Tapping power for USB ports in blank next to fog light switch - Finished.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dofartshavelumps, Jan 6, 2016.
  1. Jan 6, 2016 at 2:55 PM
    dofartshavelumps
    dofartshavelumps [OP] Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    Hi I purchased a USB connector that allegedly fits where I have 2 blanks right now (Locker/Inverter). Does anyone have a wiring diagram or know if there is power run to the connectors for the Locker/Inverter that are pre-wired behind the blanks? I bought an add a fuse so I can go that route but wasn't sure if there was a better way.
    The USB connector looks like it is wired separately so one could be switched and one could be always on.
    Thanks.
    Biscuits likes this.
  2. Jan 6, 2016 at 9:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would install it using an Add a Fuse device.
    Riverpirate and Mush Mouse like this.
  3. Jan 6, 2016 at 11:19 PM
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    Mush Mouse likes this.
  4. Jan 7, 2016 at 10:50 AM
    Gottafly
    Gottafly Well-Known Member
    Robb
    Charlotte, NC
    2009 Black Tacoma TRD Sport
  5. Jan 7, 2016 at 12:58 PM
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    the open one on the top row of the fuse panel I believe??
  6. Jan 7, 2016 at 2:52 PM
    Gottafly
    Robb
    Charlotte, NC
    I am also wanting to do this mod but the ACC circuit requires the ignition to be on for power. Anyone know of a circuit that I can tap into to allow the plugs to operate with the ignition off??
    Gottafly
  7. Jan 7, 2016 at 3:04 PM
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    PlastiDip
    I have mine plugged into the ACC circuit. works only with ignition on. If you plug into the PWR Outlet slot next to it, it will be constant on.
  8. Jan 7, 2016 at 4:53 PM
    Gottafly
    Robb
    Charlotte, NC
    Thanks
  9. Jan 8, 2016 at 2:40 AM
    baldy54
    baldy54 Well-Known Member
    Orlando, FL
    06 Prerunner SR5
    Where did you get the USB port at??
  10. Jan 8, 2016 at 4:42 AM
    dofartshavelumps
    NH
    http://www.amazon.com/Mictuning-Toy...id=1452255879&sr=8-3&keywords=tacoma+usb+port
    The add a fuse I used is just a mini and worked but after pulling out the fuse from the fuse box I saw that we have mini low-profile fuses. Not sure if it makes a difference or not but you can get the add a fuse in mini low-profile.
    http://www.amazon.com/Qiorange--cir...TF8&qid=1452255968&sr=8-6&keywords=add+a+fuse
    I got the dual USB charger 1.2 & 2.1A, I just looked and they have one that is just 2.1A for the same price, I think I would have ordered that one if I checked.
    I opened up the case and snipped out the blue LEDs since I wanted it to kind of match. I also used 400 grit wet sand sand paper and got rid of the USB logos and made it look like more of a matte finish rather than shiny so it would blend in.
    I plan on trying to do this over the weekend time permitting. I also ordered a homelink mirror from Bob and a valentine one detector and plan to mount that with the blend mount.
    I did the A pillar handle lower bolt RAM mount install last weekend, at first I was a little leery about the X grip but after the install I am very happy with the function and versatility, I can fit my iPhone in there or a GPS unit since some places I go have no cell service and I am not sure if I need cell service for GPS to work. Anyway, I liked the idea of hard wiring in a cord for charging but found this USB adapter and though it was almost accomplishing the same thing but more versatile.
    I will take a few pics when I do it and report back if the USB adapter fits ok. I saw one on here but can't find the link right now.
    Thanks for the pics of the Add a Fuse.
  11. Jan 8, 2016 at 6:45 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    AFAIK the only "constant" on circuit on the interior fuse box is the 20A door lock. Power outlets are not constant hot
  12. Jan 8, 2016 at 9:42 AM
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    PlastiDip
    U may be right. But I swear I accidentally plugged it into the power outlet 15A accidentally and it was hot. Lol.
  13. Jan 9, 2016 at 12:05 PM
    dofartshavelumps
    NH
    I got the USB ports installed and they seemed to work. Thanks for the help.
    Biscuits and Doughnut Spaghetti like this.
  14. Jan 9, 2016 at 5:10 PM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    If you plugged into an always on power source be careful with what you leave in the truck and how long. Easy to drain the battery that way.
  15. Jan 9, 2016 at 5:14 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Did you have to remove any panels to install the switch and wiring into the upper row of switches?
  16. Jan 9, 2016 at 5:54 PM
    dofartshavelumps
    NH
    I decided to use the Accessory circuit for this reason. Thanks.
    I tried to get them out from behind without removing anything and failed, I also tried to work them out form the front but was afraid I would ruin something so I ended up taking the lower panel off (actually pulled it out from the clips and let it hang lower and left all of the other wires attached) and this gave me enough room to get my finger in the back to get it out. The center blank was just a blank and the one to the right had the inverter wiring going to the back of the blank. It was pretty easy to drop down the panel, took a few minutes, I spent more time trying to figure out how to do it without removing the panel than the time it took to remove the panel.
  17. Jan 9, 2016 at 6:19 PM
    Hit n Run
    Hit n Run Well-Known Member
    14 Black DCLB Sport
    I wired my tailgate lock to the PWR OUTLET and on my 2014 it is 12v hot, no key required.
  18. Jan 9, 2016 at 7:11 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Thanks. So you were able to just pull the lower panel out from the clips. Did you pull the panel out or pulled it down. I thought you had to take out the kick panel to get to the lower panel. This is good to know.
  19. Jan 9, 2016 at 7:25 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Just screw a screw into the blank and pull the blank will pop right out, no need to remove panel :)
    shakerhood likes this.
  20. Jan 10, 2016 at 5:43 AM
    dofartshavelumps
    NH
    You are correct, you have to take out the kick panel, the plastic pedal foot rest thing, and the plastic piece net to the driver door on the floor. It was pretty easy though. I didn't disconnect any wiring from the lower panel and jest let it hang down - sorry I didn't do the best job explaining.
    I followed these instructions.
    http://www.xr-underground.com/forum/showthread.php?t=941
    These other links also talk about other ways to do it.
    https://www.tacomaworld.com/threads/2014-remove-switch-from-dash.321635/
    https://www.tacomaworld.com/threads...-switch-blanks-left-of-steering-wheel.132270/
    https://www.tacomaworld.com/threads/blank-switch-removal.283658/
