Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Jul 27, 2015 at 4:16 PM
    #1001
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    I would go spindle.
  2. Aug 12, 2015 at 2:22 PM
    #1002
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Question: Camburg UCA's come with the option of either a uniball joint or a MOOG joint. Icon and TC use uniball joints, so is the MOOG joint outdated or ahead of its time? Which is better basically??
    And heim joint vs Uniball, it seems like a safety measure and easier to replace... Still, experience welcomed.
  3. Aug 15, 2015 at 10:33 PM
    #1003
    makaha
    makaha New Member
    Kody
    2007 Tacoma TRD Off-Road Access Cab
    Extremely new here, bear with me please.
    New to the Taco family and the lift crave.
    Where do I start first? I live in Alaska, offroad frequently, and I have a Wrangler with a 5" lift sitting next to me. As much as I'm happy that it performs better than the Wrangler, I want it to look beefer than my neighbor as well.
    Mahalo in advance!
  4. Aug 24, 2015 at 4:03 PM
    #1004
    8Radiant
    8Radiant Member
    2006 PreRunner V6 Double-Cab
    I have a set of 1st gen leaf springs and was wondering if I could cut them to make them fit on my 2006 Prerunner because the hole is off center.
    Doable? Not recommended?
  5. Aug 27, 2015 at 6:44 AM
    #1005
    bmrandolph1s
    bmrandolph1s Well-Known Member
    Brian
    Missouri
    2016 DCSB OR AT MGM
    My goal is to fit 315/75R16 tires on my stock rims on a DCSB OR. From zooming this website I've deduced that I need a 6' lift and wheel spacers to do so. It also seems like Icon is one of the most popular and trusted suspension companies mentioned in here. But what I can't find is a good thread that describes the different stages of lift and their capabilities/applications.
    If this is already somewhere and I've just missed it then please redirect me. But if not, then here goes my specific situation.
    My truck goes off road probably at least 2 weekends a month, but never in a punishing fashion like rock crawling or desert racing or hard core mud bogging. Just getting to and from hunting spots, camping spots, and general exploring. So I don't feel like I need the highest end components. However when Z Day hits and all the main highways are shut down, I want to feel confident my suspension will hold up against some nasty terrain.
    So is it a safe bet for me to go somewhat middle of the road with a stage 3 kit, or are there other things I need to take into consideration?
  6. Aug 29, 2015 at 3:17 PM
    #1006
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Sorry if this question was already asked, but I'm not really willing to read 53 pages for the question. :anonymous:
    Okay, so I bought this truck with a 2.5" lift and it runs 285s. It drives normal on pavement, even at full turns. As soon as I air down the tires for Off-road however, the tires rub at full turns.
    So in the first post, it describes to trim the front body mount. Excuse my ignorance, but I've never done this so bear with me. Is that hard to do? What tools do I use, if any? WHERE is the front body mount? And finally, will you be able to tell the front mount is trimmed/cut - visually or in the ride quality?
    Thanks.
  7. Sep 1, 2015 at 3:40 AM
    #1007
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    That Jeep could have 12" of lift and its still going to get stuck, so don't get hung up on looks. 3" of lift and the right set of shoes will have you running circles around that heap.
    There are a ton of recommendations I can make, but I don't want to give you my opinion because I'm biased (Old Man Emu FTMFW!). You may want to consider searching the build threads for guys with TRD Off-Road Access Cabs, and see what has worked well for them and what hasn't. Set a goal and a ball-park budget. Also keep in mind that setting up your truck like a dune-hopping pre-runner isn't going to be very conducive to your current climate.
    Everything you're going to need to know is on TW, including other Taco owners in your area. Below are just a few of my favorite threads, I follow about 50 or so:
    https://www.tacomaworld.com/threads/old-man-emu-questions-answers-pictures.258245/
    https://www.tacomaworld.com/threads...travel-in-process-overland-taco-build.295220/
    https://www.tacomaworld.com/threads/tsb-list-for-2005-toyota-tacoma.7107/
    https://www.tacomaworld.com/threads/mrgrimms-mall-crawler.104272/
    https://www.tacomaworld.com/threads/la0d0gs-rig.229060/
    https://www.tacomaworld.com/threads/ckeene9s-12-build.259108/
    If you couldn't tell, I'm working an expedition build for my truck and these guys help me generate ideas on how to go about it.
    makaha[QUOTED] likes this.
