Ripped off factory black skid plate from TRD Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sgrounds22, Dec 26, 2012.
  1. Dec 26, 2012 at 1:00 PM
    sgrounds22
    sgrounds22 [OP] Active Member
    Plano, TX
    '12 Pre-runner TRD Sport
    Destroyed it going over some railroad tracks. It was dark and I couldn't see, but they must have been pretty serious.
    Anywhoo, I read on some other threads that you bolt the silver coated skid plate accessory over the original. That's not a possibility for me. Is there an alternative?
    TIA
  2. Dec 26, 2012 at 1:02 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '12 DCSB 4x4 SR5
    Might this be what you be looking for? :)
    Many companies make skid plates..Mine is All-Pro..but there is relentless, budbuilt..ATO..all sorts..but mainly the same design
  3. Dec 26, 2012 at 1:13 PM
    Matt123
    Matt123 Well-Known Member
    www.bpfabricating.com
    West Coast
    Toyota Tacoma
  4. Dec 26, 2012 at 3:03 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  5. Dec 26, 2012 at 3:08 PM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
  6. Dec 27, 2012 at 6:02 AM
    sgrounds22
    Plano, TX
    I don't take my taco off-roading. Unless you consider my little mishap urban off-roading:)
    So, back to my orig question. Will the TRD plate replace the stock black plate or do I need to install the stock plate before installing the TRD aluminum plate?
    TIA
  7. Dec 27, 2012 at 6:11 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    For $50-100 more, you can have a real skid plate vs the cheesy TRD Plate. You would be better off just replacing the original skid if you do not go aftermarket. :cool:
    cosmic stardust likes this.
  8. Dec 27, 2012 at 6:22 AM
    sgrounds22
    Plano, TX
    How might I go about getting the part #?
    TIA
  9. Dec 27, 2012 at 6:41 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
  10. Dec 27, 2012 at 6:44 AM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    I believe the TRD bolts over the black one as the TRD is very thin for pretty only.
  11. Dec 27, 2012 at 6:49 AM
    sgrounds22
    Plano, TX
    Not what I wanted to hear. If that's the case and the cost of purchasing both parts is compatible to an aftermarket plate then I guess I will have to go aftermarket.
    Thanks for the info.
  12. Dec 27, 2012 at 6:53 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I would just go aftermarket and be done with and have something that can take a beating. No sense replacing and adding the accessory one if you may end up just destroying again.
  13. Dec 27, 2012 at 8:36 AM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    Forget the skid that comes with the Tacoma. It is for nothing more than stopping small rocks and dirt from hitting. There are several fabricators on here that produce very sturdy skid plates that do the job by themselves. I rattle canned primer and bedliner on mine.
  14. Dec 27, 2012 at 8:43 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Go to dealership after dark remove stock black skid from a truck off the lot and put it on your truck
  15. Dec 27, 2012 at 8:49 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    If you're not off roading then why do you need a skid plate anyway?
  16. Dec 27, 2012 at 8:50 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    And i think we need a little more explanation on how this happened:p
  17. Dec 27, 2012 at 9:06 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    how about no?
    aftermarket would resolve this and future issues. what the OP needs to look at is his usage and the costs/materials that would suit his needs.
    if he wants to re-bolt a stock one on, they go for cheap and sometimes free on here in the B/S/T area.
  18. Dec 27, 2012 at 9:07 AM
    The_Hodge
    SC
    engine protection from road debris
  19. Dec 27, 2012 at 9:16 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    I think there is a guy on here who makes a 10 g plate vs a 1/2" plate snoop throught the second gen bst
  20. Dec 27, 2012 at 9:30 AM
    DikDikerson
    DikDikerson Well-Known Member
    Devon
    Calgary
    13' 4x4 DCLB TRD Sport
