SMKYTXN's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2012.
  1. Sep 2, 2012 at 8:07 PM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Here's a table of contents for my build, there are more pictures throughout the thread, but the links below are some of the highlights.
    SOLID AXLE SWAP
    FJ Transfer Case - Twin Stick Modification
    Chevy 63 swap and 18" rear king install
    Onboard Co2 install and Auxillary Fused relay panel install
    Wheeling pics from South Padre and Mill Creek OHV, Fayetteville Arkansas
    Wheeling pics from Matagorda
    Home truck maintenance setup
    Hardwired dash cam install
    Fire extinguisher install
    Snorkel mod
    Wheeling at Shiloh Ridge, January 2014
    Scrub bar build
    Front diff with 4.10's and an ARB install
    Wheeling at Shiloh Ridge March 2014
    Trailer brake controller install
    Superwinch Tiger Shark 9500 install
    SPC Light Racing UCA Spec Ride bushing install
    Feneix Titan-X 5 LED install in ARB bumper (Replacement for the turn signals in the old style ARB)
    Exhaust crossover re-route
    Hybrid transmission and transfer case skid, UHMW and 1-1/2" sch 40 pipe
    Amazon COB LED rock lights
    Flatbed/tube bed build
    Wheeling Pics
    Trees Ranch Off-Road
    Megarun 2016
    Here she is the day after I bought her. I drove to Dallas to pick up a bike that I was having restored the day after I got the truck.
    My Colorado that I traded in. It was a good truck, but I needed something more.
    2011 Tacoma TRD Sport
    Suspension:
    - KING extended travel with RR up front, 700lb springs
    - Skyjacker 5" lift chevy 63's
    - King 18" piggyback rear shocks
    - Lightracing upper control arms
    - Spidertech 1.25" spacers
    - Swaybar delete :D
    Armor:
    - ARB front bumper
    - Bruteforcefab rear bumper (Now gone to make way for the new bed)
    - My own version of a high clearance rear bumper can be found in the flatbed build
    - Beefed Sliders
    - Custom built scrub bars (courtesy of Colinb and Overland Off-road)
    - Allpro IFS skid
    - Hybrid UHMW and pipe transfer case and transmission skid (Built by yours truly)
    Winch
    - Superwinch Tiger Shark 9500
    Lighting
    - Hella 700FF converted to 55w HID
    - Custom rock lights
    - Phoenix dual mode flashers and reverse lights
    - Phoenix 5" LED's in the ARB
    Electrical
    - NSA Switch Panel
    - Tacoma tech deck
    Tires
    - Hankook dynapro MT's, 315/70/17)
    Drivetrain
    - 4.10's
    - ARB RD111 (front)
    - ARB RD129 (rear)
    - ARB CKSA12 compressor
    Interior
    - Weathertech digital fit floor liners (had to trim the driver floormat to clear the clutch)
    - Wet Okole seat covers (All black with red TRD logo)
    - Techdeck
    Body
    - Fender flares removed (My thread on making plugs to fill the holes)
    - Um... I ripped the bed off and started from scratch
    - Prinsu Roof Rack
    Completed mods
    - Snorkel mod
    - Superwinch Tiger shark 9500 installed
    Future mods
    - New front bumper of my design
    - New IFS skid of my design
    To-Do list
    - Big 3 upgrade
    - Install the following (Parts already sitting at the house)
    * Upgraded body mounts
    Other things I need/want to add to the truck:
    - Synthetic winch rope from Snevey's, probably 3/8" - 90' in red
    - 2nd battery with controller
    - Some sort of solar charging syste
  2. Sep 2, 2012 at 8:07 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Onboard CO2 install
    Wheelers offroad adjustable CO2 regulator
    I used rivnuts to attach the powertank 10lb tank holder to the front of the bed. Using 6 rivnuts was overkill, but I figure if I ever need a M8x1.25 bolt I'll have a couple extra hiding behind my tank.
    I made my own rivnut install tool out of a piece of 1/4" aluminum barstock. By holding the longer bolt still and turning the nut against the bar you can compress the rivnut. It worked like a champ and was cheap.
    Tank location
    Powertank 10lb tank holder.
    All done.
    Auxilliary Fuse Block
    I used the same location that most everyone else uses for their fuse block, but did mine a bit different. I built a frame out of aluminum angle that would hold a small pelican box. The box isn't completely water tight anymore, but it'll shrug off a good amount of water.
    The ARC fused relay panel installed in the box.
    Installed in the truck. There was an extensive wiring harness sent with the block, which you can see coiled up on the fuse panel. You can also see the brace I added to keep the shelf from moving too much. The threaded holes in the fender well are nice, but offer little lateral resistance.
    Beefed Sliders
    I was very impressed with the design of these sliders. The main selling point was the location of the legs that connect to the frame. There is no significant overhang on either end of the slider.
  3. Sep 2, 2012 at 8:07 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Wheeling pics
    A little urban offroading just for fun.
    South Padre
  4. Sep 2, 2012 at 8:11 PM
    Large
    Large Red
    bout time..
  5. Sep 2, 2012 at 10:17 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
  6. Sep 3, 2012 at 5:42 PM
    JPR21
    JPR21 Active Member
    Joe
    San Antonio/San Angelo, TX
    12' Toyota Tacoma 4 Cyl. Prerunner
    Were the padre island pics from this weekend (labor day weekend)? Man i had a blast down there, just got back home today from there (reluctantly!)
  7. Sep 3, 2012 at 5:59 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Will your on board air be able to power your lockers?
  8. Sep 3, 2012 at 7:04 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    The SPI pictures were from the meet earlier this year. It is a nice place to visit.
    That's the plan. Powertank makes a nice little manifold that will let me power the lockers with the CO2. I'm planning on having a small 20oz CO2 tank as a backup as well.
  9. Sep 3, 2012 at 7:11 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    X2
    glad you finally got a build up nathan..... Looks good :thumbsup:
  10. Sep 18, 2012 at 5:20 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    There are enough accessories that need power so if I can keep something off the electrical system I'm going to do it. I'm still considering going full pneumatic with manual air switches for the lockers, but the thought of bringing four air lines into and out of the cab doesn't sit well with me.
    CO2 will also let me run air tools, which up till now I haven't been able to do since I'm in an apartment without a garage. Therefore no room for a compressor. The 10lb co2 tank doesn't take up much space.
  11. Sep 22, 2012 at 4:20 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Matagorda 2012
    It was beach cleanup weekend at Matagorda. Jesse and I went down and did our part. There wasn't anything challenging, but it was a fun trip.
  12. Sep 23, 2012 at 12:18 PM
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    Damn! That's a great build!!! Love the look of the tan plastidip!
    Question: do you rub the fenders with the 1.5" spacers?? And did you remove the sway bar??
    Love your truck!!
  13. Sep 23, 2012 at 3:39 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thanks bud. Yes, the 12.5 inch wide tires do rub the back of the fenders a little bit. The cab mount chop keeps the tires off of the frame, but there is still some offending plastic that needs to go away.
  14. Nov 7, 2012 at 6:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Great looking truck OP
  15. Nov 10, 2012 at 5:34 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thank you sir.
  16. Nov 13, 2012 at 1:25 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Great looking truck man!
  17. Nov 13, 2012 at 3:26 PM
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    How are the generals off road?
  18. Nov 13, 2012 at 4:47 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thanks
    They're fantastic in the sand and rocks. I don't have too much to compare them too, but I like em.
  19. Dec 30, 2012 at 2:16 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    nice build man
  20. Dec 30, 2012 at 2:43 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Wow good looking truck OP!
