Very odd sound......
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ARNIE R, Sep 2, 2019.
  1. Sep 2, 2019 at 8:53 PM
    ARNIE R
    ARNIE R [OP] Well-Known Member
    Arnold
    Leesburg, VA
    2019 Tacoma White SR5 4D ShortBed
    Fender gravel guards; Side step bars; Bug shield; Vent shades; Body side door moldings; Door edge trim; Tonneau cover
    So, anyway....
    I just returned from a 6 week stay in Florida today (assisting my elderly parents with some med issues).
    Instead of the usual RT 95 method, which I have been using for years, I decided to take my time and utilize the backroads for the entire 3 day journey back home. A lot more scenic and quieter without all those 18 wheelers about to run you down.
    Normally, I listen to Sirius XM radio and like the relaxing stations that play "spa" type soothing music. Today, I began to become aware of a low pitched sound that seemed very regular and cyclic, so I attributed it to something from the music. After all, it is supposed to be relaxing. Trouble was, it was present in all of the songs being played.
    Turned the radio off and listened. It was still there. I can't really explain exactly what it sounds like except that it reminds me of a very low pitched sound that reminds me of someone blowing lightly across the top of an open glass bottle, only with a slight "hollow metallic" ring to it.
    It is very rhythmic, and can be heard almost exactly 20 seconds apart as I actually timed it with my cell phone timer. Sometimes, it is slightly louder or quieter than the previous one before it, but it is definitely very steady and precise.
    It happens during coasting, acceleration, going uphill, downhill, around curves, etc. I even heard it down to about 25-30 mph while going thru a small town.
    I really can't say if today was the first day it started, as I do drive a lot in heavier traffic and frequently have the windows open.
    Really, I am not making this up. Any thoughts out there? Truck only has slightly over 4K on it.
  2. Sep 2, 2019 at 8:58 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    The blowing over a bottle noise /sounds/ like the typical rear diff howl - but that happens based on speed and throttle - not randomly every 20 seconds....
    Good luck!
    ARNIE R[OP] likes this.
  3. Sep 2, 2019 at 9:11 PM
    ARNIE R
    Arnold
    Leesburg, VA
    So, is that "normal" or something to be concerned about? Probably taking it in for its 5K checkup within the month.
    As far as being every 20 seconds, the sound was very low but audible and timely. I was doing primarily highway driving at steady speeds or long straight backroads where I was definitely aware of it with the windows closed. My last hour of driving was either open windows or torrential rain, so I could hear squat then.
  4. Sep 2, 2019 at 9:12 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Lower control arm or mirror whistle?
    shakerhood, Tommyb08 and tcjacado like this.
  5. Sep 2, 2019 at 9:14 PM
    tcjacado
    tcjacado Well-Known Member
    This ^^^^ or the diff howl at around 45 to 50 mph.
    Tommyb08 and Lawfarin[QUOTED] like this.
  6. Sep 2, 2019 at 9:15 PM
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    The holes on the lower control arms are known to make random whistling noises on the highway. It's usually exacerbated with a lift kit due to moving the LCAs further away from the the body. You can fix with plastic hole plugs or skid plates.
    Boss hoss likes this.
  7. Sep 2, 2019 at 9:18 PM
    ARNIE R
    Arnold
    Leesburg, VA
    More like if you took an open glass bottle and blew across the top very lightly just enough to make the sound appear, then stop. It was very precise in its 3-4 second length and 20 second appearance. I could not determine where it sounded like it was coming from, IE., front, back, inside, outside, etc.
  8. Sep 2, 2019 at 9:21 PM
    tcjacado
  9. Sep 2, 2019 at 9:22 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    shakerhood, cshrum and ARNIE R[OP] like this.
  10. Sep 2, 2019 at 10:21 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    What is the mirror whistle?
  11. Sep 2, 2019 at 10:25 PM
    tcjacado
    My driver side mirror howls at certain speeds and sometimes if the wind is just strong enough in the right direction. It does it a little worse now that someone drove by and smacked it with their mirror when parked on the street. (Narrow roads). So its cracked and doesnt quite fit/line up just right.
    I see it more of an issue with the upper trims that have the turn signal there.
  12. Sep 2, 2019 at 10:26 PM
    Dr. Emmett Brown
    Is it a similar sound to the LCA and rear diff howl?
  13. Sep 2, 2019 at 10:28 PM
    tcjacado
    To my knowledge, yes. Not many have complained about it though.
  14. Sep 2, 2019 at 10:30 PM
    CoreyJames
    CoreyJames Well-Known Member
    Corey
    Camas, Washington
    2018 Quicksand SR5 Tacoma
    Turn the radio up:lalala:
    shakerhood and ARNIE R[OP] like this.
  15. Sep 3, 2019 at 4:30 AM
    MaTaco_4x4
    MaTaco_4x4 Well-Known Member
    2018 Tacoma Sport DCLB
    I had a wheel bearing go bad on a Mitsubishi Diamante. Very rhythmic. The period between hums changed with speed though.
    Try turning off the A/C.
    If the sound goes away, your blower fan is wonky. There's a TSB for that I believe.
  16. Sep 3, 2019 at 4:32 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Switch to slayer.
    NYCTaco52, shakerhood and turbosnail like this.
  17. Sep 3, 2019 at 6:07 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
  18. Sep 3, 2019 at 6:53 AM
    Boss hoss
    Boss hoss Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    I just turn my hearing aids off and my truck is like a Rolls Royce then. :thumbsup:
  19. Sep 3, 2019 at 7:19 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    OP has a 2019 so the LCA whistle 'should' have been addressed. It was primarily found in the 2016 models, even my 2017 came with the LCA already plugged
    shakerhood likes this.
  20. Sep 3, 2019 at 8:14 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Op, did you run the fan on all the time? It’s possible you are hearing the Darth Vader breathing sound that comes with the HVAC system.
