Two-Way Diff and T Case Breather MOD
Discussion in 'Off-Roading & Trails' started by Frogsauce, Jul 7, 2013.
  1. Jul 7, 2013 at 8:29 PM
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    I did my own version of the scuba breather mod based on these:
    http://www.tacomaworld.com/forum/off-roading-trails/15093-scuba-mod-relocating-front-rear-diff-tranny-transfer-case-e-locker-breather.html
    http://www.tacomaworld.com/forum/technical-chat/111954-my-differential-breather-mod-photos.html
    Big thanks to both for locations and ideas.
    I ran the rear differential and transmission breathers up to the engine bay right behind the battery and extended the two breathers that were already relocated up there just a little further.
    Parts:
    - Toyota Part #90404-51026 (Camry Union Piece for Rear Diff)
    - Specter Filters (Autozone/Advance Auto)
    - 1/4" Fuel Line (little less than 15') and some hose clamps
    - 1/8 x 1/4 x 1/4 'T' Barb Connector
    - 3/8" x 1/4" Barb Connector
    If you got an e-locker breather, your gonna need another 'T' to tie in the rear breather. I don't have one, so I can't give the info on that.
    UPDATE: Before this mod, my diff oil had water in them after about 5k miles (or one hunting season). I just had a chance to check the fluid after this mod and it came out clean. I think another oil change after this hunting season will be enough evidence for me.
    2ND UPDATE: 15k on this breather setup. Fluids still look like new. Filters look very clean too.
    I also made a box out of a 4 gang electrical box from Lowes and used the breathers that Shadow-Warrior recommended (specter).
  2. Jul 7, 2013 at 8:44 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Believe other breather is for add actuator.
  3. Jul 8, 2013 at 7:22 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Did I miss any breathers? Is the T-Case and Transmission the same breather?
    I followed the transmission breather line and it looks like it connects to two spots. One is the transmission, the other looks like it could be the t-case.
  4. Jul 8, 2013 at 7:34 AM
    Large
    Large Red
    Looks clean, what are those filters you are using?
  5. Jul 8, 2013 at 8:51 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    autozone
  6. Jul 16, 2013 at 4:42 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    thats pretty badazz!
  7. Sep 18, 2013 at 5:50 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    I was able to change the diff oil yesterday to check it and test the two-way breather theory.
    Before, my diff oils had water in them after about 5k miles (or one hunting season with water crossings). But this time it came out clean, and I even went further and more diff dunking on this oil than the last.
    So it looks like the two-way breather helps release pressure from expand also, probably helping keep water out. I think another oil change after this hunting season will be enough evidence for me.
  8. Sep 30, 2013 at 11:21 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
  9. Sep 30, 2013 at 11:21 PM
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    Looks good! Might have to do this in addition to my rear diff relocate :)
  10. Oct 13, 2013 at 5:57 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    When you say ADD, are you talking about the t-case... or something else?
  11. Oct 15, 2013 at 4:10 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Automatic Disconnect Differential
    I didn't even know it had a breather until I started poking around.
  12. Oct 16, 2013 at 4:11 AM
    x2468
    I need to find a schematic of this.... i always thought the ADD components were inside the front diff...
  13. Apr 2, 2014 at 7:39 PM
    skygear
    skygear                    
    so how many Toyota parts did you order?
    2 unions? I did not see a parts list in the OP.
  14. Apr 3, 2014 at 9:41 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    I updated it with a parts list.
  15. Apr 3, 2014 at 3:19 PM
    skygear
    skygear                    
    Nice.
  16. Dec 29, 2014 at 6:31 PM
    badzook
    badzook Member
    East Coast
    Off Road
    This is on a new 2014 OFF ROAD with about 3k miles. The truck was cold after sitting over night.
    So, when I went to remove the factory vent on the rear diff, I noticed there was some air pressure releasing from the vent cap. I would guess there was something like 2 or 3 psi in the rear axle.
    I then disassembled the breather fitting to find a spring and rubber washer inside.
    It seems to me like this is a check valve but is also designed to hold a small amount of pressure in the axle to keep water and dust / mud out of the diff. It would also keep the seals lubricated and running true on the axles and pinion.
    As a result of this, I did run a fuel line up to the cubby but I decided to re-use this factory vent fitting to maintain the factory pressure setting inside the diff.
    I did purchase the 2 Toyota parts mentioned earlier but only used the nipple piece on the axle.
    Any knowledge or comments on this are appreciated... :)
    Has anybody else noticed this?
  17. Dec 29, 2014 at 6:35 PM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
  18. Dec 30, 2014 at 9:59 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    No no... the spring in the factory vent (breather) simply secures it closed to keep junk out when you are bouncing around. The thing is not a breather, however. It will not equalize pressure if you drop a hot diff into cold water... and that's how contamination of the diff with water happens.
    We install the same breather that Toyota already puts on the front diff when we do the mod on the back... and up high so water, excess dust stays out.
    I am not a Toyota Tech, so I will defer to one if there is error in my logic.
    I drove in deep, muddy water when my truck was 6 months old, and the rear diff was contaminated. I did the breather mod (see the link in my sig) and 4 years of off roading since has never contaminated the fluid since.
    Throw away the original factory rear 'breather', and do the mod correctly with the front breather or an aftermarket breather filter, up above any possible water crossing level.
  19. Dec 30, 2014 at 10:34 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I noticed some oil on my filter. anybody else see this? I highly doubt oil is traveling all the way from the rear diff to the engine compartment where I relocated the breather
  20. Oct 1, 2018 at 5:54 AM
    Gbrearle
    Gbrearle New Member
    What size filters are used here?
