Pioneer AVH 4400 How do you enable the video feature?
Discussion in 'Audio & Video' started by kh7nm, Feb 28, 2012.
  1. Feb 28, 2012 at 11:28 PM
    kh7nm
    kh7nm [OP] Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    How do you enable the video while driving? I have read to ground the wire that suppose to hook up to your parking brake. Tried that it does not work any other ideas? Either then that the deck sounds way better then the stock head unit.
  2. Feb 28, 2012 at 11:37 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Search DVD bypass here, or YouTube, you'll find an answer.
  3. Feb 28, 2012 at 11:42 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    It should work. How did you ground it?
  4. Feb 29, 2012 at 12:52 AM
    t4daddy
    North Alabama
  5. Feb 29, 2012 at 12:57 AM
    EODTech08
    EODTech08 Well-Known Member
    Jacob
    Oahu, HI
    '11 Access Cab TRD Off-Road
    FX-R Retrofits, Hood Struts, aFe CAI, Wet Okoles, Pioneer AVH-P8400BH Head Unit,
    x2
    I had to put a switch under the steering wheel in my Tundra for mine.
  6. Feb 29, 2012 at 6:34 AM
    kh7nm
    Miles
    Ewa Beach, Hawaii
  7. Feb 29, 2012 at 6:35 AM
    1989supraturbo
    1989supraturbo Well-Known Member
    British Columbia, Canada
    2012 DCSB TRD 6 Spd MGM
  8. Feb 29, 2012 at 7:45 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
  9. Feb 29, 2012 at 8:19 AM
    kh7nm
    Miles
    Ewa Beach, Hawaii
    I found one in my workshop. Free 99 LOL. Just doing this mod for the kids to watch on the way home getting stuck in traffic.
  10. Feb 29, 2012 at 10:39 AM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    I will probably do this before i install mine, Its kind of annoying how many adapters this thing needs to run like the factory stereo. Steering wheel control adapter, JBL adapter, This relay... It ends up being over a hundred dollars just for adapters. WTF
  11. Feb 29, 2012 at 10:50 AM
    bluuge
    bluuge Well-Known Member
    brian
    Costa Mesa, CA
    06 White Tacoma TRD Sport
    x2 on the relay method... did it on mine
  12. Feb 29, 2012 at 10:52 AM
    shadowsecho
    shadowsecho Well-Known Member
    Charleston, SC
    11 Taco 4x4
  13. Feb 29, 2012 at 10:25 PM
    kh7nm
    Miles
    Ewa Beach, Hawaii
    Installed the relay works like a champ. Run down installed Pioneer AVH-4400BH head unit as for adapters Pioneer CD-IU200V I pod Interface cable, Axxess ASWC {Steering Control} PAC TATO JBL Inteface with stock amp & DD In dash Receiver kit from Crutchfield and the relay to enable video when driving. Blue tooth works great and the reverse cam is interfaced with the pioneer deck and it has both pictures on the deck and mirror using these two post for the wiring http://www.tacomaworld.com/forum/2n...-view-camera-switch-dash-mod.html#post3777072 & http://www.tacomaworld.com/forum/2nd-gen-tacomas/42644-09-always-rear-view-camera.html Only problem I am having is the 2 clips does not latch at the top of the dash receiver kit I think I have to move the cables and black box behind the receiver around to make it fit because it is a tight squeeze back there. Since everything was taken a part I did the mod on changing out the LED's on the steering wheel and the clock white and blue. Here is a post that I used http://www.tacomaworld.com/forum/lighting/87534-2010-clock-lcd-led-backlight.html Thinking of doing the rocker switches next changing out the LED's to white can't stand the amber light from 80's. I will post some pictures later. Thanks for everybody help. The sound with the new deck is like day and night totally awesome. Gotta hear it to believe it.
  14. Mar 1, 2012 at 6:09 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    It does take some working around to get everything back there. A couple of notes, make sure that any of the male connectors plugging into the back of the unit are not too long. I found that my RCAs and the AUX connectors that I had were too long and would interfere with something back there. Other then that you just need to work the wires and boxes off to the sides and top in order to get it all the way back.
    For the boxes, on my 4300 I put the steering wheel box over by the glovebox to get it out of the HU area, I put my HDRadio box up in the HVAC plumbing Y, and my relay went off to left side.
  15. Mar 1, 2012 at 6:14 AM
    shadowsecho
    Charleston, SC
    11 Taco 4x4
    How is the reverse cam interfaced with the backup camera?!? Which section of those two posts did that? Also does your dash kit make your aux out (factory one by the cigarette lighter) work?
    I agree about the color of the stock LED's...I dont know why toyota insists on keeping that old Amber color. I'm excited about getting my 4400bh.
  16. Mar 1, 2012 at 6:55 AM
    kh7nm
    Miles
    Ewa Beach, Hawaii
    The first post is for the Reverse wire for +12 to connect to the violet/black wire coming off pioneer deck located on connector IN1. The second post is the wrong post my bad here is the right post to get the signal from the connector below IN1 location to the pioneer deck RCA brown input.http://www.tacomaworld.com/forum/audio-video/30889-oem-camera-connection-below-dash.html
    As for the AUX to work with the pioneer deck from the JBL system, no it does not work. Looks like there is another harness with 5 or 6 wires that crutchfield does not give a harness for, but since the Pioneer deck comes with an USB output then I will be using that for my Ipod so don't really need that AUX input.
  17. Mar 1, 2012 at 6:57 AM
    kh7nm
    Miles
    Ewa Beach, Hawaii
    I gotta try take it apart this weekend again and move the wires around and boxes.
  18. Mar 1, 2012 at 7:14 AM
    shadowsecho
    Charleston, SC
    11 Taco 4x4
    Awesome! I think I will do both mods as well. Thanks for the links. I'm amazed by how helpful this community is.
  19. Mar 1, 2012 at 7:53 AM
    shadowsecho
    Charleston, SC
    11 Taco 4x4
    I am thinking that I will probably unplug the factory mirror lcd and just use the pioneer for backing up instead of having both turn on.
    How bad does having both screens plugged in degrade your backup camera quality?
    Does the Pioneer 4400bh boot up fast enough to use it as a primary backup camera LCD? Basically, if you jump in your truck, crank it up and put it in reverse, would the screen have enough time to power on and show your camera feed?
    Ty for all the info.
  20. Mar 2, 2012 at 10:06 PM
    Dave M
    Dave M Well-Known Member
    Dave
    Seattle WA
    12 S/C AC TRD Off-Road 4x4
    Supercharger Sunroof Leather Seats TRD Exhaust TRD Short throw Shifter
    I have both my 4400 and my mirror running my backup cam. I used the same splice method with the D-sub pins. I don't notice any degradation during the day, at night it's a little pixellated on the Pioneer, but not too bad at all.
