Paint chips, in rust stage
Discussion in 'Detailing' started by DanGer, Aug 9, 2009.
  1. Aug 9, 2009 at 10:40 AM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I browsed around a found a few threads like this one:
    http://www.tacomaworld.com/forum/detailing/30697-terrible-chips-paint.html
    But I am wondering what the best course of action to take is if you have a small paint chip that is showing rust. It was on my truck when I got it and I realized letting it sit for a year probably has not helped. But that is the reason I want to take care of it.
  2. Dec 10, 2009 at 3:23 PM
    berdinkerdickle
    berdinkerdickle New Member
    Horizon Blue 2WD SR5
  3. Dec 10, 2009 at 3:27 PM
    berdinkerdickle
  4. Dec 13, 2009 at 3:57 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Kill the rust
    Touch up the paint with paint that matches. Factory touch up bottle works.
    Keep the paint as flat as you can as you apply.
    Let it dry, Multi coats recommended if deep area
    Sand with 400, then 600, then 800, 1000 grit wet dry
    Stay off the good paint.Get the repair flat
    Compound out area with a light compound
    Be patient and you can get it back to factory look
