Prerunner to IFS 4x4 (FJ case) list of conversions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toy Yoda, Jul 12, 2013.
  1. Jul 12, 2013 at 7:29 AM
    Toy Yoda
    Toy Yoda [OP] gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    People seem to periodically ask about how to convert their prerunners to 4x4's (non SAS) and what all is required for it etc. well i'm really bored at work so i'm attempting to consolidate some of the threads that i've found from this forum and others. Bear with me here as i slowly collect more information. Any input or links to other threads is greatly appreciated as well!
    without screwing with the computer, you'll need something to trick the front diff into thinking its linked to the 4x4 ecu, which you dont have because you're a prerunner, doh. fortunately rock solid toys has developed an ADD harness that you simply have to hook up to the actuator that you wire a switch to so none of the 4x4 electronics will be needed.
    what you'll need (taken from VanCity4x's thread) and seems to be the most accurate-
    A750F 4x4 Transmission
    VF2A FJ Crusier (Automatic) Transfer Case
    Tacoma Front Diff w/ mounting hardware
    CV axles
    4x4 hubs/bearings
    CV nut/seals
    Front drive shaft
    ADD Harness - replaces ecu
    Custom tranny crossmember
    Modified rear drive shaft
    modified y-pipe exhaust
    +large assortment of mounting bolts, seals and misc parts
    so far this is what i've found, as most people want a manual T case when they convert because a little switch is ghey.
    Rock Solid Toys-Marlin crawl box and FJ t case modded for twin sticks, with ADD actuator
    http://www.tacomaworld.com/forum/2nd-gen-builds/233527-first-2nd-gen-2wd-4wd-ifs-conversion.html
    VanCity4x- using FJ T case without twin sticks or crawler box
    http://www.tacomaworld.com/forum/2nd-gen-builds/285377-vancity4x-prerunner-convert-build.html
    PSUTaco85 (was already 4x4 but put a manual FJ T case in)
    http://www.tacomaworld.com/forum/2nd-gen-builds/156506-psu-taco85s-swb-build.html
    idk if this will help anybody, but it might eliminate some of the "im butthurt and want to convert to 4x4 threads"
    enjoy:mudding:
  2. Sep 19, 2013 at 12:51 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Thanks for the info
  3. Dec 18, 2013 at 12:18 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    thanks for the consolidation, have been lookin into this and have seen both threads in the past. Lookin at doin this to my PreRunner after savin up some $$$, then I just gotta find someone willin to help after I aquire all the parts
  4. Dec 27, 2013 at 6:46 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
  5. Dec 31, 2013 at 10:01 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    that looks promising, may try that to eliminate finding the A750F 4x4 Trans
  6. Feb 19, 2015 at 9:52 AM
    jp05
    jp05 Well-Known Member
    Juan
    TN 931
    2016 Tacoma SR, DCSB, 4x4, Leer Top.
    bump
  7. Feb 19, 2015 at 9:57 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
  8. Jun 22, 2016 at 12:05 AM
    1uzrnr
    1uzrnr The NotaRC 4runner :D
    Washington
    86 Samurai stockish
    Couple
    What about the 4cyl guys?
