TELL ME WHERE I AM WRONG...I speak for many NEW GUYS to lifting
Discussion in 'Suspension' started by ChuckLee, Jul 11, 2011.
  1. Jul 13, 2011 at 9:43 AM
    ChuckLee
    ChuckLee [OP] Well-Known Member
    Richmond, VA
    06 SR5 4x4 DC
    If i go with 885's i'll have to get UCA's (to be on the safe side) from what I have read. that is why i chose the 884's (approx. 2" before settling)
  2. Jul 13, 2011 at 5:33 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Chicago
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    The settling will be minimal at best since the springs are scragged from the factory.
  3. Jul 13, 2011 at 5:33 PM
    packfan88
    packfan88 Very Nice !
    Acworth, GA
    Billy Lift, Cooper STT Pro, Westin Step bars, tinted, rain gaurds, EBC rotors hawk pads
    im in the same boat you are....im sure you saw my thread a couple down.
    a bit of clarification is needed. sure there is a suspension faq thread, but once your edone reading that and come ask a question the reply you get it "not, do it this way" or..."it might work".
    then after going to the vendor web sites, you see there are many bilstein 5100s for sale...which package?
    very confusing.
    im glad you also have a dc 4x4. once you get set to order your products, i can order the same lol. And i too can go look under my truck for what leaf springs i have......i looked, i have 3 leaf (i assume a non TSB set).
  4. Jul 13, 2011 at 5:34 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Possibly depending on the actual lift height. 885s seem to very alittle from truck to truck. So 884s and a 1.5 aal would probably put ya about where you want to be then
  5. Jul 13, 2011 at 8:05 PM
    ChuckLee
    Richmond, VA
    06 SR5 4x4 DC
    Well I'm not the expert...but I'm getting 5100's on all four corners (approx $280 with discount at Downsouth Motorsports). Front OME 884 springs (also at DSM for under $200) which will lift front approx 2" which is highest you can safely go and know you won't need UCA replacement. I don't want to use stock springs because it compromises ride quality. For the rear, I would go with the ICON progressive 3 leaf setup but they are sold out so I'll go with the similar set from Wheelers ($150+shipping). This will lift rear just under 2" so I will be leveling the truck a small amount also since the front is going the full 2". This setup will be improving ride quality while lifting it and it won't cost me an arm, a leg, and my hair because i won't be pulling it all out trying to fix other problems caused by lifting any higher. This route is pretty fool proof I think
    Oh and BTW, yes you have a non-tsb setup. Only thing I haven't decided on yet is whether or not I'll be removing the factory overload leaf when I install the progressive AAL setup. I probably will.
  6. Jul 14, 2011 at 11:33 AM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    I have been exactly where you are. I decided on the OME shocks and coils for the matched damping ARB states on the web site. I have the tsb 1.5 aal from toytec.
    http://www.tacomaworld.com/forum/suspension/149572-884-dble-cab-install.html
    http://www.tacomaworld.com/forum/suspension/140680-884-885-2nd-gen-double-cab.html
    Threads with more detail.
    Now getting to UCA , i'm at 2 inches from stock and the best I could get was 0 toe , 0 camber and 1.4 caster. 1.4 is the minimum toyota recommends. I could gain more caster if i gave up some camber. Camber wears tires and caster doesn't so i wasn't gonna move on that one. So i AM looking at camburg UCA to get my lost caster back. I thought as you do that with so many threads out there and guys are able to lift without changing UCA and keep alignments within spec. Yes you can BUT it might cost you something like a little darty on the highway or different feel from factory. Just keep your eyes open when you pull the trigger and lift because eveybody is different and what one guy likes might not be what you like.
    I definitly like the lift and the ride is much better than stock , but i will be tweaking with UCA's and possibly a new aal because I want more capacity.
    Cheers and Good Luck:)
  7. Jul 14, 2011 at 2:17 PM
    Treedawg37
    Treedawg37 Well-Known Member
    Barry
    Central, Alabama
    '11 Tacoma DC 4X4 SR5 SB,
    BHLM, tinted tails, weathertech mats & visors, sportsman"s camo seat covers, diff breather mod.
    +1 very good explination....thanks
  8. Jul 14, 2011 at 7:17 PM
    ChuckLee
    Richmond, VA
    06 SR5 4x4 DC
    Any reason you aren't jumping on the group deal on the LR UCA?
