Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 15, 2013 at 9:05 AM
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Well since Dan doesn't want questions asked on his OME Gallery thread I thought I would start a Q & A thread.
    If you have a question ask away and the TW Emu Gurus will answer it.
    If you have OME post a pic or two & tell us what you got.
    What did you put up front & what did you get?
    What did you put in back & what did you get?
    If you got Dakars on a 2nd Gen share your measurements with @OZ-T here.
    Are you running trail armor & how much lift did you loose or what did you do to regain/maintain lift?
    Tire & wheel specs & rub or what you did to eliminate rub.
    Are you still running a sway bar?
    Thanks Mike for the info.
    From the OME Bible JohnBb 1:31
    This thread is for everyone but if you want to go to a 1st Gen only thread it's here OLD MAN EMU SETUPS ON 1st gen
  2. Jan 15, 2013 at 9:05 AM
    4Wheelin4Banger
    Randy
    885s on 90000 Sport Nitros gave me 3".
    Dakars gave me 3" with shell.
    If you got Dakars on a 2nd Gen share your measurements with OZ 2nd Gen OME Dakar hub to fender measurements ([​IMG] 1 2 3 ... Last Page)
    Been there done that.
    I just finnished adding 1/4" top plate spacers & I'm almost where I was before adding the sliders & skids.
    I was 23 3/8" DS I'm now 23 1/8".
    It rides just like it did before adding the spacer, just 1/2" higher & better than it did before adding the sliders & skids.
    255/85/16 BFG KM2s on 1st Gen TRDs 16"x7" with 4.5" BS. No rub & no trim.
    No & it ride even better on & off road.
  3. Jan 15, 2013 at 9:24 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    :cookiemonster:
    Rawlins and paintedhands like this.
  4. Jan 15, 2013 at 10:00 AM
    la0d0g
    running for the hills
    For crawling not hauling
    I'm just here for the emu pic :popcorn:
    Tocamo and Ninj like this.
  5. Jan 15, 2013 at 10:06 AM
    4Wheelin4Banger
    Randy
    It does get your attention doesn't it.
    Come on Matt you've got some OME post it.
  6. Jan 15, 2013 at 10:08 AM
    Deadcrowm
    Deadcrowm Well-Known Member
    Ventura County
    07 4x4 TRD
    Camper shell, bed kit, tires
  7. Jan 15, 2013 at 10:20 AM
    la0d0g
    OK I'll play :D
    My rig and an oblig shot of Pyro
    884s and 5100s
    TSB and 5100s
    If you got Dakars on a 2nd Gen share your measurements with OZ [​IMG] 2nd Gen OME Dakar hub to fender measurements ([​IMG] 1 2 3 ... Last Page)
    Not yet but soon, very soon
    Front relentless alum bumper with winch, IFS skid, mid skid, sliders, and relentless rear steal bumper. I have a t-case skid sitting in my garage, no comments Eric :p Not sure what I lost in lift and I didn't do anything to regain lift. Soon I'm just redoing it.
    265/75/16 KM2s on 16x8 w/ 4.5 BS. No rubbing.
    Yep, too scurred to take it off ;)
    Here are the specs center hub to bottom of fender:
    DF 21.5"
    DR 22.25"
    PF 21.75"
    PR 22.5"
    Rupp1 likes this.
  8. Jan 15, 2013 at 10:22 AM
    OZ-T
    Peter North
    British Columbia
    I'm not moving people's measurements from this thread to the Dakar Measurement thread
    Just sayin
  9. Jan 15, 2013 at 10:24 AM
    MJM777
    MJM777 Well-Known Member
    N.E. Ohio
    2012 DCSB 4x4 Sport
    Sub'd
  10. Jan 15, 2013 at 1:16 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    09 trd offroad access cab
    pic coming later
    885s no top plate spacer, 2 1/2" on drivers side, 2 3/4"+ on passanger side (yes i used the trim packer) hub to fender is about 23" and 23 1/4
    dakars with 3rd leaf removed. Hub to fender i am half inch higher in the rear compared to the front. Based on OZ's dakars thread, removing the 3rd leaf reduced the amount of lift by 1-1.5 inches (OME says 3/4)
    Nope but i will have sliders very soon! I might add top plate spacers and reinstall the third leaf in the future EDIT: bamf sliders added and no change in measurements
    EDIT AGAIN: CBI front bumper and 8500lb superwich added ~200lbs, lost about 1" of lift up front and the coilovers ride a lot softer now
    SCS stealth 6 wheels- 17x8.5, 4.3" backspacing, -10mm offset with 285/70/17 duratracs. Lots of rubbing, cab mount chop, flattened pinch weld, trimed bottom of fenders front and back and removed alot of plastic. I still rub a little at full lock when the suspension is flexed hard
    yes, no plans to remove it yet, i hate body roll!
    only other detail about my setup is SPC light racing UCAs. Caster numbers are 2.5 and 2.7
    Great idea for a thread! And thanks randy for answering my OME questions months ago before i did my lift, thanks to OZ also
    BandanaBerg likes this.
  11. Jan 15, 2013 at 2:50 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    can't wait to see the pics of the stealth 6 wheels :popcorn:
  12. Jan 15, 2013 at 2:54 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    All i have right now is crappy cell picks
    And a little driveway flexing :cool:
  13. Jan 15, 2013 at 3:19 PM
    la0d0g
    Looks great.
    Question - what do you still rub at full lock?
    taco417 and dan81finn like this.
  14. Jan 15, 2013 at 3:30 PM
    nj636
    Kev
    Jersey
    looks great
    dan81finn likes this.
  15. Jan 15, 2013 at 3:33 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Thanks! During normal driving no. If i try to make them rub by stuffing the front tires at full lock they do lol. I just need to cut more plastic and a little more off of the bottom of the fender in the back of the wheel well. the trimming is not very noticable unless you know what your looking for. When the front wheel is stuffed in the wheel well i have ~ 1/4" of room between the tire and the chopped cab mount
    Thank you! Im very happy with my setup.
    JAL4 likes this.
  16. Jan 16, 2013 at 9:28 AM
    4Wheelin4Banger
    Randy
    Thanks & you're welcome.
    Taco looks good Evan.
  17. Jan 16, 2013 at 10:00 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    886 with Nitro 90000 up front, Dakars with N182 in the rear with this pic (changed to Fox 2.0 recently).
  18. Jan 16, 2013 at 11:27 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Nice truck^ that hidden winch is awesome
  19. Jan 16, 2013 at 11:32 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    :rant: there's too many pics here, there is a thread for that :rant:
    jk, jk
    ecgreen likes this.
  20. Jan 16, 2013 at 11:34 AM
    MadToy
    Nick
    Huntersville, NC
    Ha! I'm getting confused with all the different threads, and what is expected in each :confused:
