Tire Install Question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMaster44, Feb 21, 2013.
  1. Feb 21, 2013 at 5:25 PM
    TacoMaster44
    TacoMaster44 [OP] Well-Known Member
    06 Tacoma TRD
    Ok so I ordered some 18 inch rims offset -12 with 4.53 backspace to go on my 33x12.50 tires and I have a three inch lift kit aswell as this lifting block like thing in the front that the previous owner installed. Anyway my question was where do I need to trim to clear the tires. Pics would be great!
  2. Feb 21, 2013 at 6:53 PM
    TacoMaster44
    06 Tacoma TRD
  3. Feb 21, 2013 at 6:55 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I have a pic in my gallery
  4. Feb 21, 2013 at 7:12 PM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    You may need what is known as the "cab mount chop"
    I'm not sure what that is, but I've heard it talked about on here a lot
    You also will definitely need to take off your mudflaps
    If I were you, I would crawl under there and turn your wheel and see where it hits.
    Since you have a block lift, I assume you won't be going off road, which means you don't have to worry about turning under hard compression situations.
  5. Feb 21, 2013 at 7:20 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Probably ganna need the cab mount chop. Look in the back of your wheel well you will see where the cab is mounted to the frame, or the body mount. That will need to be cut back and a new plate will have to be welded on there
  6. Feb 21, 2013 at 7:30 PM
    TacoMaster44
    06 Tacoma TRD
    I'm gunna take the blocks of for that exact reason!
  7. Feb 21, 2013 at 7:35 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    So your taking your spacers out and installing a 3" lift? Which one? 12.5" x 33" are going to rub alot
  8. Feb 21, 2013 at 7:39 PM
    TacoMaster44
    06 Tacoma TRD
  9. Feb 21, 2013 at 7:44 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    The dreaded pro comp lift :stirthepot: just kidding, thing is those front coilovers will ride very stiff. They use 700 lb spring rate coils, most guys only use springs that stiff if they have a plate bumper and winch
  10. Feb 21, 2013 at 7:52 PM
    TacoMaster44
    06 Tacoma TRD
    I have a steel winch bumper and 8,000 pound winch, should they be fine?
  11. Feb 21, 2013 at 7:57 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Oh good lol, you didnt mention that. Then yes those coils will be good for you. Something like old man emu with a 590lb spring rate would sag with that much extra weight. Alot of guys go with 650lb springs, but the 700 will be nice, you dont want them sagging, your ganna need that extra height to clear 33x12.5 tires. You really wont know how much trimming until you get them mounted. I had to cut my cab mount, bang over the pinch weld, trim the very bottom of my fender flares and cut away a bunch plastic wheel well liner
  12. Feb 21, 2013 at 7:59 PM
    TacoMaster44
    06 Tacoma TRD
    I'm still confused with the cab mount cutting. Are there any threads baed on that? I couldn't find any.
  13. Feb 21, 2013 at 8:11 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  14. Feb 21, 2013 at 8:26 PM
    TacoMaster44
    06 Tacoma TRD
    He says you will be able to fit 285's. Is that without a lift?
  15. Feb 21, 2013 at 8:33 PM
    TacoMaster44
    06 Tacoma TRD
    What tire do you recommend for this lift with out doing the cut and just doing trimming?
  16. Feb 21, 2013 at 8:38 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Eh probably not, probably means with a lift, the lift doesnt matter as much once you stuff the suspension tho. you might need to do a pretty aggresive cab mount chop. It really is hard to know for sure, there are to many factors but i can tell you a -12mm offset and 12.5" tires are ganna cause some rubbing. I have -10mm and 285s so 11.5" and i had to do alot of trimming. Who knows you might barley rub the cab mount and just need to shave it down. I had to cut mine, i have 2.5 inches of lift and i rubbed during normal driving at full lock. Caster and camber numbers also play into rubbing
  17. Feb 21, 2013 at 8:43 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    285/65/18 are a safer option than 33x12.5, but you still mighhtt have to do the CMC, especially if you wheel it hard an flex out the suspension. 275/65/18 will most likely not need the CMC. If you are not set on the 18" wheels you can get a tall skinny tire and not do the CMC, like 255/85/16 (33.3x10)
  18. Feb 22, 2013 at 5:38 AM
    TacoMaster44
    06 Tacoma TRD
    What about 275/70/r18 tires
  19. Feb 22, 2013 at 7:24 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    That might be a good option, a little taller than 285/75/18 but a little skinnier. There will probably still be trimming
  20. Feb 22, 2013 at 7:36 AM
    TacoMaster44
    06 Tacoma TRD
    Ok man thanks for all your help!