  9. Jul 15, 2011 at 3:11 AM
    Treedawg37
    Barry
    Central, Alabama
    yea $$$$$.
  10. Jul 15, 2011 at 5:35 AM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    Yes I am not looking at the LR UCA cause the ball joint that fits that arm is unique. Meaning you can only replace that ball joint with one from them. The arm has a slot in it that only accepts the "adjustable" ball joint that has settings for the castor you want, then you can slide it in or out for camber. The only thing holding it there is the "torque" of the nut. I am sure that this is more than adequate but I am more comfortable with something else.
    I want an arm that you can install a more universal ball joint. The camburg arms have the "hole" where I can install the toyota ball joint, if desired, or an aftermarket one like Moog. The moog is greaseable and is available at any local parts store. This gives me more choice and dosen't limit me to availablity from one source. Pay a little more now or ???? more later. I don't like unknowns.
    Cheers:)
  11. Jul 15, 2011 at 6:05 AM
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
  12. Mar 15, 2012 at 11:34 AM
    trktwo
    trktwo tagging shit all over the net since 2001
    tommy
    biloxi
    '12 Prerunner TSS stock
    Aero Turbine at2525xl, curt hitch and trailer wiring kit, weathertech vent visors, leer topper 5100s@1.75, 2" AAL, 265/70 r17 michelin at2, bbs 17x8 rd wheel (fj)/ jl stealthbox, 700/5 amp, jl 6.5s x4
    great thread!
  13. Mar 15, 2012 at 8:20 PM
    DR Da_da
    DR Da_da Infrequent Member
    Northeast FL
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Well, that sucks. I just bought a new set of 5100s for the rear to match the 5100s I'm sticking up front. Ever since I lifted the rear (TSB with ToyTec 1.5" TSB AAL while still using stock TRD-offroad shocks) I get a harsh WHAM! when I hit bigger bumps at speed. I've always felt that it was due to the stock shocks hitting their full extension stops. If the 5100s are the same length, then I just wasted my money! It looks like 5125s or a custom length set of 5100s from DSM would give me the correct amount of travel I need.
  14. Jan 13, 2013 at 6:42 PM
    calebm12
    calebm12 Well-Known Member
    MD
    2011 trd tx
    Weathertech, hand turned wood shift knob, rear view mirror mod, grillecraft MX, hella 500s
    Did the OP ever pull the trigger? Would like to see before and after pics and get a read out on I'm new UCA was needed in the end. want to do a very similar lift.
  15. Jan 14, 2013 at 2:26 AM
    #35
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    He probably got the lift but probabyl didn't need new UCAs.
    I got a full 3" front & rear lift with OME 885s & Dakars and still have stock UCAs. Toe & camber are 0* caster is just out of spec but no driving problems.
  16. Jan 14, 2013 at 8:12 AM
    #36
    Techy
    Techy Well-Known Member
    Montrose, CO
    06 trd off road dbl cab
    I am curious how it worked out for the op as well.
  17. Jan 14, 2013 at 10:04 AM
    #37
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    I have Eibachs and the rear tsb springs and that's it. I just upgraded my wheels and tires to 33's. I do have some rubbing, but the rubbing is on plastic parts ie. mud flap. I can achieve full steering lock in either direction, and the ride is great. I'm not gonna post another pic because in my elation I posted all over the board! Haha! A lot of it has to do with tire size and wheel specs for success. My lift cost me the price of the coils from another member who never got around to installing them, and pushing toyota to upgrade my leafs after they shot me down once. This forum was instrumental in all of it. I feel sorry for those tacoma owners who don't have this information available to them.
  18. Jan 23, 2013 at 7:02 PM
    #38
    calebm12
    MD
    2011 trd tx
    This might be an obvious answer, but does adding new coils (884s), bilstein 5100s, and an aal void the manufacturer warranty?
  19. Jan 24, 2013 at 12:27 PM
    #39
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Silver 06 4x4 TRD Sport Access cab
    4Runner wheels BFG A/T ko2
    Thank you for posting this thread. I have a similar truck and had similar questions.
  20. Jan 24, 2013 at 12:50 PM
    #40
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    No, it does not but Toyota will obviously not warranty the aftermarket parts. Where it gets tricky is say if your wheel bearings or needle bearing goes out while still under warranty. The dealership will point at the lift and say that's what caused the premature failure even though it may not be the case.
    In short, it won't void the warranty but could make getting certain driveline parts warrantied more of a fight.
