UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Jul 9, 2014 at 9:53 PM
    #41
    gray223
    gray223 [OP] Well-Known Member
    SE Missouri
    2014 Tundra Limited
    High end preprogrammed engine management that is end user tunable
    This is listed as included with the urd mk3 supercharger kit for the 2.7. Not sure if its a modified ucon or what.
  2. Jan 13, 2015 at 12:56 PM
    #42
    fnkytrd
    fnkytrd Member
    05 Tacoma 4x4 TRDcharged
    Anyone out there have any maps to download or know how to use the included program. I've got it installed, just don't have any documentation to help use all this stuff.
  3. Jan 13, 2015 at 12:57 PM
    #43
    gray223
    SE Missouri
    2014 Tundra Limited
    I would pm gadget or email urd.
  4. Feb 12, 2015 at 9:00 PM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Ask the same question on XRU. Gadget will likely respond.
  5. Feb 13, 2015 at 5:58 AM
    #45
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Hey guys any development for 2009+. I would like to know if they working on it or not. We've been said it was just about to be avalaible but it was years ago. I know the problem is supposed to be the harness but company like unichip know have a harness compatible so. Just want to know cause i'll find another way.
  6. Feb 13, 2015 at 6:28 AM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have already described how to adapt the UCON into the later models. UniChip i believe is owned by Tyco or something like that. They made the plugs shortly after the '09's came out. You could always get a Unichip just for the plugs.....but that has its own inherent difficulties.
    Adding in GM plugs into the OEM harness, then having a jumper harness to adapt the UCON to the GM plugs, would be the "easiest" way.
  7. Feb 16, 2015 at 5:50 AM
    #47
    Vassily28
    Thanks TOR but i'm really looking for a plug and play solution.
    Base on your knowledge and experience, what do you think about the UNICHIP. I know you need to have acess to an official retailer that can program it but there is one close to me and based on evertything i've read, except the fact it's not an open tune, it seems to be a good product.
    In fact i'm looking to buy the chip, the connectors and the software package so i'll be able to tune it myself. A module can be add to control a 7th injector. Even with all those options, the price will be Under the UCON.
  8. Feb 16, 2015 at 11:50 AM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Effectively, it becomes plug n play, but I know what you mean.
  9. Feb 5, 2017 at 3:52 PM
    #49
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    How you tune the UCON? Send email to Gadget and ask a different map? Let's say if you change the headers or CAI.
  10. Feb 5, 2017 at 4:06 PM
    #50
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It should auto adjust.
    cdelgado14 likes this.
  11. Mar 11, 2017 at 5:19 AM
    #51
    FinnJ
    Finland
    Any numbers, dyno graphs, speculations, if TRD SC with UCON?
  12. Mar 11, 2017 at 8:25 AM
    #52
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    @Torspd
    My speed dial guy for having dyno graphs on hand. I can't keep track of what 1GR changes his name to.
    Lucario Runner and Torspd like this.
  13. Mar 11, 2017 at 9:36 AM
    #53
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  14. Mar 11, 2017 at 9:44 AM
    #54
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Mar 11, 2017 at 11:01 AM
    #55
    FinnJ
    Finland
    Thanks, I've read this and XR-Underground's topic too. I've not found just TRD Supercharger and UCON/X-1 combo.
  16. Mar 11, 2017 at 11:38 AM
    #56
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    URD should have that info. Usually, by that point, owners have already installed other mods first.
  17. Mar 14, 2017 at 8:55 PM
    #57
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The UCon is definitely not user friendly with custom tuning.
  18. Mar 15, 2017 at 5:15 AM
    #58
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is correct. Unlike the X-1, which came before it, the UCON is shipped with the Lite version. Only a very few parameters can be modified. It is locked down otherwise.
    You have to contact URD to with what you have, for any hardware changes that are outside the bounds of its self tuning cability, then have them send you an update, or remotely update it.
    I.E. larger injectors. 7th injector. Meth injection....
  19. May 20, 2017 at 7:29 AM
    #59
    FinnJ
    Finland
    Maybe soon available for the newer models too.:cool:
    WorldWar546, Torspd and gersus like this.
  20. May 20, 2017 at 8:18 PM
    #60
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Looks like a step in the right direction. Hope the price doesnt increase!
