Techstream Tips and Tricks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totall4285, Mar 10, 2019.
  1. Dec 18, 2020 at 7:34 AM
    #401
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    https://www.tacomaworld.com/threads...-for-2020-toyota-tacoma.680281/#post-23961472
    As others said, chopping it is the only way.
    tonered likes this.
  2. Dec 18, 2020 at 8:08 AM
    #402
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Pressing the black rubber thingy on the frame will get the chime to shut up. It's the door close sensor, so you can trick it into thinking the door is actually closed. Do it everytime I flash a new tune.
  3. Dec 18, 2020 at 8:37 AM
    #403
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    A magnet works to keep it depressed
    NorrinRadd likes this.
  4. Jan 16, 2021 at 10:07 AM
    #404
    mandog
    mandog Lesser-Known Member
    Race City, USA
    2017 4WD Off-Road Quicksand Overland
    I went through a lot of the customizations and thanks to @CdnSldr from the other topic (tonered’s ECU update) basically followed his suggested options. I only remember seeing it asked once here, but in case I missed something, is there a way to turn off the hood ajar alert? I’m not skilled enough I don’t think to close the circuit on it manually, or w/e.
    Also, can someone explain the TPSM page in TS? I was hoping you could just input values for when it alerts you, say at 20 psi, vs anything below 26, but I was unsure how to mess around with that page.
    Thanks for all the help in here, you guys are great! :thumbsup:
    ktbell444 likes this.
  5. Jan 21, 2021 at 9:49 AM
    #405
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    Please excuse me if these questions have already been addressed before...
    When applying TSBs is there an audit entry written to the ECU that contains information related to Who applied the TSB? And is there any impact to the warranty if the TSB was applied by someone other than a Toyota Dealer?
  6. Jan 21, 2021 at 9:52 AM
    #406
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Nope. And most dealerships don't even apply the sticker that the T-SB states to install. Go ahead and update!
    G8R_Taco likes this.
  7. Jan 21, 2021 at 10:22 AM
    #407
    gForceDude
    gForceDude Well-Known Member
    The option is there in TS to turn-off or disable the door open chime when in ACC mode.
    Evidently on the earlier Gen3 years this option did nothing (as reported by some here); but I selected it on my 2020, and it did indeed work. I don't know if it works on the years prior to 2020, but it worked on mine :)
  8. Jan 21, 2021 at 10:24 AM
    #408
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Well that is a new one. Nice find!
    If you can post up screenshots, I can add them somewhere in the ECU Update thread.
    G8R_Taco, NorrinRadd and daveeasa like this.
  9. Jan 21, 2021 at 10:50 AM
    #409
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Or here. I'd definitely like to see if it's possible on mine.
    NorrinRadd and tonered[QUOTED] like this.
  10. Jan 21, 2021 at 5:44 PM
    #410
    gForceDude
    I don't even remember where I was inside the Labyrinth that is TechStream.
    It was my very first time using TS (to update my ECU), and while I was in there I turned-off my seat belt warning, and then I looked at literally every single Customization Option to see what was available. The option is in there, somewhere; but I don't remember where.
    In the 5 Posts starting here in this thread you can see that it doesn't work for some years prior to 2020 (which years, I am not certain), but it definitely worked for mine :)
    In this post it is stated:
    As an update, Toyota documents in the latest 2021 manual that you are able to have the door alarm/reminder turned off by dealer service departments - having mine done this week!
    The Dealer Service Department would certainly be using TS to do this. So, it works for 2020 & 2021 at least.
  11. Jan 21, 2021 at 5:55 PM
    #411
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    What version of TS are you using? Perhaps only a later version exposes that option...
  12. Jan 21, 2021 at 6:16 PM
    #412
    gForceDude
    I'm using the TS version from this thread:
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    v14.20.019
    It might work on your 2019, I don't know.
    But, evidently it didn't work on VB25's 2018 (see here).
    tonered likes this.
  13. Jan 21, 2021 at 9:05 PM
    #413
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    At the end of the ECU Update thread 1st Post, I linked a bunch of Customization screenshots from @CdnSldr 's 2020. Does anything look familiar there?
    Oh!! It is shown in the third pic! I will note that.
    :cheers:
    CdnSldr and gForceDude[QUOTED] like this.
  14. Jan 22, 2021 at 6:22 AM
    #414
    gForceDude
    Yes, it is the third item in this pic:
    I selected 'Off' (as shown in the pic), then clicked the 'Green Arrow' to confirm my changes (lower right, next to the 'Red X' - it turns Green after you make changes), and it worked on my 2020.
    :cheers:
    Edit: This pic is the third one in this post.
  15. Jan 22, 2021 at 6:48 AM
    #415
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    @Totall4285 .
    Could you change to the title to possibly add something about the door chime option being re-discovered? It is kind of a big deal to a lot of folks and really cool that some 2020+ have the option.
    Thanks!
    :cheers:
    gForceDude and daveeasa like this.
  16. Jan 22, 2021 at 7:05 AM
    #416
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Let the hacking for 2016-2019 begin! :)
  17. Jan 22, 2021 at 7:07 AM
    #417
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is hard to even say what ECU this option resides in. The fact that it only works on some 2020s is a big head scratcher.
    @G8R_Taco said that he will peek at his 04B33 2019 though.
    G8R_Taco and gForceDude like this.
  18. Jan 22, 2021 at 8:31 AM
    #418
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No luck with 04B33.
  19. Jan 22, 2021 at 8:32 AM
    #419
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    No joy on the 2019. Completely different customization screen than what I have.
    Do the 2020+ trucks have the option to change the number of blinks for lane-change?
    Was a sub-system selected for this customization?
  20. Jan 22, 2021 at 8:33 AM
    #420
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That should be in Warnings. I've seen it for all model years except 2021s, only because I haven't hooked up to one yet.
    G8R_Taco[QUOTED] likes this.
