns on disposable items will change/supersede many times over the life of the vehicle.
    2) Toyota doesn't make filters. They contract with a low bidder, and they get painted/labeled as Toyota. So no need to obsess over 'OE' parts.
  4. Nov 20, 2015 at 2:59 AM
    TacoTaco15
    Jake
    VA
    taco2010trd likes this.
  5. Nov 20, 2015 at 3:02 AM
    TacoTaco15
    Jake
    VA
  6. Nov 20, 2015 at 3:30 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  7. Nov 20, 2015 at 4:06 AM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    My 2006 1GRFE V6 came with a large filter. My dealer sold me a G1 for my first oil change.
    I switched to the D3 after being enlightened by great forums like this one.
  8. Nov 20, 2015 at 4:19 AM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
  9. Nov 20, 2015 at 11:08 AM
    Dustflap
    I asked the Toyota parts guy about the filters and supposedly the "G" in the part # (YZZG2) means it has a pre lubed (greased) "O" ring on the filter. So maybe the "D" means Dry or Denso (the manufacturer)? Why does Toyota have to make things so complicated??
  10. Nov 20, 2015 at 11:12 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    I have a 2013 2.7. d1 is made for 2.7L and that's what the manual will tell you. When I was getting my toyotacare oil changed they always put the d3 which works just fine, its just a little longer so "more filter". When I did my first oil change after my toyotacare was done, I switched back to D1. Next oil change, im thinking of using D3.
    Had a similar question last year
    https://www.tacomaworld.com/threads/difference-between-yzzd3-and-yzzd1-oil-filter.314355/
  11. Nov 20, 2015 at 11:18 AM
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
  12. Dec 15, 2015 at 8:58 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I was searching for an answer to this too. I went to the parts counter and got 5 filters, they gave me the YZZG2's. I said I don't think that is right and the guy said they switched the filter or filter number for 2.7s to that. I was back a couple days later and a different guy was working. I asked him about it and he said the same thing. I have one on there now and it is working fine, although I might go to the D3's after these ones are used up.
    I wish I would have remembered to look at what came from the factory. I was just so happy by the time I got it off I wasn't even thinking about part numbers.
  13. Apr 12, 2017 at 9:34 AM
    lennyk
    lennyk Well-Known Member
    Mountain Top, PA
    Magnetic Gray Metallic
    Thanks for the info -
    Replacement oil filters for TOYOTA 90915-YZZD1:
    Brand Model
    AC-Delco PF 53
    AC-Delco PF1212
    AC-Delco PF1245
    AC-Delco PF13
    AC-Delco PF13CL
    AC-Delco PF13FCL
    AC-Delco PF1781
    AC-Delco PF2
    AC-Delco PF20
    AC-Delco PF2056
    AC-Delco PF2CL
    AC-Delco PF2FCL
    AC-Delco PF53
    AC-Delco PF53CL
    AC-Delco PF53FCL
    AC-Delco PF53M
    AC-Delco PF54
    ALFA-ROMEO 60574554
    ALLIANCE ABP/N10G-LF3335
    AMSOIL ASF57
    AMSOIL EAO57
    AMSOIL EAO58
    ARGO 12695
    ATLAS M-54
    AUTOEDGE AL3614
    Autolite for Oil Filters AL3614
    AUTOPAR FE213
    AUTOPAR FE259
    AUTOPRO 2348
    Baldwin B1405
    Baldwin B1430
    Baldwin B7020
    Baldwin BT223
    Baldwin BT8409
    Beck/Arnley 041-8077
    Beck/Arnley 041-8097
