Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Dec 30, 2019 at 4:59 PM
    Emanresu
    Emanresu Well-Known Member
    Just got my "Warranty Enhancement" letter today from Toyota for my 3rd gen regarding frame inspection and coating
    pete37, Manfred and RoamingGnome like this.
  2. Dec 30, 2019 at 5:06 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Dealer in Burlington was just starting their training on the L32 limited service campaign about 2 weeks ago.
    I'll still be oil spraying my truck every year though.
    Atlas86, Manfred and llamasmurf like this.
  3. Dec 30, 2019 at 5:18 PM
    Emanresu
    Yup, same. I put several coats of Permalac on the underside of the body and frame when it was still new and prior to oil spray and now soak it with oil spray myself spring and fall.
  4. Dec 30, 2019 at 5:18 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Winch is in, :)
    not wired yet though, :(
    as I'll have to make a bracket to move the controller box right up near the battery.
    I'll finish making the template tomorrow...
    Figured out my wire paths, going to make some support brackets...
    Ran the winch in forwards and reverse before I pulled off the front bumper and mounted it in.
    Didn't drop the front end height at all, and didn't notice the extra weight at all when cornering or braking.
    Rides a little smoother over light bumps now.
    Loving these 8112's.
    Sloweburn, Atlas86, Snail81 and 4 others like this.
  5. Dec 30, 2019 at 5:27 PM
    RoamingGnome
    RoamingGnome Well-Known Member
    Gerry
    Ontario, Canada
    2017 Tacoma TRD OffRoad
    Mostly stock for now...
    ...Me too...
  6. Dec 30, 2019 at 5:32 PM
    cwisema
    cwisema Well-Known Member
    Acton, Ont.
    2017 MGM DCSB TRD Sport
    Me three...
    Does it mean they will spray the coating or replace the frame depending on weather you have holes, or is there a scenario where they will do nothing?
  7. Dec 30, 2019 at 5:37 PM
    Emanresu
    They want you to have the coating done to extend your frame warranty. Personally, I would never use a coating like that.
    Joe23, over60 and 3JOH22A like this.
  8. Dec 30, 2019 at 5:39 PM
    Emanresu
    Especially after the truck has been on the road for awhile. I wonder what they do with people who have already oil sprayed...just coat over it???
  9. Dec 30, 2019 at 5:50 PM
    cwisema
    Acton, Ont.
    Well my truck has been on the road for a couple years and has some surface rust here and there. I've never oil sprayed it. What is the issue with the coating?
  10. Dec 30, 2019 at 5:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The frame rust campaign #173 bulletin for 2nd gens instructed the mechanic to pressure wash the frame, remove flaking rust with wire brush/scraper, then brush coat the frame with etching primer. Whether the mechanic follows all the steps thoroughly is questionable. If you've been oiling the frame yearly and it looks to be in no danger of developing rust holes, just ignore the campaign.
  11. Dec 30, 2019 at 6:08 PM
    Emanresu
    Interesting. The amount of time it would take to do this properly...can’t see it happening
    over60 and Joe23 like this.
  12. Dec 30, 2019 at 6:10 PM
    Emanresu
    The surface rust and the salt will just be hidden under this coating to continue to rot your frame out of site.
  13. Dec 30, 2019 at 6:34 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Manfred and Emanresu[QUOTED] like this.
  14. Dec 30, 2019 at 6:51 PM
    Ares
    Ares Well-Known Member
    Darek
    Hamilton , ON
    2015 LTD DCLB
    Joe23 and 3JOH22A like this.
  15. Dec 30, 2019 at 7:09 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    It's a rubberized coating that after a few years dries out and cracks letting moisture and salt get in aiding in holding that moisture and salt on the frame
    Lumberjackcoma likes this.
  16. Dec 30, 2019 at 7:11 PM
    Joe23
    This has been all over Instagram pages.
    Guy is a cunt and went where numerous signs say not to go. This wasn't an adventurous trail gone bad.
    This was a stupid fucking cunt the adds to ruining public land access by being a selfish twat that thinks rules don't apply to him.
    llamasmurf and 3JOH22A like this.
  17. Dec 30, 2019 at 8:26 PM
    2Dayvid
    2Dayvid Very little known member
    Dayvid
    Kitchener Ontario Canada
    2023 Tacoma Access Cab Black TRD OR Auto
    Yep! Got mine in the Post today too. For my 2nd gen.
    Shveet and tacoma16[OP] like this.
  18. Dec 31, 2019 at 2:18 PM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    But is this the same stuff? I had that black stuff done when I bought my truck and it was gone within the year. I was reading in a thread, a guy that works for Toyota was saying this stuff is waxy...
    "Other wise the frame will have a CRC coating performed inside the front half of the frame, this includes the inside of the front boxes section and certain areas of the open mid section ( C channel ). There will be no coating at the rear frame sections. The inside frame rails will be dried with a frame dryer for 3 hours to ensure any water inside the frame is removed before the cleaning process can be performed. After the cleaning process is performed the technician will use an endoscope to inspect the inside of the frame before the CRC application can proceed. A heated wax based CRC is used to coat the inside of the boxed frame and locations of the mid open section. There will be no exterior coating in this campaign like used in the 2010 and previous years.
    The front wheels, suspension braces and front bumper will be removed for the cleaning and application process."
    https://www.tacomaworld.com/threads/frame-coverage-for-2011.590939/
    What they did to my truck just looked like a flat black paint.
  19. Dec 31, 2019 at 3:30 PM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    I know rusty frames and protective coating are really cool and shit...
    Happy New Year
    Atlas86, Tridet167, Shveet and 7 others like this.
  20. Dec 31, 2019 at 4:01 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Happy New Year! May your Tacos rust less, see more of dirt and less of malls! :santa::woot:
