vsc/trac warning beep... make it stop!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ttylerr, Dec 28, 2009.
  1. Dec 28, 2009 at 8:33 PM
    ttylerr
    ttylerr [OP] Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    does anybody know how to disable the god damn vsc/trac warning buzzer on 09(10)'s?
    i'm getting pretty sick of the damn thing going off everytime i make a turn on a snow covered road.
  2. Dec 28, 2009 at 8:37 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Yes, move to Florida. You are pretty much stuck unless you want to disable the system completely. You could go to the dealer and ask them as well.
  3. Dec 28, 2009 at 8:47 PM
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
    i don't want to disable the whole system. just get rid of the beep.
    moving to florida would be ideal... but, not possible
  4. Dec 28, 2009 at 9:00 PM
    JKD
    JKD Well-Known Member
    I've been driving around in the snow for the past week--it only goes off when the back end gets squirrelly. How hard are you driving?
  5. Dec 28, 2009 at 9:05 PM
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
    not hard at all. i like to make the back end slip out purposely at times and the damn beeper seems like it never stops.
  6. Dec 28, 2009 at 9:15 PM
    JKD
    Yeah, that'll do it. I think it's there to let you know it's working (and that you reached the 'limits'). Maybe to keep people from getting too complacent about driving hard in slick conditions.
    What if you could just reduce the volume? Somewhere in the dash is a piezo beeper. A sticker or a piece of electrical tape over its output hole would reduce the volume.
  7. Dec 28, 2009 at 9:16 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    you can disassemble the dash and eliminate the beeper. it gets rid of the stupid dinging whaen the door is open too
  8. Dec 28, 2009 at 10:32 PM
    Yoytoda
    Roland
    completely stock
  9. Dec 28, 2009 at 10:35 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Yea, find the pizzo and tape it up or clip it out... that's all I'd know of.
  10. Jan 1, 2010 at 8:17 PM
    izu_yo
    izu_yo Active Member
    Calgary
    2010 Black TRD Sport
    OP... I know exaclty what you're experiencing. Have you found a solution yet?
    I found a diagram on page 45 of this document:
    It looks like the VSC buzzer (V7) is the source of the annoying sound.
    I'm going to take a trip to the dealership when I get some time off work to see if it can be disabled electronically before I disassemble my dash to find the buzzer.
  11. Jan 1, 2010 at 8:26 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    Dealership will not disable any type of warning/advisory type lights or chimes.
  12. Jan 2, 2010 at 8:45 AM
    izu_yo
    Calgary
    Thanks for the info Hootbro. I won't waste my time there.
  13. Dec 8, 2010 at 5:34 AM
    three west
    three west Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
    this truck is absolutely no fun to drive in the snow :mad:
    I LOVE my winter driving, but that damn beeper came on in the middle of a drift and the VSC straightened me and left me pointed directly at a tree
    ABS sure seems sensitive when braking on ice/snow too.
  14. Dec 8, 2010 at 5:37 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    That depends completely on your tires. For instance, stock dunlops will cause your ABS to kick in at every stop on snow. Switching to an AT tire, for instance, will likely result in it never kicking in due to the better traction. So if ABS is kicking in all the time, you likely aren't using the correct tire for your environment.
  15. Dec 8, 2010 at 5:54 AM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    This is true, when I had the stock Dunflops, my ABS would kick in on the smallest bump while stopping. Since I put the BFG AT's on it I haven't felt it once.
  16. Dec 8, 2010 at 6:11 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I too am a bit annoyed by the frequent warning on snow covered roads. It doesn't have to be aggressive driving...sharp corners or even pot holes will set it off.
    And I also agree that this truck is not fun in the winter....IF you leave the systems turned on. When I get into an empty snow covered parking lot, I stop and disable all of the safety systems. Then it's GO TIME!!! Once the truck is restarted, the systems automatically turn back on. I suppose it's good they are there but you have to remember to turn them off before having any fun.
  17. Dec 8, 2010 at 6:44 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Your truck is lifted, correct?
    It is common for the lift to through the system out of tolerance, maybe yours is a little sensitive :confused:.
  18. Dec 8, 2010 at 6:18 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  19. Dec 9, 2010 at 5:46 PM
    three west
    JD
    UP MI
    09 DC SB TRD Sport
    thanks for the tip moose, I am still running the dunlops, would like to change, perhaps nearly rearending that person coming down the hill today is reason enough....
  20. Dec 9, 2010 at 5:48 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    Don't complain guys. Atleast we can still disable the traction control fully. My buddy with a new dodge ram with the 5.7L can't even fully disable his !