    Beck/Arnley 041-8162
    BIG A 92269
    BIG A 92335
    BIG A 92348
    Bosch 3330
    Bosch 72161
    BRAVO B241
    BRIGGS & STRATTON 491056
    BRIGGS & STRATTON 491056S
    BUKH 610J0050
    BUNTON BPL6006
    CAM2 C241
    Canadian Tire 17-1748-8
    CARCARE IOF3614
    CARQUEST 85335
    CARQUEST 85348
    CARQUEST 85374
    CASE 87409203
    CASITE CF2951
    CASITE CF3614
    CASTROL CAS3614
    CATERPILLAR 220-1523
    CENEX CO2835
    Champ LF525
    Champ PH2835
    CHAMPION OF10
    CHRYSLER 2647020
    CHRYSLER 4105409
    CHRYSLER 4105409AB
    CHRYSLER 4105409AC
    CHRYSLER 4273810
    CITGO C241
    CLARK 6513501
    CLARK 6513601
    CRUISEMASTER 224
    CUMMINS C600-211-2110
    Daihatsu 15601-87103-000
    DEFENSE DL3614
    DEFENSE DL9566
    DELPHI FX1017
    DENSO 115010-2191
    DENSO 115310-0261
    DENSO 150-1002
    DENSO 150-1003
    DENSO 150-2010
    DEUTSCH D366
    Donaldson P502016
    Donaldson P550335
    Donaldson P550589
    DYNALIFE CN-3614
    Econo Lube L10241
    EVERGARD E2835
    FACET 335
    Filters Incorporated OF3614
    FIRESTONE TF-335
    FIRESTONE TF335
    FLAG C-3614
    Fleetguard HF28783
    Fleetguard LF16011
    Fleetguard LF3335
    Fleetguard LF3376
    Fleetguard LF3460
    Fleetguard LF3874
    FLEETRITE LFR-83335
    FLEETRITE LFR-83460
    Flying F PH3614AZ
    Ford 1S 7Z 6731 DA
    Ford 1S7G-6714-DA
    Ford 1S7Z-6714-DA
    Ford 1S7Z-6731-DA
    Ford BE8Z-6731-AB
    Ford USA 1S7Z-6731-DA
    Fram PH3614
    Fram PH7575
    FULLER 4304827
    GEHL 000361
    General Motors GM 19160689
    General Motors GM 19160690
    General Motors GM 19161274
    General Motors GM 19161275
    General Motors GM 21000872
    General Motors GM 25011520
    General Motors GM 25014441
    General Motors GM 7984778
    General Motors GM 89060466
    General Motors GM 89060498
    General Motors GM 94840078
    General Motors GM 96058042
    General Motors GM 9975120
    GONHER GP58
    GONHER GP58M
    GOODYEAR 222-4522
    GOODYEAR L335
    GRAND PRIX PH2835
    Grease Monkey GM10241
    Grease Monkey GM335
    Group 7 V241
    GULF GF-224
    HASTINGS HF1000
    HASTINGS LF157
    HASTINGS LF494
    HASTINGS LF550
    HASTINGS LF563
    HASTINGS LF589
    HAVOLINE T-29
    IAPCO A-0211-001
    IAPCO OF2
    IAPCO OF36
    IAPCO OF935
    INGERSOLL-RAND C25042
    INGERSOLL-RAND C25402
    INGERSOLL-RAND C26191
    IPD 10130
    ITM 11-10103
    ITM 11-11400
    ITM 11-11516
    ITM 11-17600
    ITM 11-19700
    ITM 111-0103
    ITM 111-7600
    ITM 111-9700
    ITM 111-9802
    JAGUAR C2Z 21964
    JIFFY LUBE HL3614
    JIFFY LUBE JL241
    JIFFY LUBE L10241
    John Deere AT1220338
    John Deere HE1220800
    K & N HP-1002
    K MART K-16
    K MART MP-16
    KENDALL K17
    KOHLER 52 050 02
    KOHLER 52 050 02S
    KOHLER 520-5002
    Komatsu 600-211-2110
    KRALINATOR L127
    Kubota 70000-36160
    LAZORLITE L11-1350
    LAZORLITE L11-1805
    LEE LF-2835
    LEE LF-2835HP
    LISTER-PETTER 201-55370
    LUBER-FINER P823
    LUBER-FINER PH2835
    LUBER-FINER PH2858
    Lucas Girling F6515
    Lucas Girling F6587
    Lucas Girling F6618
    Magneti Marelli 1AMFL00004
    Mann Filter ML 1003
    Mann Filter W711/80
    Mann Filter W712/37
    Mann Filter W712/38
    Mann Filter W712/43
    Mann Filter W811/81
    Mann Filter W920/80
    MARATHON PH2835
