Raz4back's 2012 MGM Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Raz4back, Jul 8, 2012.
  1. May 11, 2014 at 10:06 AM
    #81
    tacopaulo
    tacopaulo Tanned
    Paulo
    Raleigh, NC
    red truck
    I like your truck. Are you using the stock trd off-road springs? Thinking about buying just the billies for my trd off-road set at 1.75 and the 1.5aal as well.
  2. May 12, 2014 at 5:55 AM
    #82
    Raz4back
    Raz4back [OP] Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    Yep, I'm just running the stock springs
  3. May 20, 2014 at 12:20 PM
    #83
    Kudagra
    Kudagra Member
    SoCal
    2013 Prerunner TRD Sport DCLB
    This is a sick build you have here man. I have been spending hours on the TW site looking for a build to follow, and I wish I would of have found yours a couple weeks ago.
    I am doing almost the same wheel/suspension setup as you have done. just received my 5100's on my doorstep today actually, and I will be setting them to 1.75" (Front only). I am also getting the exact same wheels with probably the Nitto Terra Grapplers A/T. My question to you is, do you plan on getting 255's in the future when you get new tires? Or would you prefer going with 265's or even 275s? I just cannot decide on if a bigger tire than yours would look good with the -12 offset and only 1.75" lift. Then again, you also save a chunk of money with going with the smaller tiers (and they look awesome with the current offset).
  4. May 21, 2014 at 9:50 AM
    #84
    Raz4back
    Brett
    Benton, Arkansas
    Thanks!
    To answer your question, 255s and 265s are roughly the same size. When I replace my tires I'll probably end up going with Duratracs in a 265 (just because that's the size they are available in). The only reason I went with 255s is because I wanted Trail Grapplers and 265s weren't available in a C load range. I was trying to avoid running an E range tire because of the added stiffness to the on road ride.
    I don't think you would see a noticeable difference between 255s and 265s. I'd stay away from 275s unless you are willing to do some trimming. At 1.75 you are going to rub pretty good with 275s without some mods.
  5. May 21, 2014 at 10:16 AM
    #85
    Kudagra
    Kudagra Member
    SoCal
    I think I will just stick with the Terra Grapplers then (probably SL rating). The Duratrac is a sick looking tire, but I won't be doing hardly any off roading with where my current job has me so I would benefit from the Nitto's price a lot more.
    Thanks for such a quick reply!
  6. Jul 4, 2014 at 2:35 AM
    #86
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
    Sweet truck man. Looking good so far. I was just reading through your thread because you are running 255/75/17 tires. I am looking at getting method standards with Duratracs in that 255/75/17. FYI, they have them now!
  7. May 16, 2015 at 7:25 AM
    #87
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    How's the black paint on the front valence holding up?
  8. May 20, 2015 at 6:57 PM
    #88
    Raz4back
    Brett
    Benton, Arkansas
    It looks just like it did the day I painted it.
  9. Jan 22, 2016 at 6:27 AM
    #89
    tethsojh
    tethsojh Well-Known Member
    Quad Cities, IL
    2000 Toyota Tacoma TRD 4WD Extended Cab
    I know this thread is old, but hopefully you respond.
    I see you're running 255/75/17's. And that your wheels are 17x9. Have you encountered any issues at all? I've been searching for months on this. I want that same sized tire (not necessarily same brand) and wheel but every forum on the internet says the maximum wheel width with 255's is 8.5".
    Is this not true? Or is it specific to tire brand/model? eg: youre running Trail Grapplers which work for you. Say i ran BFG.... Would it not work for me?
    The claim is that 255 can only run wheel width between 7-8.5".
    I'm just afraid of ordering wheels and getting tires and it not working.
  10. Feb 25, 2016 at 8:43 AM
    #90
    Raz4back
    Brett
    Benton, Arkansas
    I haven't had any problems. I'm now running Duratracs in the same size and still haven't had any problems. The only way I would foresee an issue would be if you aired way down.
    tethsojh[QUOTED] likes this.
  11. Apr 19, 2016 at 8:46 PM
    #91
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    Do you find it to really be an exact match? Did you have to wet sand the clear coat? Thanks.
  12. Apr 20, 2016 at 6:21 AM
    #92
    Raz4back
    Brett
    Benton, Arkansas
    Yes, the color is spot on. I didn't wet sand so they aren't as glossy, but it isn't noticeable at all. I've been asked several times how I got color matched mirrors and door handles on an Off Road.
  13. Apr 20, 2016 at 7:50 AM
    #93
    alvinfromhawaii
    Northern California
    Did you also color matched your grill surround?
  14. Apr 20, 2016 at 8:29 AM
    #94
    Raz4back
    Brett
    Benton, Arkansas
    Yes, it matched great as well. I did end up eventually buying a color matched surround because when you inevitably get rock chips the silver really stands out.
  15. Apr 20, 2016 at 8:33 AM
    #95
    alvinfromhawaii
    Northern California
    That was my fear of painting the chrome surround. Thanks for the info.
  16. Jul 30, 2016 at 7:34 PM
    #96
    j_sav115
    j_sav115 Well-Known Member
    SC
    07 Silver TURD SPRT
    Getting to start all over :)
    Really looking for this Crossfab lightbar but I cannot find anything. Do you still have any info on where you got it?
  17. Jul 31, 2016 at 3:48 PM
    #97
    Raz4back
    Brett
    Benton, Arkansas
    I got it straight from crossfab. I think they went out of business. I sold mine to another member that was having the same problem you are
  18. Jun 13, 2017 at 3:11 PM
    #98
    GUN SLINGER
    GUN SLINGER Well-Known Member
    Colorado
    2018 TRD OFF ROAD DCSB QUICKSAND
    Nice I got the same light bar