  8. Sep 2, 2015 at 12:12 PM
    #1008
    Mtnflyer
    Mtnflyer I'm big in Japan
    Las Vegas
    I think I've read through most of this thread and I don't think I saw a good discussion/comparison of advantages/disadvantages of lifting with blocks and spacers vs. with suspension. Is there another thread that compares the two with pros and cons?
    YOTA LOVER likes this.
  9. Sep 2, 2015 at 1:25 PM
    #1009
    valt0five
    valt0five Well-Known Member
    Val
    NM
    2012 DCSB TRD Off Road
    Okay sorry if these are some dumb questions.
    I'm looking to get rid of my Revtech 3" lift kit that the dealership put on and go with a new suspension. I'm completely new to all of this so I guess my question is where do I start? I'm running 285/70/17 right now and my new tires are already rubbing again. After browsing through TW, I don't want to go with the "temporary fix" by putting wheel spacers because I already know I want to move away from spacers all together and go with something nice and reliable.
    Another dumb question.
    If I already have the 3" lift, what does that mean for a new suspension? A lot or bundle of some type? I've heard Icon is a great brand to go with...
  10. Sep 2, 2015 at 7:23 PM
    #1010
    DustStorm4x4
    U S A
    04 Jeep LJ
    No such things as dumb questions. I think I want to do what you're doing and replace all suspension under the truck. My goal is to fit 33s, however I don't think a 3 inch lift will suffice based on what some people say. As much as I want 33s, I will NOT go anywhere above a 3" lift. I hear anything above that and you'll have to use drop brackets which lowers ground clearance. And also isnt great for handling safety.
    I'm thinking about going with Fox or Icon like you. I hear they're the big brands for offloading.
  11. Sep 3, 2015 at 1:08 AM
    #1011
    YOTA LOVER
    NH
    try searching the whole site, its a topic thats been beaten to death.
  12. Sep 3, 2015 at 1:10 PM
    #1012
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    I heard that if you go more than a 3 inch lift you become really likely to break tie rods, is this true?
  13. Sep 3, 2015 at 10:03 PM
    #1013
    valt0five
    Val
    NM
    I've thought of 33s myself but like you, I've heard that's not such a good idea. I won't go over a 3" lift either. Im more than happy with the 3" lift that it's got right now I just would like to learn a little more and possibly go with Icon.
    Altogether I am thankful for TW. I don't want to jump into something without knowing what fits me best.
    Thanks for the input
  14. Sep 6, 2015 at 10:33 PM
    #1014
    Gply
    Gply Well-Known Member
    Bay Area, CA (east bay)
    2015 Tacoma DC TRD off-road
    More shit then I ever planned on doing
    Rather new to this sight and wishing I would've joined and read some of these threads before I made the mistake of installing a pro crap 3" coil over kit on my 2015 DC and dealing with the incompetent / untrusting employees at 4wp.
    With tha said I'm looking to dump my pro comp kit cut my losses and install a better riding 3" coil over kit that'll allow me to get my alignment (steering bump) issues squared away.
    Was thinking of going with the bilstein 3" kit and 5160's. Any recommendations would be greatly appreciated.
  15. Sep 6, 2015 at 10:41 PM
    #1015
    DustStorm4x4
    U S A
    04 Jeep LJ
    Many of the guys on this site run ICON's and Fox. Just a recommendation.
  16. Sep 8, 2015 at 5:19 PM
    #1016
    taco8603
    taco8603 Well-Known Member
    Philip
    Kenneth city Florida
    2019 White Tacoma DCSB SR 4x4
    lt265/75/16
    if i put a aal do i need to get new u bolts with stock leafs
  17. Sep 8, 2015 at 8:40 PM
    #1017
    Gply
    So I'm on the fence between toy tech 2.5 coil overs or the icon coil overs. The price difference is only about $100. Would love to hear some feedback from guys or gals running these shocks.
  18. Sep 8, 2015 at 10:16 PM
    #1018
    spike54
    spike54 New Member
    08 tacoma 4x4 trd sport
    5100 bilt's
  19. Sep 9, 2015 at 10:52 AM
    #1019
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    The Wheelers 1.5" AAL comes with longer u bolts. Not sure about other AAL's
  20. Sep 9, 2015 at 1:51 PM
    #1020
    taco8603
    Philip
    lt265/75/16
    I got procomp short ones