    MARATHON-LETOURNEAU PH2835
    Master Parts PH-2835
    Mazda LF05-14-302A
    Mazda LF05-14-302B
    Mazda LF10-14-302
    Mazda LF10-14-302A
    Mazda LFY1-14-302
    Mechanics Circle MOF 3614
    MELROE 6652366
    MICROGARD MGL3614
    MIGHTY M3614
    MILEGUARD MO3614
    MINIT LUBE PH2821
    Mitsubishi MD308302
    MOBIL L35098
    MOBIL M1-102
    MOBIL MO241
    MOPAR L-335
    MOPAR MO-409
    Motor Trend ML3614
    MOTORCRAFT EFL910
    MOTORCRAFT FL 793
    MOTORCRAFT FL 910
    MOTORCRAFT FL 910S
    MOTORCRAFT FL-910S
    MPA 2050
    MPA 2818
    NAPA 1269
    NAPA 1348
    NAPA 1374
    NEW HOLLAND 507107
    NEW HOLLAND 87415600
    NEW HOLLAND SBA140517020
    OMC 5031411
    OMC 778885
    ONAN 122-0406
    ONAN 122-0645
    ONAN 122-0679
    ONAN 122-0800
    ORIGINAL EQUIPMENT PLUS OF-530
    ORIGINAL EQUIPMENT PLUS OF-550
    ORIGINAL EQUIPMENT PLUS OF-830
    Parts Master 61215
    Parts Master 61348
    Parts Master 61391
    Parts Plus PH2835
    PENNZOIL PZ-21
    PERFORMAX PO-21
    PERKINS 140517000
    PHILLIPS 66 PO241
    POWER FLO SL10017
    POWER FLO SL10241
    POWER FLO SL20252
    PRECISION TUNE OF-161
    PRO-TEC 130
    PRO/GAUGE PGO-241
    PROMOTIVE PH241
    PRONTO PO-3614
    Purolator L10241
    Purolator L35098
    Quaker State L35098
    Quaker State QS3614
    ROCKHILL 61348
    ROVER LR025306
    SAAB 30 54 8485
    SAAB 91 44 445
    SAAB 93 18 6554
    SEARS 45205
    SECURITY SO-241
    SELECT 500 L1348
    SERVICE 1 OF241
    SERVICE PRO M241
    SHELL L35098
    SHELL SH29
    SIEG OS3614
    SIERRA 18-7884
    SIERRA 18-7915
    SILVERLINE 21348
    STP S3614
    SUNOCO O-21
    SUPERTECH ST3614
    Suzuki 16510-60B01
    Suzuki 16510-60B10
    Suzuki 16510-60B11
    Suzuki 16510-73000
    Suzuki 16510-73001
    Suzuki 16510-73001-000
    Suzuki 16510-73002
    Suzuki 16510-73002-000
    Suzuki 16510-82001
    Suzuki 16510-82703
    Suzuki 16510-83000
    Suzuki 16510-83010
    Suzuki 16510-83011
    Suzuki 16510-83012
    Suzuki 16510-87J00
    TARGET SF2835
    Toyota 00120-00009
    Toyota 00120-00012
    Toyota 00120-00014
    Toyota 08922-02004
    Toyota 08922-02010
    Toyota 08922-02011
    Toyota 15601-13051
    Toyota 16510-83011
    Toyota 32623-12620-71
    Toyota 32670-12620-71
    Toyota 90915-03002
    Toyota 90915-03005
    Toyota 90915-20001
    Toyota 90915-20002
    Toyota 90915-20003
    Toyota 90915-20004
    Toyota 90915-YZZA1
    Toyota 90915-YZZB1
    Toyota 90915-YZZB5
    Toyota 90915-YZZB9
    Toyota 90915-YZZD1
    Toyota 90915-YZZD3
    Toyota 90915-YZZG1
    Toyota C0120-00014
    Toyota C0120-00015
    TRUST PH2835
    UNIVERSAL 299381
    UNOCAL PF2835
    UNOCAL PF9A
    VALUTEST 42143
    VALUTEST V2348
    VALVOLINE VO25
    VERA 10-01337
    VERA 10-01352
    VERA 10-01402
    VERA 10-50389
    Volvo 834337
    Volvo 834337-8
    VW Group 04E 115 561B
    VW Group 7B0 115 561
    WALMI WS-3614
    WARNER PH2835
    WESTERN AUTO 74-5884-7
    WHITE 33-0083836
    Wix 51348
    Wix 51762
    Wix 51785
    Wix 57023
    Wix 57181
    YAMAHA 69J-13440-01-00
    YUGO 46620004
    YUGO 46624209
    ZINGA BE10-18
    Mac4Willy likes this.
  14. Apr 12, 2017 at 9:36 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Use Toyota oem, just had the dealership do my last oil change ($13 coupon couldn't pass up) they used d3. I have the 4.0 L
