XPOTRPR mounts and accessories
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by XPOTRPR, Jul 1, 2016.
  1. Jul 1, 2016 at 6:09 PM
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Howdy-Ho TW :cheers:
    This here, is a for-sale thread for a few items I have been making for myself, and all you like minded enthusiasts. I offer my CAD and Prototyping services for anyone interested on the side. Programming and CNC Machining for anything serious. PM me for inquiries. :thumbsup:
    EDIT - 4/15/2022:
    BACK IN ACTION
    **This is just a hobby, so please bear with the inventory selection, stock and lead times. I will do my best for you fine people.
    First.. a few pictures of some of the parts I have been producing, as well as some custom projects.. you know, to entice you a bit..
    File%20Jun%2016%2011%2015%2045%20AM_zpsi_39a6c651c3a83b9a93a631e62f9b6bd7d2edd07c.jpg
    _______________________________FOR SALE_______________________________
    Switch-Pro 8100 Flush Mount NOW INCLUDING 3RD GENS
    - $30 shipped (3 Versions - see below for info/stock quantity)
    3D printed in Black ABS. Some texture. Friction fit, so no hardware required. Mount drops into hole in mounting surface. Switch-pro pops in from the back side. Comes with stencil to cut hole to proper size. RTV can be added to bottom of flange to help adhere to surface.
    Install/Info:
    https://www.tacomaworld.com/threads/switch-pro-8-switch-panel-group-buy.389851/page-14#post-12285505
    -Flush
    Fits the 2nd gen Automatic center console (0 in stock)
    Installed in my truck (primered, sanded, painted)
    -Flat
    Fits any flat surface up to .180" thick (0 in stock)
    -3rd Gen
    Fits in the Cubby with some trimming. (4 in stock)
    __________________________________________________________________________
    -Quick Disconnect Mount
    - $60 shipped (Currently Unavaible)
    Machined from 6061 Aluminum. Comes with Stainless Steel quick release pin (rated up to 4,800lbs) w/ lanyard. Holes on one half to mount to desired surface, or can use hose clamps to mount to tube. Designed for Fire Extinguishers, but can be used for anything you seem fit. (Not yet tested with Propane or Air tanks)
    -2nd Gen Hazard/Clock panel
    - $40 shipped (made to order)
    3D printed in Black ABS. Some Texture. Friction fit, but some RTV or epoxy on the backside can only help. Designed for these Push button switches...
    https://www.superbrightleds.com/moreinfo/push-button/led-indicator-push-button-switch/1201/
    ...But can be changed to basic holes/slots easily. PM with requests/Dims.
    Install/Info:
    https://www.tacomaworld.com/threads/az2013-spruce-build.401321/page-9#post-12605951
    -MORE TO COME!!
    PM me with any questions or possible custom part ideas and we can go over if its feasible or not.
  2. Jul 1, 2016 at 6:35 PM
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    I love the clock replacement switch panel. Tons of possibilities. Do you have that red switch wired to your flashers? Or just no flashers?
    WetTaco and jmaack like this.
  3. Jul 1, 2016 at 7:01 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That is actually on @AZ2013 truck. He is still trying to wire it I believe.
  4. Jul 1, 2016 at 7:41 PM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    Interesting...
  5. Jul 1, 2016 at 7:46 PM
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Sub!! That hazard clock light thingy looks interesting.
  6. Jul 1, 2016 at 7:49 PM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    :D:drool::drool:
    ODNAREM likes this.
  7. Jul 1, 2016 at 8:21 PM
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
    Sub'd :thumbsup:
  8. Jul 1, 2016 at 8:24 PM
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    Badass man! It's about time you made one of these to show off all your skills!
  9. Jul 1, 2016 at 8:28 PM
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    The red switch is indeed for the hazards. Unfortunately I haven't figured out how to wire it correctly. I've isolated the original wire but no dice. It's more than likely something simple that I'm just missing.
  10. Jul 1, 2016 at 8:48 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I shall text you this weekend :thumbsup:
    ODNAREM likes this.
  11. Jul 1, 2016 at 9:21 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'll be out of town this weekend, and off till Wednesday, so I'll try my best to keep in contact buddy!
    ODNAREM likes this.
  12. Jul 1, 2016 at 10:05 PM
    Jmad1997
    Jmad1997 Well-Known Member
    2005 TRD sport long bed 6" fab tech lift
    I am really liking that switch panel setup
    XPOTRPR[OP] likes this.
  13. Jul 1, 2016 at 10:08 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Then next Thursday man.
    No rush. Enjoy your time off!
    ODNAREM likes this.
  14. Jul 5, 2016 at 3:06 PM
    BortlesKombat
    BortlesKombat New Member
    Jae
    2012 4x4 Tacoma -gray crew cab w/ short bed
    Side steps, shocks, lift
    Props for that Coheed under the hood! :cheers:
    JCos327 likes this.
  15. Jul 5, 2016 at 3:45 PM
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    :bananadance::bananadance::bananadance: Bought time all this dope work is out!
  16. Jul 5, 2016 at 4:39 PM
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
    Thank you Sir!
  17. Jul 6, 2016 at 7:44 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Sweet stuff
  18. Jul 6, 2016 at 6:13 PM
    Mcolt11
    Mcolt11 Well-Known Member
    2013 tacoma Trd off-road 3" toytech lift 33's
    Toytech 3" lift, 33" cooper stts, xd addict wheels, volant throttle body spacer, led interior lighting, truxsport cover, custom satoshi grill, mbrp dual exaust.
    Awesome stuff!! Who makes the switch panel that fits inside your center console bezel ?
  19. Jul 6, 2016 at 6:32 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  20. Jul 7, 2016 at 8:20 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Updated stock quantities for the Switch-Pro mounts.
    4 of each currently.
    working on a new batch of quick release mounts.. ETA is probably next week.. just working on them as I have the time.
